Question about KitchenAid Dishwashers
I have a kitchenaid superba diswasher that one of the door hinges has either popped off or broken. I need instruction on how to get into the door to replace it. Model KUDS01FLSS2
After taking the bottom cover off, I noticed that it's the cheap string that's broken and not the spring. I'm assumming that's pretty easy to replace? I've ordered the parts and just waiting. Any tips on replacing it would be appreciated.
Posted on Jun 10, 2008
    Problem Solver:
  • 19 Answers
What you need to do is unscrew the screws at the top of the dishwasher that's securing the unit to the countertop. gently pull the d/w out from underneath the counter.. please be careful because you may have a copper water line connected to the d/w. if so, then you must remove the line because the copper does not allow you to move the d/w around without the copper line beginning to leak. if you have any other line you can maneuver ok. also, check to see if the electrical line is long enough. if not, secured the power and disconnected the electrial line. when you have all of the restriants out of the way, then pull the d/w out and reconnect the springs. you have 2 spring configurations. you can look at the other side that's not broken to see how to put the other side on. usually only 1 side breaks. you'll need to order the string that connects the spring to the plactic figure 8. take a look at each side and you'll see what im taking about. thanks.
I need to replace the hinges on my kitchenaid superba, how do i take the door off ?
Usually all you have to do is open the door slightly, and lift upwards keeping your fingers away from the hinges as they have a very strong spring and can hurt if they release.
Jan 04, 2011 | Ovens
The top hinge on my Kitchenaid refrigerator door is making a loud popping sound when the door is opened about 90 degrees. I removed the top hinge and it looks OK. Is the spring assist mechanism (that I...
You can easily go online and purchase the parts that you need... they usually come with replacement instructions...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 15, 2010 | Microwave Ovens
Door doesn't self close on Kitchenaid Superba frig
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Jul 11, 2010 | KitchenAid Superba Architect KSCS25INSS...
Superba KEBS277 broken door spring
go to appliancerepairpros.com or repair clinic .com..good luck...
Apr 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
My kitchenaid superba oven door..
Contact the landlord and have him repair or replace the oven.
Aug 24, 2017 | KitchenAid Ovens
Oven door hinge replacement installation
kitchenaid superba oven door will not stay closed.
Oct 22, 2008 | Kitchen Ranges
Kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Chute door dislodged
IF THE ICE DOOR HAS COME OFF, THE CHANCES ARE THAT THE PLASTIC TAB THAT HOLDS THE HINGE PIN IN PLACE HAS BROKEN. IT IS PART OF THE PLASTIC HOUSING. WHIRLPOOL/KITCHENAID HAS A FIX KIT THAT REPLACES THE PLASTIC TABS WITH A METAL BRACE THAT IS PRESSURE TAPED IN PLACE. I HAVE INSTALLED A COUPLE OF THESE KITS AND IT TAKES PATIENCE AND TIME. THE KIT WILL HAVE INSTRUCTIONS ON HOW TO INSTALL. FIRST VERIFY THAT THE TAB HAS BROKEN. IT IS LOCATED IN THE UPPER LEFT SIDE OF THE OPENING TO THE ICE CHUTE.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba side by side doors slam
sounds like a door closure is broken on refrig door, a 2 part door closure(cam). look under door where sits on hinge, freezer door should have as well(use for comparison as to broken or not)
Feb 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
Dishwashers Logo
202 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
