Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
Whirlpool ADP 9520
Unfortunately my washing machine water ended up inside my dishwasher via a blocked drain etc - now the start light just blinks and will not start - have tried flushing out salt container and adding new salt but even by holding in the start button it just goes through the start up cycle and then carries on blinking - have tried doing this on each cycle but still no joy - help please before war breaks out or even worse I have to get my hands wet!
  • tweedy1 Jun 23, 2008
    the same problem the drain blocked, firstly the machine filled and overflowed, now it fills and empties but does not wash and the light keeps flashing
Press the start button (which is flashing) for a few seconds and it should start again?
Posted on Aug 20, 2008
How to reset Whirlpool dishwasher ADP 6342; it stopped working and cancel button is blinking 8 times
F8 failure (slow/no draining)
In a consumer cycle, the appliance is indicating F8 E1 (slow/no draining). This is because of wrong signals from the circulation pump read by the control board and interpreted as "water present", when there is no water. During draining (and in fact, there is no water), the failure occurs.
1. Check if drain hose is not closed/clogged
2. Drain pump faulty, harness or wiring faulty, control board faulty
3. If machine is equipped with OWl, issue might be caused by damaged or dirty OWl. Clean the sensor lenses then , if issue is not solved, replace OWI (optical water indicator).
Jun 14, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool adp 2415
try turning off the power to the dishwasher for about 20mins then turn the power back on. sometimes this will reset the unit
May 21, 2014 | Whirlpool Dishwashers
Whirlpool ADP 9620 dishwasher not working?
Is the machine still full of water? did it drain by itself?
if not, may be a blockage in the drain pump or circulating pump. Can you hear the pumps running when on drain at the start of the program? The machine will not start unless it is fully empty, as it follows a logical series of steps, and recognises when something is wrong - ie full when it should be empty, etc.
Check the drain pump, pump impeller for foreign bodies, and waste hose, the fill hoses and if you haven't done this already.
If not this it may be control pcb, motor or heater faults - but check basic issues first
Feb 02, 2018 | Dishwashers
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Dishwashing machine whirlpool electronic control ADP 4520
Check the Water Indicator (WI).
When you think it should be enough water, unplug WI connector from control board and check if on WI connector is closed contact (WI written on the control board housing). If not, try with some more water. And so on. When too much water with no contact on WI, it is the one to be replaced by new one.
NOTE: by every check UNPLUG the machine
Jan 03, 2010 | Electrolux Dishwashers
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
Whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Start light flashing
start light on and no other action could mean that the door catch has gone faulty, test accordingly and replace if needed, no wash cycle will work if this item is faulty, the waste outlet pump may be the only part that will work on some models, this is a safety feature hope i have helped if so please rate me, work safe unplug when testing
Sep 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
530 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
