Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Defaults to 0 deg. temp
I have a Kenmore upright freezer that is now approx 1 1/2 yrs old. For some reason when the power goes off for any length of time the freezer sets to a 0 degree default temp. ( which means not cold 7 being the coldest). This has happened several times and I just thought well ok its a fluke until about the 4th time I lost about $400. worth of food. I am told that there is no recall on this . I am wondering if anyone else has had this issue? Kenmore 13.7 cubic ft. 388 liter freezer.
  • kronmagnum Jun 18, 2008
    I don't know if I have the same freezer (my model # is 253.21041105), but when I get either electrical storms or power bumps my freezer will completely shut down and will not power back up unless I physically disconnect it from the power source. I even put it on a power strip with a CB on it, and I had to shut the power strip off, turn it back on and then hit the power button on the freezer. Without the power strip I have had to unplug the freezer from the outlet to get it to power back up. Last night I put a surge protector on the outlet and plugged the strip into that, we are expecting storms today so I see how it goes. My question is....is there some kind of shunt trip circuit in the freezer where any power surge or bump might cause it to lock out the freezer power supply?
    Master:
  • 683 Answers
I would be more worried about constant power disruptions
Posted on Dec 03, 2014
tborn6
  • 700 Answers
SOURCE: purchased a 2004 upright freezer i dont know how to set temp
sir seven is the coldest setting. Good Luck
Posted on Jan 10, 2009
kachbibi1
  • 979 Answers
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Posted on Feb 17, 2009
Maytag317
  • 1136 Answers
SOURCE: Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
woodchuck789
  • 4070 Answers
SOURCE: Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Oct 13, 2009
walterkunesk
  • 683 Answers
SOURCE: how do i figure out
wide x length x 3
Posted on Feb 21, 2011
I can't turn my Kenmore upright freezer on.
Try disconnecting power for about 30 seconds, and then restore power. This will reboot the control and maybe restart.
Jul 09, 2017 | Kenmore Freezers
Have upright frost free freezer alarm is going off about once or twice a day.Put a thermometer it is around 20 degrees I mute the al;arm and it beeps again and again after several hours. looked to clean...
Hi most deep freezers operate at 0 dergrees. your model may have 2 temp zones. 0 or 20 deg.I'm gessind that your sensor is going off when the defroster is on to melt ice (defrosting). Lower the setting. monitor and repeat as needed. if it continues you may need to replace the unit or ad freon. If the unit is over 13 years ge a new one.
Jul 21, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer quit freezing would work intermitantly and then quit cooling altogether, Approx 10 years old trouble shooting advise or most likely cause would be appreciated
Sorry to read about your problem. you can have many different problems.
Here are some areas to troubleshoot
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company. for compressor issues
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Kenmore upright freezer only 3 years old running ,no clicking noise, no ice build up but won't completely freeze although set to 7 (lowest temp)
check door seals, also check vent direction, a dial or lever in fridge, it adjust how much air goes to fridge and freezer
May 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
214 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
