Question about Agfa SnapScan 1212u Flatbed Scanner
Scanned sheets divided
Whenever I prepare to scan just about anything, the program divides the sheet into several sections, each boxed off with a broken line and then wants to scan each little section individually. This is no good. I end up having to close up each box separately to get one cohesive page. How can I skip this whole operation of closing all the boxes? I just want to scan the entire page without a lot of fuss.
Thanks.
  • Conundrums Jul 20, 2008
    Bingo! Thanks!
In the preference section Uncheck "Detect Multiple originals".
Posted on Jul 17, 2008
If steel rebar sheets are 3.6m by 2m how many sheets would i need to cover 10117 square meters
3.6 X 2 =7.2 sq meters
10117 sq meters divided by 7.2 = 1405.13 or 1406 sheets as you cannot get a part of a sheet
grade 3 maths really
Feb 19, 2017 | Office Equipment & Supplies
What would 150 letter size sheets convert to in cubic feet measure
8x10 x whatever the height of the package is= cu inches. divide by 12 to get cu.ft.
Jun 18, 2015 | HP Office Recycled White 8 1/2 x 11 Inch...
I have 10000 sqft in drywall how much linear ft is it
Drywall sheets are 4 feet wide. Thus, each foot of a drywall sheet contains 4 square feet. Divide 10,000 by 4 = 2500 linear feet of drywall sheets. Add 5 to 10% for wastage.
Mar 25, 2015 | Drywall
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
What is the best way to sew elastic on to a baby sheet ? ( No casing )
Are you making a "fitted sheet"? Divide length of elastic (3-4 inches long) in half; pin halfway point onto sheet's location. Stretch left side to desired extension and pin across width; do same for right extension.
Sew along the edges lengthwise, then across width. If you don't sew both length edges, elastic will BUCKLE and "warp".
Aug 29, 2013 | Janome Memory Craft 3000
How do i scan more than one sheet into a pdf document?
In Adobe Acrobat, go to -File-/-Create PDF-/-From Scanner-/-Scan-. Scan your first sheet and after it is completed, in the Acrobat Scan Dialogue box, click on -Next-, and scan the next sheet. Continue until you have finished your document and then click on -Done-. You can make your scanned document searchable by doing an OCR procedure on it by going to -Document-, -Recognise document by using OCR-/-Start-.
Aug 12, 2011 | Canon MP560 All-In-One InkJet Printer
How do I get my scanner to go to the next line/box when using Excel?
In your programming manual there is a barcode scan that needs to be scanned in that adds the carriage return function. To do this you will first need to scan the barcode to put the unit into program mode, then scan the carriage return barcode, then scan the end programming code. Now when you scan a barcode the scanner will add the return to the sequence it sends to the computer. If you can't find your programming book you can download the sheets from the Symbol web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 14, 2010 | Symbol LS2208 Handheld
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
How do I change the type of file my scanner saves a document in?
No .Type reconiznition software is very complicated and expensive. All a scanner does is divide the sceen into millions of dots and copies those dots in Picture(JPEG) format. It's software know nothing except to copy what is there.
Mar 09, 2009 | Epson Perfection 2400 Photo Flatbed...
Formula for percentages
column d = column c divided by column b. result can be formatted to 3 decimal places or anything you prefer.
Sep 09, 2007 | Microsoft Office Standard for PC
Agfa SnapScan 1212u Flatbed Scanner Logo
67 people viewed this question
Top Agfa Office Equipment & Supplies Experts
Chris Larocque
Pierre Legault
Are you an Agfa Office Equipment and Supply Expert? Answer questions, earn points and help others
