Error code on air conditioner e1 - Heating & Cooling
  • 1 more comment
  • Anonymous Jul 25, 2008
    I've been getting an E1 error code too.
  • christina_va Aug 11, 2008
    i have the ei1 code on my ac. i don't know what it means. i've cleaned the filter and reset it.
  • lmhenthorn Oct 07, 2008
    Mine does the same thing... the filter is completely clean but it turns off after about ten minutes of usage every time with the E1 code.
  • 3 Answers
Search for this problem on web or contact Sharp Technical Support for the following procedure:
1. Unplug unit.
2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off.
3. Release power button and unplug.
4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Posted on Jun 30, 2009
Error code e2 on a model acw126v how th correct
Posted on Aug 23, 2010
Sharp inverter Air conditione.
After approx 20/30mins the system shuts down and shows a 6 on the display.
Any ideas.
Has been service
Posted on Jun 11, 2008
SOURCE: reset air conditioner
This did it for me! Same procedure but its described a little more thoroughly here...
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Posted on Jul 21, 2008
sgregg
  • 133 Answers
SOURCE: Problem with samsung aw0503b
Found this on Samsungs site.Hope it helps a little, at least you know the problem now. If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced. If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced. To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have the model number of your air conditioner on hand when you call.
Posted on Aug 02, 2007
  • 143 Answers
SOURCE: AIR CONDITIONER MODEL #AF-S85FX--CODE E1
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
(Don't you just love having a computer chip in every appliance?)
Posted on Jul 25, 2008
6ylucy
  • 742 Answers
SOURCE: boston innovative products MOB 10KDCHR portable
i found the user manual for it at:
manualfox.com/link/bostoninnovative.htm
Posted on Feb 13, 2010
SOURCE: error code E1 54 on samsung air conditioner split
A Bit of a late reply but E1 54, is indoor fan fault.
Posted on Feb 09, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
My air conditioner showing on the display is E1
The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
How to Fix an Air Conditioner When It Gives You an E1 Code eHow
Jan 24, 2016 | Heating & Cooling
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
Comfort Control Center 2. Why is E-1 error displayed?
[PDF]Customer assistance for air filters cleaning (E1 code)
www.sharpusa.com/.../air_man_AFS100FX_S120FX_S125F...
Sharp SolarCustomer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners. The display will indicate an E1 code and not allow the unit to operate until the ...
Sep 08, 2015 | Dometic Rooftop RV Air Conditioner
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
My air conditioner want turn on or anthing and it shows e1, whats this mean
The E1 code is an error code that appears on the LED temperature display of some digital air conditioners. The error code could mean anything from dirty air filters to a damaged room thermistor, a safety connected to your thermostat that detects room temperature. Troubleshooting the cause of this error code may improve your air conditioner's performance
Sep 15, 2013 | Haier HWR06XC7 Air Conditioner
Heating & Cooling Logo
3,384 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
