Question about Kenmore 43142 Front Load Washer
Kenmore he2 front loader
The smell is terrible, now the spin cycle has stopped and clothes are soaking wet. We have checked the pump/filter and nothing is there. Called for service, man didn't know anything about it, said it was a board, we ordered and changed it ourselves, still not working.
  • 1 more comment
  • Anonymous Nov 10, 2008
    mine is doing the same thing
  • Toby Norton
    Toby Norton May 11, 2010
    When you checked the pump/filter, did you check the impeller part of the pump also? It through the hole on the right side of the pump. While you can get you finger in there, it is a very awkward angle. If you drain and remove the pump, it is easier to check through the hole in the rear. If something is wrapped around the shaft, it's the only way to see/ remove it.
  • oldfixer May 11, 2010
    is it showing any fault codes do you hear the pump running or trying to run?if pump is trying to run may be bad impeller on pump or something locking up impeller
  • 246 Answers
We have not heard back on this in about a week. I'm presuimng It's been repaired?
Posted on Jun 21, 2008
I have a WSXH208 ge front loader It started to fill was and then in the middle the water pumped out but did not finish and clothes were sopping wet, Drum stopped spinning. what could be wrong
all front loaders will not go into high spped spin if there is water in the tub.You should first remove the bottom panel and check the water pump for blockage.Some units have a sscrew style filter to catch debris befor it enters the pump impellor.when you unscrew the filter make sure you have a wet vac handy.
Apr 02, 2013 | Washing Machines
I have a 4 year old Kemore HE2 that isn't spinning the water out of the clothes. I encountered this issue about a month ago and found a fix for cleaning out the hidden pump trap. After removing a large...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2010 | Kenmore HE2 Plus Front Load Washer
I have an lg wm1814cw front loader with a ue code
Probably the pump filter is blocked.Make sure the machine is empty...Access filter via small door at floor level. Unscrew the filter cap, and clean filter. check that there isn't a coin stopping the impeller vanes. ...When you take the cap off, any water left in machine will flow out!! Leaning the machine back can help.....Good luck...Nomess
May 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clothes are still very wet after the spin cycle.
sounds like not pumping very well, try cleaning the filter/ pump
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
My washer will not spin my cloths all the way they are still very wet. It shows that it is on a high spin but doesn't cloths are still very wet.
Plug off the wall socket. You have to check out your filter and pump. The pump does not function for either there is a loose wire some there or something could be clogging the impeller. First check out filter.
Mar 16, 2009 | Kenmore HE2 Plus Front Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 43142 Front Load Washer Logo
183 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
