Question about Gestetner Office Equipment & Supplies
Gestetner 1302f error code sc 101 - Gestetner Office Equipment & Supplies
Error code sc 309 gestetner 1302
Posted on May 16, 2010
  • 37 Answers
Scanner home position error , white plate shading error .
check to see if the scanner can move , take the glass offf it has got a white sticger underneath , clean the sticker.it is used to initialize the scanner if this is dirty it will give sc 101
Posted on Aug 14, 2008
Error sc 551
Replace both the thermistors and reset SC code
Sep 05, 2014 | Gestetner Office Equipment & Supplies
Error 120 code
To reset the SC code follow these directions:
Resetting Ricoh Savin Lanier Gestetner SC Error Code
Error code 120 is scanner home position sensor problem. If it's a recurring problem, here are some troubleshooting tips:
SOLUTION:
Turn the main switch off and on.
Check the wires between Home Position sensor and the SBU.
Fix scanner board or the SBU .
Check the wires between scanner motor and the scanner I/O board
Fix the scanner motor.
Fix the Home Position sensor.
Fix pulley, timing belt, the scanner wire,
Fix the carriage.
Jun 17, 2014 | Gestetner Office Equipment & Supplies
How can I solve error code E-1 on my gestetner 2722ztd photocopier? the error occurs when I turned on the power
u need to get a full error code press star or hash key to get the rest
my gues its 101 which is exposure lamp brocken or something to do with optics
Nov 02, 2010 | Gestetner Office Equipment & Supplies
Gestetner 1302f error code sc541
SC541 relates to a heat up error.
Jan 13, 2010 | Gestetner Copier
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Gestetner DSM645SP Error Code SC 322
After research it seems this problem is not easily fixed.
Jan 16, 2009 | Gestetner - DSm645sp Digital Imaging...
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
724 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
