Model SHU43C02UC/17 fills and drains fine but during the wash and rinse cycle the water just dribbles out of the spray arms. I checked the water flow to the machine and found it to be fine. I removed the filter in the basin and made certain it was clean. I also removed the arms and checked for clogs, none were found. Remove cover of the impeller in the basin and checked for clogs and found nothing. What next?
Regarding a Bosch built in dishwasher SHV46C03OC/14 The upper arm is not spinning. I have cleaned the unit by hand, filters, arms and with CLR (chlorine, rust and lime cleaner) as suggested by Bosch. The bottom dishes come clean but the top is not. I have checked the water level after it fills and it seems like it is only near the filter on the bottom. Is this normal water level because of the type of circulating system of this unit? Is this a water pressure problem? --and dur to what - the switch goin off early or the cir pump. I am reading too much about this machine on these blogs. I did notice that the detergent cup stays half filled. Is this due to the water not hitting it or the mineral deposits from our well water? Please help Thanks
-   How can I confirm it is the motor which is bad vs. the control pannel? I just do not want to start buying parts only to find out that something else was root cause. -   saleivan
Jul 08, 2008
-   my jenn air built in dishwasher gets no water during the wash cycle-   Guest
Need a new dishwasher. Don't need all the bells and whistles, just good cleaning capabilities;...
(More)
Need a new dishwasher. Don't need all the bells and whistles, just good cleaning capabilities; regular and heavy duty wash cycles, hot air dry. Quiet not a factor if it means a smaller motor than usual.
Any decent frigidaire dishwashers out there? Ours has been one problem after the other and just...
(More)
Any decent frigidaire dishwashers out there? Ours has been one problem after the other and just went out of warranty, now the control board is burning out. The best they will do is give us a rebate on a new unit. I say are you crazy? But maybe theree are a few models out there w/out these troubles, dependable and that get the dishes actually dry!
since movin home dishwasher hasnt worked, flashed different times, water is going in and is hot but...
(More)
since movin home dishwasher hasnt worked, flashed different times, water is going in and is hot but the arms dont swing round and now i cant even run the diagnostic programme. It was a gift from my Dad just over 1 year ago Whirpool ADP4501/5
HI. During the eco-cycle wash,the first and second wash cycle lights from the left are flashing....
(More)
HI. During the eco-cycle wash,the first and second wash cycle lights from the left are flashing. What does this mean? Thankyou.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
