Question about Sub-Zero 690 Side by Side Refrigerator
Refrigerator smell I have a GE TDX 11 SNYAWH that seems to have began producing a funny smell. I first thought to check the drip tray but after removing the front grate I don't seem to have one under there, never heard of one not having a drip tray. What could be the possible causes for this?
  • 32 Answers
This refrigerator has a tray on top of the compressor. If the tray has water in it there may have been some food or something in it. It may have turned rank. You may also want to make sure the temperature and defrost are right. I am having problems with the thermostat. It is stuck on 4 which is too cold. I ordered a new thermo and will put it in this weekend. I hope the defrost heater is working properly if there is one.
Posted on Sep 24, 2008
  • 828 Answers
Defrost water tray may be located in the back of the refrigerator behind a removable panel. If you remove the panel make sure you re-install it.
Posted on Jun 09, 2008
GE Profile Refrigerator has an electrical smell but it still cools
sure..the drip is no biggie..the smell..can be from a variety of worrisome issues..
compressor
capacitors
wiring
motors(fan)
you planning on dissecting this one yourself_
Oct 23, 2008 | GE Refrigerators
How do i get to and remove the drip tray on my liebherr KIU 1640 fridge?
Should be in the back at very bottom of refrigerator, remove back panel to access the tray....
Feb 27, 2015 | Liebherr KIU 1640 Premium Compact...
Why is my GE Monogram, model zfsb26dnd SS, emitting an odor from the front bottom behind the base grill. The air blowing from underneath produces the smell when the fan is operating. The odor appears
If your refrigerator is frost-free, check the drainage tray at the bottom, probably behind a removeable grille. You may find the tray is full of all kinds of disgusting stuff collected by drainage during defrost cycles. Remove the tray and clean it thoroughly. Reinstall the clean tray.
Dec 10, 2014 | GE Refrigerators
Leaking water on floor, even without water hooked up. Seems to be coming from under the fridge
Your freezer defrost drainage tube may not be routed to the evaporator tray under the refrigerator. If this is the case, humidity condensed from the freezer, then drained down the tube will be dripped onto the floor.
The second theory is that the drainage tube could be blocked. Humidity in the freezer is removed from the air sent to a drainage tray, at the rear of the freezer, which has a drainage tube which carries the water to an evaporation tray at the bottom of the refrigerator unit, on my GE. if the drainage tube is blocked, the water will find another route. Check the drainage tube after you find it. First try inspection. if there is standing water in tray in the freezer, use a flexible wire to clear the tube.
Oct 04, 2010 | GE Profile TPX24PBDCC Side by Side...
I have a refrigerator that leaks water inside at the top
flush out drain hose in drip tray in back of ref with hot water line is most likely stoped up
Sep 14, 2009 | GE Refrigerators
GE side by side refrigerator smells on the outside!
Mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section . Too much bleach and the smell of bleach would be circulated by the fan to the room , so be sure to add water .
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Bad smell from the back
Any drippings in back may cause a funny smell with water settling behind the refrigerator. Pull your refrigerator out from the wall and trace the smell. Maybe your waterline needs to be cleaned.
Jul 03, 2009 | Whirlpool Refrigerators
GE refrigerator
this may be water from the defrost cycle. if this drains to tray over compressor, check tray is not too full (water evaporates from heat of compressor) otherwise defrost water will go to a seperate container which may have a split or is overflowing. fault can also be caused by poor door seals which would produce too much ice on evaporator pipes
Mar 21, 2007 | GE GSS25JEMWW Side by Side
Sub-Zero 690 Side by Side Refrigerator Logo
212 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
