Question about WYSE WT8360SE 96MB (901996-22) Network Terminal
How do I configure a Wyse WT8360SE
I purchased a working WT8360SE Winterm. It boots, and keyboard, mouse and network work fine. I can see it gets an IP from my network (BOOTP/DHCP), but I cannot figure how to point it to my RDP based Terminal Server. There must be a way to configure:
Device Name
Terminal Server address?
Fixed IP?
I saw one post about configuring a DHCP setting to tell it where to get the config file, but I use an appliance to dish out DHCP settings, so cannot configure DHCP setttings. Can someone help? There are a lot of these units on the open market. There must be manuals somewhere? Please let me know. Thank you.
Eric H.
5 Suggested Answers
  • 42 Answers
SOURCE: Howto add a network printer on Wyse winterm S30 terminal?
The S30 terminal has the CE 5.0 operating system loaded as default. So you are limited by the operating system and not the hardware when it comes to network printing.
Here is a extract of the release notes for Windows CE 5.0:
"In Windows CE, TCP/IP supports network printing through the Server Message Block (SMB) protocol. It does not provide the Windows Line Printer Remote (LPR) Spooler. However, independent software vendors (ISVs) and original equipment manufacturers (OEMs) can add this support."
In short, you need a 3rd party software program or a (SMB) printer server setup to setup network printing on the S30 terminal..
Wyse also have add-on software to help, if you have CE 5.0 loaded then try the "Thinprint" add-on supplied as a free download by them.
Download Link:
I haven't tried this, so let me know if it works.
Posted on May 07, 2008
SOURCE: wyse winterm sx0
Reprogram EEPROM
Posted on Aug 26, 2008
  • 25 Answers
SOURCE: I have Wyse V50L termimals
Have you tried the latest V50L firmware version? There was a major revision lately?
Posted on Dec 18, 2008
SOURCE: Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Posted on Oct 07, 2009
Does the wyse sxo have a speaker
No, I do not believe the "S" series (S10, S30, S50 & S90) have any speakers.
Mar 01, 2013 | WYSE Winterm S30 Network Terminal
I am trying touse a Mouse and Keyboard, by PS2 to USB adpators. When the machine boots up, I get this alert: "Hit Control, ALT Del to stabilze the system." The mouse or the keyboard does not work.
Do not work. No telling what's wrong with the thing without checking the connections with an eye to ruined PS/2 ports out back (though it's possible the interface chips are fallen victim to ESD (static, say).)
Cleaning might fix it, or might not.
It's ancient, please don't use that kind of technology on the web at large instead of well behind school or company firewalls.
Feb 14, 2010 | WYSE Winterm 3235LE (90202401R) PC Desktop
Orange Light, Will not boot When Powering on Wyse WT325LE
go on line and type in the following information:
motherboard manufacture, nake, model, and orange light comes on
see if anyone else had that same problems
Feb 06, 2009 | WYSE WT3235LE (902032-68) Network Terminal
WYSE 3235 thin client needs bios flashed
The easiest way to would be to take apart the machine so that the motherboard is exposed. Once you do, you will see a small, circular watch-like battery. Remove this for about 15-30 seconds. By doing so, it will perform a hard restart when the BIOS memory is cleared and you will have your original factory settings. If this does not work, consider the ports/card for the peripherals. Perhaps it is a hardware problem.
Dec 01, 2008 | WYSE Winterm 3235LE (90202401R) PC Desktop
I have a WYSE 3235LE thin client in a Sears retail environment. I need to reset the bios. There is a way to flash it from another terminal but the bad box won't boot. It stops with keyboard/mouse error....
The best solution for resetting the bios is to do a hard restart. This requires you to get to the motherboard and take out the battery for about 15-30 seconds before replacing it. By doing so, the temporary memory in the BIOS is erased and you will have you factory settings.
Wyse 3150 terminal - yellow light
Does it boot into BIOS if you hold down Delete while powering up the terminal?
Sep 03, 2008 | WYSE Winterm 3150SE Network Terminal
Reconfigure winterm
try holding down the 'g' key when booting -this just worked for me.
Aug 11, 2008 | WYSE Winterm 3150SE Network Terminal
Getting connected
Build a Windows server with DHCP and DNS and install Terminal Services. Open config on the winterms and setup the RDP client. Follow the prompts, it's pretty straight forward.
Term Service requires license after 90 days AFAIK, so you better have a plan by then.
Thats the easiest way to setup and connect, it is a far from complete solution, though.
I would suggest you google upgrading the winterm firmware using FTP, the older firmware is poor and slow.
Otherwise, these are great little termianls that will last forever and work well.
Mar 17, 2008 | WYSE Winterm 3350SE Network Terminal
Open Questions:
See all WYSE WT8360SE 96MB (901996-22) Network Terminal Questions
WYSE WT8360SE 96MB (901996-22) Network Terminal Logo
202 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
