Question about SanDisk Sansa Clip MP3 Player
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
My Sandisk Sansa Express mp3 player showed low battery after being taken out of usb port on computer. I found out that it has quit charging. It is completely dead except for a very small speck of blue in window. Help me with this?? sanDisk 2gb clip mp3 plyer
  • 1 more comment
  • Anonymous Jun 09, 2008
    Mine does the same thing. It charges when it wants to...
  • black rose Jun 14, 2008
    Thank you so much.
  • Anonymous Aug 27, 2008
    How do I charge sandisk mp3 player?
Thats a good idea but if it dosent show up under my computer how do you fix it?
where do i get the driver for this thing the disk it came with was usless it only installed a audio rapsody player that sucks.
Posted on Jun 17, 2008
    Sergeant:
  • 213 Answers
SAME THNG YA
FORMAT IT
Posted on Jun 15, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
I tell you connect to the computer your device
and right click on your device and format it
Posted on Jun 11, 2008
SanDisk Sansa Express 2 GB MP3 Player (Black), battery status states 14% critically low....what does it mean and what actions should I suppose to do?
You need to charge the battery so you can continue playing your MP3player.
Connect the supplied USB cable into the player and then plug it into the USB port of your computer. The computer will charge up the MP3 player and you can also copy mp3 music and photos etc to the MP3 player.
Aug 25, 2011 | SanDisk Audio Players & Recorders
It was kept idle for 4 months.when power button is pressd the screen shows "battery is too low system shut down".when charging is tried through PC USB port there is no proper charging
Not all computer USB ports put out enough current to charge batteries. If you have another USB port on your computer, try that. Try another computer. If that doesn't work, try an AC-to-USB charger, as you might find for cell phones.
Nov 17, 2010 | SanDisk Sansa e260 MP3 Player
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
Sir where i go 2 repair it.my sansa express 1Gb is not working
sir i always stop 2 play it for 24 hours and then click the main button .it shows sandisk suddenly off.so it means that it charge is low
Nov 02, 2009 | SanDisk Sansa MP3 Player
My computer doesnt recognize my sansa express and it used to
check usb cable and make sure that the cable is connected properly .
Try connect to other usb port .
Hope it helps
Jul 17, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
MP3 Sansa Sandisk 1 GB
If it won't charge, then:
1) USB connector is damaged
2) USB port is damaged (Have you tried other port and/or other computer ?)
3) MP3 Battery is damaged
May 27, 2009 | SanDisk Sansa m240 MP3 Player
Will not take a charge. took two charges prior but has now stopped
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa clip wont power up unless hooked up to usb
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Charging
computer.
Clip player.
Sansa
adapters.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
hii
just re plug it and see what happens or.. if you have wall mount charger with a usb connect .. then us it ... and if all fails... open ur player and disconnect the batter for a minute and reconnect it and then put it to recharge...
let me know what happnes..
tc
May 28, 2008 | SanDisk Sansa MP3 Player
SanDisk Sansa m230 MP3 Player
maybe the internal battery is shorted,leaked,low. i remove it and start working well.
Aug 05, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
190 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
