Question about Linksys Wireless-G WRT54G Router
Router signal signal too weak to another room in apartment
  • Anonymous Feb 24, 2009
    no signla from this crappy router at less than 20 feet in another room
    Problem Solver:
  • 15 Answers
If there is no signal of your router,make a call of the service provider of you internet connection,they will be the one who fixed that problem and there is no money will pay for it.
Posted on Jun 18, 2008
  • 2,794 Answers
You can get a bigger antenna and attach it to the router or purchase a wireless access point.
Posted on Jun 09, 2008
    Problem Solver:
  • 8 Answers
Move out of dumpster you are in now , and get a better apartment
Posted on Jun 11, 2008
Router gives strong and weak signal in same place
If you think that your router signal is weak then you can follow the given points:
->Router positioning has an impact on the strength of a wireless signal. Brick walls and metal objects such as radiators, refrigerators and file cabinets can weaken a signal.
->Change the WiFi Channel
->Update firmware or drivers
->Reduce wireless interference
If you need any technical help on wireless router then you can reach at http://www.vtechsquad.com/
Nov 14, 2012 | Vizio Xwr100 Dual-band Hd Wireless...
Hi everyone, I have a D Link DSL 2640U wireless router.I have been facing problems with connection stability for some time...the problem is that I have to keep my laptop switched on, so that I don't loose...
An unstable connection can be caused by any number of things, especially a weak signal.
Try moving the wireless router higher location away from concrete walls and or to a central location.
To improve the wireless connection, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Dec 28, 2010 | D-Link Computers & Internet
A friends iof my gave me this router, but I don't know how to install it so that i can use it with my laptop in my living room. my internet is connect to my computer in my room. My main internet is in...
You have a few options. If you already have a router, set this one up as an Wireless Access point. It pulls signals from the main router and you can connect to this one. BUT your signal could be weak depending on the distance, walls etc. If you can make a cable run, use it as a switch. (Extend your ports, and as a wireless point. Go to Cisco Linksys and download the manual.It is not difficult. Use the main router as a your DHCP and this one as a wireless point. You will need to set up the SSID and security (Securty is optional, but I would do it). Give it a SSID different then your main one and you can setup your device to connect to the one with the strongest signal (Most do this by default.
Dec 18, 2010 | Linksys Wireless-G Broadband Router
How can I increase my WIFI range. My internet signal is very weak when I am in my bedroom. Can I increase my range by possibly buying a signal extender.
Try moving the wireless router around and or higher.
If the wireless router is in a different room and the room has concrete walls of foils insulation in the walls, this will weaken the wireless signal. AND/OR
You can connect add a antenna to your computer. Have a look at this device. Normal 0 USB High Gain Antennas www.pricewatch.com/gallery/networking/high_gain_antenna
Oct 25, 2010 | Arris SURFboard SBG900 Wireless Router...
Have a 2Wire Router from SBC that has recently been causing connection problems with my sons XBox. Low signal roughly 2 bars. Nothin has changed in the house. Have router in main bedroom, Xbox is in son's...
if signal is fading in and out there are a lot of factors. 1 have you installed an other electrical epuiment in the house? emf cause interference. 2 if you move the xbox to the same room as the router how is the signal? d3 do you have a laptop to try next to the xbox where it is at now and see the signal? if it is weak on ther laptop also get a new router.4 if the signal is good on the laptop your xbox is the problem.
Dec 30, 2009 | 2wire HomePortal 100W Router...
When I go into other rooms I can't connect to router
How is the signal strength? Check and make sure the antennas are not loose. Is your house the old style concrete? Sometimes thick block or concrete walls are tough for the wireless signal to get through. They do make larger antennas or signal boosters for wireless routers. You may need to install one of these to boost signal strength. Also is it wireless B,G,or N? Wireless B has a very weak signal while wireless N has a very strong signal. Sometimes the router settings can be changed to adjust the signal strength and may be set too low also.
Sep 05, 2009 | Linksys Wireless-G WRT54G Router
Laptop and iPhones cannot connect to my network unless they are i
hi! I will be more than glad to help u in this concern..your using a wireless n router and the n router will work with the signal properly if u are using a wireless n network adapter. If you are using a wireless g adapter then u need to use a wireless n range expander in order for the other wireless g adapter to get good signal..or try buying a antena which 9 dbi which will boost the signal from your wireless g adapter..
Aug 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless range/signal seems very weak
ok the problem is that ur using a wireless b modem
the wireless b is the shortest of the classes of wireless routers
you should go with a G or N series
this should solve ur isse
the B series is for one room operations then the signal has to go through ur home that is more resistance on the signal
you could also buy a 2wire modem /router at best buy
that covers ur whole property with ur wireless range
but u will pay the same in one router as this 2wire single unit
Apr 11, 2009 | Gateway Wireless-B Router (wbr-100)
Can't go no more than 20ft from the router with my laptop
What you can do is try changing the router's channel. Follow the steps below:
1. Open Internet Explorer and type 192.168.1.1
2. It will ask for username and password. No username and password is admin
3. Click on Wireless tab. Select Standard for Radio Band and select Channel 11 for Standard Channel. Click on Save settings.
4. Check the signal distance now
Dec 20, 2008 | Linksys Ultra RangePlus Wireless Routr...
Linksys Wireless-G WRT54G Router Logo
47 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
