I560 printer prints a colored line across the top of photos.
  • breadick Jun 09, 2008
    canon
  • breadick Jul 10, 2008
    It appears to be a paper feed problem. The feed slows way down near the end of the paper and than speeds up again, but not as fast as before.
  • This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side.
You can also try turning up the printer's contrast adjustment, if it has such a knob. Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If this does not work, you need to clean heads manually replace the print head.
For more
Shop Easy 3D Printing
Posted on Apr 18, 2016
  • 983 Answers
Printing not dark enough or varied in darkness
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
Posted on Jul 08, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 08, 2008
    Now that you are familiar with the printing process, you can probably
    guess some of the common problems and their causes even before I explain
    them. The best way to determine the cause is to identify at what point in
    the process the printer is breaking down.
    Loose or smeared toner
    Here’s an easy one. If the toner is loose (that is, not fused to the
    paper), the fuser is not melting the toner, and thus the toner is not
    fusing with the paper. Make sure the fuser is heating; if not, replace it.
    Similarly, smeared toner happens because the nonstick coating on the
    fusing roller is scratched or has baked-on debris. You can try to clean it
    with a soft cloth and alcohol, but make sure you let it cool down first!
    Note
    In this
    article, I recommend replacing certain parts, but unless you are
    a technician working for an authorized service center for that
    type of printer, you might not be able to get the needed parts
    easily.
    Smeared output can also result when you refeed a printed page into the
    printer to make a double-sided page. This happens because the rubber
    rollers that grip the paper to pull it into the printer can pick up toner
    from the first side’s printing and smear it.
    Vertical
    white areas
    To fix this problem, clean the corona wires. Why? This problem is
    caused by either the main corona or the transfer corona being covered with
    toner in a certain spot. A quick fix is to change the toner cartridge,
    even if it isn’t empty. Because the primary corona is located in the
    cartridge, this will correct problems with a dirty primary corona.
    To clean corona wires, use a special felt-lined tool that comes with your
    printer or use an alcohol-dipped cotton swab. But be very careful! Corona
    wires are thin and easy to break with too much pressure. To locate the
    primary corona, remove the toner cartridge and look for an exposed wire.
    The transfer corona’s location depends on the printer, but it is usually
    protected with a webbing of filament threads. Not all laser printers allow
    you access to the transfer corona, so check your manual if you can’t
    find it.
    Gray mist
    If the white areas look like they have been lightly sprayed with a
    gray mist, making them look slightly dirty or dingy, the problem is also
    likely to be a dirty corona wire. (See the preceding section.)
    This can also be the result of turning the printer’s print density
    control up too high. The newer the drum, the lower this setting can be. As
    the drum ages, you must turn up the print density control higher to
    achieve sharp black printouts. However, if you turn it up too high, the
    entire page acquires a dirty gray tinge. Some printers include the drum in
    the toner cartridge, so you get a new one each time you change toner. On
    other printers, the drum is separate, and you must eventually replace it
    when it wears out.
    Master:
  • 788 Answers
  • 19,396 Answers
Try first performing the head/nozzle cleaning procedure a couple of time, if this does not work, you need to clean heads manually replace the print head.
    Master:
  • 555 Answers
Who is the maker of your printer?
Posted on Jun 09, 2008
Hp 8500-printing yellow lines across photo prints
I have an HP 8500 printer. When printing photos it prints lines spaced 1" apart accross the entire photo?
Dan
Oct 31, 2009 | HP LaserJet 8500 Color Printer
Lines appearing across printed photographs
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Printing lines across the picture
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Q: How can I tell if the computer or the printer is causing a print quality problem? A: You can print a nozzle check pattern to determine whether the print quality problem is caused by the Epson Stylus Photo RX680 Series or some other source.
Above under FAQ
Dec 10, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
Printer is Not using all the colors when printing?
if you download the ssc you can do a power clean if you dont have this tool let me no
Nov 16, 2008 | Epson Stylus CX9400 Photo Printer
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Canon I560s printer
Was this the problem prior to changine the cartriages? If not check the contacts between the machine and the cartriges. there may be tape, ink, papaer in between.
Jul 03, 2008 | Canon BubbleJet i560 InkJet Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Ink cartridges wont print
same problem!!!!! temping to get another printer - help!!!
Dec 19, 2007 | Canon BubbleJet i560 InkJet Printer
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Canon i560 --No color!
see you removed the seal of catridge nozzel like stiker of catridge and also check whethre your pring mode is color not a grayscal. bye
Sep 03, 2007 | Canon BubbleJet i560 InkJet Printer
122 people viewed this question
jasbo
jasbo
