Question about Roper Refrigerators
Roper Fridge I have a top freezer refrigerator that keeps icing up in the freezer but isn't staying cold in the lower part. I tried defrosting it and plugging it back in and it worked better for a couple days but it didn't last. The fan appears to be running (at least until the ice builds up too much to let it spin freely) but it doesn't stay cold enough to keep food in.
  • 828 Answers
You have one of the following problems which is indicated by the frost buildup. Your defrost timer has failed, or defrost heater circuit consisting of a defrost heater and defrost thermostat. Start at the defrost timer. May be located in the fridge compartment near the temperature controls. There may be a recess through which you can turn the dial SLOWLY clockwise until you hear one click. the freezer will be in defrost. Wait 18-22 minutes and the freezer should defrost and restart into cooling. If it does not restart after 30 minutes turn the screw clockwise again one more click and it should restart.
If you had to turn it again to get it to restart the timer is bad and needs to be replaced. If the timer restarted the cooling mode after 18-22 minutes and defrost did not take place your problem is in the heater circuit.
Posted on Jun 09, 2008
Roper Refrigerator. No ice maker. Freezer on top. Water pooling in refrigerator. keep refrigerator in garage.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 20, 2011 | Roper Refrigerators
Refrigerator cold ice on ceiling no air to refrigerator and its warm the fan not turning
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 19, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My refrigerator won't stay cool but my freezer works fine
You have something wrong with the vent going from the freezer to the fridge. You probably have a defrost problem and ice is blocking the vent that goes from the freezer and comes out in the roof of the rerigerator compartment. Replace your defrost timer and bimetal.
Sep 11, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Freezer working fine (no ice buildup), refrigerator warm
make sure your cond under ref is clean allso check your door gaskets if its getting moisture in it i have seen the damper stick from ice from door gasket and when your defrosting evap its clearing damper
Jul 05, 2009 | Roper RT14DKX Top Freezer Refrigerator
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer not freezing
you may have defrost problem or check fan by compressor
Apr 04, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Roper fridge is not cold enough now.
Check the back wall of the freezer.
Is it iced up?
If yes, replace the defrost parts.
Mar 10, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
177 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
