Question about RIM BlackBerry 7130c Smartphone
BATTERY I JUST BOUGHT A BATTERY ONLINE AND THE COMPANY SAID I PROBABLY HAD TO HARD OR SOFT RESET MY PHONE TO ACCEPT THE BATTERY, HOW DO I DO THAT
  • Kay m Jan 16, 2009
    I can't turn my new blackberry 71 30 on??? when I put the charger in it shows the baterry and a slash over it, but when I put the baterry in it the power goes off. Please help me
    Problem Solver:
  • 6 Answers
Performing a SOFT reset on the BlackBerry device Performing a soft reset stops all applications on the BlackBerrydevice by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. A soft resetre-establishes communication between the BlackBerry device and thecomputer.
Note: This does not apply to the BlackBerry® Pearl™ smartphone.
Performing a DOUBLE-SOFT reset on the BlackBerry device Performing a double-soft reset stops all applications on theBlackBerry device and is nearly the equivalent of a hard reset. Timinghowever is critical. Perform a soft reset by pressing the ALT+RIGHTSHIFT(CAP)+DELETE keys. The screen will go blank. When the screen is nolonger black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. Youshould then see another blank screen followed by an hour glass.
Performing a HARD reset on the BlackBerry device The first step in troubleshooting a network, software or hardware error is often to perform a hard reset. With Java® based devices, thisis accomplished by removing the battery, while the BlackBerry device ispowered on. Hold the battery out for about 30 seconds, and replace. TheBlackBerry device will reboot.
Note: A hard reset on a C++ based device is accomplished by pressing the Reset button.
Note: To perform a hard reset on a RIM models 850, 857, 950,or 957 device, insert the end of a paperclip inside the small hole onthe back of the handheld.
Posted on May 24, 2009
    Scholar:
  • 60 Answers
A hard reset on a Blackberry smart phone is removing the battery and replacing it.
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB02141&sliceId=SAL_Public&dialogID=142182781&stateId=0%200%2067125002
Reasons to perform a hard reset (none of which has to do with the battery - sounds like a bad battrery to me).
Posted on Jun 09, 2008
Tip
How To Soft Reset, Hard Reset, and Factory Reset Your LG Quantum
If you are uncomfortable with resetting your phone, or unsuccessful in fixing the problem, please contact the phone company for which you receive service from for help with resolving your issues.
Soft reset
To perform a soft reset, power the device off and back on.
  1. With the screen unlocked, press and hold the Power key to turn the phone off.
  2. When the phone is off, press the Power key to turn on the phone.
Hard reset
  1. To perform a hard reset, remove and re-insert the battery.
  2. Press the Power key to turn on the phone.
Master reset
IMPORTANT: The device will be set back to factory settings; all data stored on the device will be lost. The device may not be functional for up to 15 minutes after a master reset is performed.
  1. From the home screen, swipe left to expose your app list
  2. Tap Settings
  3. Scroll down and tap about
  4. Tap reset your phone
  5. Tap yes to confirm, then tap yes to confirm again
That's it! Your LG Quantum will now be wiped. It will then reboot and you'll be left with a factory fresh phone.
on Feb 10, 2011 | Cell Phones
How do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Apr 15, 2015 | Coby kyros Tablets & eReaders
What is the unlocking code for a Kyocera Hydro Life..model #6035?
Resetting the phone If the phone does not respond to taps or key presses with the flip either
open or closed, you may need to perform a reset.
There are two types of resets-soft resets and hard resets. In a soft reset,
all records and entries are saved. In a hard reset, all records and entries
are erased. If you must do a hard reset, you can restore any data that you
previously synchronized using a HotSync operation.
May be either on or off
Open
1. Turn the Kyocera smartphone over. Open
the battery door on the back of the phone.
2. Press the reset button with the stylus.
3. Replace the battery door. Turn the phone
back over and verify that it has restarted.
Feb 02, 2015 | Kyocera Cell Phones
I BOUGHT A POCKET PC VX 6700 USED I HAD MY CHANGE OF EQUIPMENT DONE BUT I CAN PROGRAM IT BECAUSE THE PHONE HAS A PERSONAL BLOCK A 4 DIGIT PASSWORD ..HOW CAN I GET AROUND IT BY THE WAY ITS A A VERIZON...
Soft Reset
1. Power off the device.
2. Locate the small reset button on the bottom of the phone.
3. Press and hold "Reset" with your stylus until the device restarts.
4. Release the button once the phone restarts. The Today screen will appear on the display.
Hard Reset
5. Press and hold both soft keys.
6. Press and hold "Reset" with the stylus while still holding both soft keys.
7. Press the "Y" when the prompt appears to initiate the hard reset.
Feb 19, 2011 | Cell Phones
My lg quantum is giving a a message:"retry again
Soft reset
  1. With the screen unlocked, from the top panel, press and hold the Power key to turn on the phone off.
  2. When the phone is off, press the Power key to turn on the phone. press and hold the Power key to turn on the phone off.
Hard reset
Master reset
  2. Tap Settings
Feb 10, 2011 | LG Quantum (16 GB) Smartphone
My G1 screen goes blank when i close it
First try SOFT RESET
1) Turn Off the Phone
2) Remove Battery
3) Remove Sim Card
4) Put battery and sim card again
5) Turn On the phone
6) Press Menu
7) Factory Data Reset (Remember that: This action will reset the phone to its initial factory state, erasing all data and wonloaded applications, so BACKUP BACKUP BACKUP first you try this).
Press "reset phone"
IF STILL NOT WORKING TRY:HARD RESET
1) Turn off the Phone
2) Press HOME + POWER KEYS (keep them holding for about 25 secs)
until you see a screen with a phone and a triangle.
then
3) SLIDE YOUR KEYBOARD TO OPEN IT
4) press ALT + l ( TO SHOW YOU OPTIONS)
5) Press ALT + W ( TO FORMAT ALL DATA)
Note: When I write the sign + you don't have to press the + sign, it means that you need to press both keys @ the same time.
May 03, 2010 | HTC G1
HTC PPC-6800 Smartphone errors
Okay take out battery and put phone on charger .. then try a hard reset . and then go to a soft reset. after that put battery back on and soft retset and see if it works .
Jul 04, 2008 | HTC PPC-6800 Smartphone
Touch screen not working
You Will need to Hard reset the phone but make sure you back up your info first, because a hard reset will delete all info. To Hard reset the phone hold the two Soft keys which of Dots on them and then while holding those buttons press the reset button located on the bottom of the phone by the Charging port.
Mar 20, 2008 | Sprint Vision PPC-6700 Smartphone
PTT SCREEN HAS UNABLE TO ADD CONTACT MESSAGE:
I had this problem and we needed to contact our cellular company to verify settings. After some time looking into the problem they said it was a hardware malfunction and swapped phones for us. I think there must be a solution to this problem that the cell representatives did not know about.
Oct 22, 2007 | Motorola Mobility V365 Cellular Phone
RIM BlackBerry 7130c Smartphone Logo
554 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
