Question about Disteck P4204TWHD Television
Tv wont' powerup...
I attempted to plug speakers into the back of the panel while the TV was on. It all of a sudden went blank.. can you help me or offer a possible problem to what may have happened..
  • 7 more comments
  • Disteck Tele Jun 17, 2008
    i attempted to plug speakers into the back of the panel while the TV was on. It all of a sudden went blank.. can you help me or offer a possible problem to what may have happened..
    Hi there.. i got the response.. that doesn't work.. it appears the audio module is out in the tv..
    How do I find the details to contact the Manufacturer... ???
    so i tried to plug some "additional" speakers (other than the speakers that came with the tv). the tv went blank... repair man says the audio module needs replacing... i need to know where to find the part. can you tell us where we can find the part..
    May i chat with you to get the telephone number to the Disteck manufacturer or where i may get the part for replacement.
    i know.. i'm trying to find teh replacement part. tv repairman is not able to find a part.
    would you happen to have the replacement part for the whole module board.
  • RahulNXG
    RahulNXG Jun 27, 2016
    power board
    Novelist:
  • 97 Answers
Hi Distech Tele!
There is very little information available on the your widescreen high-def plasma TV. This makes a specific solution difficult if impossible, but I'll give you my best impressions and directions, despite the limitations.
I suspect that you have blown the audio amplifier chip, and it is highly unlikely that this blown chip will present itself by any visible evidence(i.e.: There will not be any burnt, smoking, hot or discolored parts - everything will appear normal..
To locate this chip, locate the speaker jack where you plugged in the speakers, and carefully trace the circuit land from the center conductors of these RCA Phono jacks back to the (hopefully) Audio Amplifier chip. You might have to trace through a low resistance current limiting resistor, but you should be able to locate that chip.
Ascertain the manufacturer and part number for that chip (note ALL the numbers printed on the chip), and try to locate a replacement chip online. If need be, I can assist you with that if you like, just post a free question to me (look for the "Ask" link under my avatar).
Sometimes chip failures daisy-chain (like falling dominos) back upstream through the circuits, especially in the event of static discharge, dependent upon how well the designers provided isolation protection in their design. A good way to check for this is via the alternative audio outs (line outs). Line out levels are high enough to power a pair of headphones/earphone, so if you can rig up adapters from the RCA Phono jack line outs to the stereo mini-jack of some headphones, you can verify that the damage did not go further upstream.
This might also provide you with an alternative "fix" by routing these line outs to a stereo or jambox with a line in input, and running your TV sound through that. This was always my preferred audio set-up because of the superior rproduction... and if the line outs are functional, then the introduction of a home theater system is another possible way to go in order to regain TV sound function.
I know you probably have a considerable investment in your plasma HDTV, and I can imagine the stream of expletives that came when the sound blew (I'd be cussin' like a sailor!!!), but if the set is stil warrantied, it still might be possible to have it repaied or replaced under warranty if you minimize your culpability. Were there any clearly posted warnings not to plug in speakers with power on? If not, you still have a warranty claim --- it is quite easy to design in isolation protection in these circuits to prevent this type of failure, but it would entail the added components and added expense, and these considerations lead manufacturers away from the more reliable design in their quest for better profit margins and price competitiveness.
Distek, I hope this is illuminating AND helpful, I wish you well in this endeavor - good luck! - and do not hesitate to contact us if you have further questions or comments!
Thanks-
-WildBill
Posted on Jun 17, 2008
  • Bill Bellomy
    Bill Bellomy Jun 17, 2008
    Disteck Tele-
    Check out http://disteck.en.ec21.com/ for addtional information.
    -WildBill
  • Bill Bellomy
    Disteck Tele-
    Have you got the set back to picture/no sound functionality yet?
    -WildBill
    Genius:
  • 1,665 Answers
Check for any fuse blown
  • 1,879 Answers
Hope this helps
Disteck International
[USA] Address:
3660 Wilshire Blvd. Suite 820 Los Angeles CA 90010 USA Phone:
1-213-2529393 Contact name:
Robin Lee, Assistant Manager
    Genius:
  • 2,028 Answers
Here's a link to contact info for Disteck.
http://www.electrobase.com/app/mi194/nimfr/wsall_____all
  • Ryan Rogers
    Ryan Rogers Jun 17, 2008
    Give your repairman the contact info we provided. It's his job to provide the parts, not yours. He's not much of a repairman if he can't provide parts for the repair.
    Master:
  • 638 Answers
Attaching somedevice to the tv with power on condition causes this problem many times.your tv will not get on till the particular part is not replaced or repaired.try to get it repaired it will definately work properly.why going for the costly options of replacing
  • hemant somaiya
    hemant somaiya Jun 17, 2008
    one of my expert friend ohms has send u the contact information.it will help u solve ur problem i feel
    Master:
  • 788 Answers
Sounds like you shorted something out with you went to plug in speakers. Is this a CRT or a flat panel TV? Couldn't get much information on it from the web.
If it's a CRT I would have it serviced professionaly, there are high voltages at play.
If it's an LCD it is safer to open up the TV and examine the boards for burnt components. If you find the culprit you could attempt to replace the component in question or try to find a whole board for replacement.
It would be much easier to replace the TV depending on your budget.
  • 2,323 Answers
It looks like the audio amplifier integrated circuit might have become defective. Those parts could be very sensitive to sudden current spikes if you did not turn the TV OFF ro connect the speakers.
  • 4,472 Answers
What kind of speakers were you attempting to connect to this tv? What kind of connection were you using? From the looks of it you will definetly want to have this TV serviced. There are no user serviceable parts.
Thanks and if you need any further assistance please ask,
Lee
  • 6 more comments
  • Lee A.
    Lee A. Jun 17, 2008
    Target is selling these tv's under TechView as the manufacturer I would try to contact them first.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    http://www.techview.com.tw/techview/en/c...
    Here is the link to contact them.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    With a company like this alot of times it is unlikely to find replacement parts. Thats why with companies like these they are known as throw away TV's. Unfortunately the hundreds you may save off the bat will catch up with you later.
    If you need any further assistance please ask. If you find one of our solutions helpful please accept and rate it as we are all working very hard to find everyone the best solution.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    What is the part number you are looking for?
    Thanks,
    lee
  • Lee A.
    Lee A. Jun 17, 2008
    Do you know which part you need? If so I will be glad to assist you. If you would like to chat you can always click Ask Me under the Expert and then choose the chat option.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    Please let me assist you fully before you rate me negatively. I will be more then glad to answer any question you have.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    I believe all the available solutions have been provided. If you could accept one of our Experts solution it would be greatly appreciated as we are all working hard to provide you with speedy and concise solutions.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 18, 2008
    Unfortunately like i previously mentioned because of the lack of support and service by companies like this, this product is known as a throw away. It would be much more beneficial to buy a new tv that does not have old components. So that when you do fix this 2 weeks later something else doesn't break. I would recommend something Japanese. Hitachi, Sony, and Panasonic are some of my favorites. Even if they make a bad product at least you will have some support and replacement parts readily available.
    Even though this is not a happy ending I will hope you will still accept my solution and find it helpful in the least.
    If you need any further assistance please don't hesitate.
    Thanks,
    Lee
    Master:
  • 555 Answers
Turn off the TV, unplug the speakers, and turn the TV back on.
  • 13,433 Answers
Unplug everything for a moment then only plug in the power and try again.
  • Ekse Jun 17, 2008
    check your user manual for contact information.
My 2006 manufactured Viore flat screen plasma tv suddenly went blank. Still have sound. Please help!
Read the following:
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
Different TV, but most likely same problem and, in fact, quite possibly literally the same boards, so maybe practically the same TV.
Can't be sure since you haven't posted the model of your Viore.
If you have specific questions, please always include the model number in the question...the model is on a sticker at the back of the TV, right after or below the words "MODEL:" :-)
Nov 09, 2011 | Toymax Viore 42 in. Plasma TV
Got a 21 inch promac tv, suddenly screen went blank, tried switching it back on but it didn't came back.
accidentally adjust the color,sharpness,and brightness how can get back the standard color display in my tv. or what is the exact number of display? help me pls
Apr 16, 2011 | Televison & Video
I was watching a dvd on my week-old Sony Bravia XBR-52HX909 for the past three hours when the screen suddenly went blank. The standby indicator light in red started blinking. I attempted to turn on the...
This tv only a week olds,should never having this problems already.The tv should be return and get a new tv for the replacement,this tv have tv Tuner signal board or tv power supply board distrubution problems.Even when the store test it out it work,don't take that tv back.Insit they give a new tv for the replacement.
Dec 13, 2010 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
Screen went blank but still have audio
loud pop then no picture. still has sound 50 in samsung plasma mod s50hw-yb02
Feb 24, 2010 | Samsung 50 in. Plasma TV
I was watching TV and all of a sudden the screen went blank and wont come back on. I can unplug the TV and when I plug it back up, you can hear it clicking like it wants to come on but doesnt. The light...
Hi, you failed to mmention what make and model the tv is. But it sounds to me like a Samsung from experience. If it is then you need someone to check the power supply capacitors. The ones with bulging tops are faulty and need replacing. If it isnt a samsung, still look on the power supply pcb for signs of this and you will be on the right track.
Feb 12, 2010 | Televison & Video
RCA HDTV DLP 50'' TV Goes Blank!!!
The bulb went out, The clicking is the ballast trying to start the bulb
Jul 12, 2009 | Televison & Video
We just purcased Toshiba 26AV502U, now the screen is blank
Heard back from Toshiba. They said to unplug the TV, wait at least 3 minutes, and then plug it back in. This should allow it to reset itself. Sounded too simple, but after doing just that the tv has worked fine for the last three days! Toshiba noted that if this didn't resolve the problem we should contact them to have a Toshiba Authorized service person come check out the tv. It worked for us, hopefully it'll work for you too. Good Luck
Jan 18, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Blank Screen
the power supply board has gone bad. part number
BN96-00249A
Oct 19, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Televison & Video Logo
85 people viewed this question
Top Disteck Televison & Video Experts
Electro Med Services...
Are you a Disteck Televison and Video Expert? Answer questions, earn points and help others
