Question about Canon imageRUNNER 210S Copier
Can't print We run off a network. As of here lately we can't get the server to put or keep us online. We can ping all we want and can go into the server system itself and print. If we turn the printer off and back on we go back online for juat a few mins. it will actually spool everything and print it. It remains to show online until something else is sent to the printer. We have replaced the board in the printer itself and tried setting up the printer one of our workstations but still the printer won't respond. We are out of things to try to resolve this issue. Any help would be greatly appreciated as our company really needs access to a printer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Which board did you replace ??? I'm guessing the Nic is bad. Is that what you changed?
Posted on Nov 21, 2008
Why would my Trendnet Print server TE100-P1U not be seen by all computers on the network even though it can be pinged. I can't install it on these computers even though it can be pinged
May requires software loaded on every computer - software that will create the non-std print server "port".
More expensive print servers like the HP jetdirect print server use std tcp/ip ports.
Nov 13, 2013 | Trendnet 1-Port Print Server TE100-P1U...
I've connected the Zonet PS to my Linksys router and the light on the router is green. The PS wizard does not see it from either my wired PC or wireless laptop. Is there a setting on the Linksys router I...
ZPS2102, ZPW1000, ZPS1000 :: Trouble shooting tips for finding the print server using the utility
supporting troubleshooting links
? A: Please check the connection link light.
Temporarily disable all firewalls on your system even the Windows XP firewall
(for instruction to disable XP firewall, please go to http://support.microsoft.com/kb/283673 )
Power cycle the print sever by unplug the power at the back (10 second).
The print server default IP is 192.168.5.1
Set the computer which has the print server utility installed to have an IP of 192.168.5.2
(Test ping the print server / 192.168.5.1 --
If print server is respond to ping, using web browser with the address of 192.168.5.1 will also beable to configure the print server)
Run the utility/hit the refresh button to find the print server again.
The CD has two installation methods:
1. The Auto run will run the utility.
2. By manually install the program into your system. (Browse CD to the folder: manual installation.)
It is recommended to use the 2nd method and run the PSAdmin utility from the system's programs after the installation is completed.
If it still could not find the print server, direct connect your computer to the print server using cross over cable and run the utility again to find the print server.
When it finds the print server, change the print server IP(192.168.5.1) to a unique static IP your router can accept. Put the print server back to the network, change back your computer's IP accordingly and try ping the print server with the new IP or run the utility again.
For wireless print server, it is recommended to use Ad-hoc connection from a wireless computer to connect to the print server first. (follow the Quick Installation Guide booklet that came with the box on page 8)
Jan 30, 2011 | Zonet ZPS2102 Print Server
Has network card which i can ping to but fails to
Have you installed the printer driver. If not install but do NOT plug printer in till it tells you to.
Mar 05, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I am on wireless network cannot hook up printer according to network magic it sees printer but does not print I have updated the driver
pls check the ip addreess of the print server
ping the ip address from your computer
by>start>run typr "cmd"
ping <ip address>
if you get reply.that means no problem in the connectivity
if it requset time out
check the cable of the print server
Nov 02, 2009 | Computers & Internet
Printer can not ping
is this is a print server/network printer? first off, the basics --- is the computer you are using to ping the printer on the same LAN IP as the printer (e.g. 192.168.1.x for both)? is this a wireless print server/network printer? if yes, physically connect it first to a router or switch and check if you can ping it. if you can, does it have a web interface, make sure you can access it and its wireless settings matches those of your wireless router.
Post back whatever you can come up with so I can give you more specifics
Jul 13, 2009 | Zebra (11X-7CX-XXXXX) (11X7CXXXXXX) Print...
DP-300 Print Server Access Problem
Using a print server like this, you should not need to "browse" to find the printers. See what ip address has been assigned to the printer. Once you have the ip address, open a command prompt (start -> run -> cmd) and type:
ping <insert ip address>
ex: ping 192.168.0.24
See if you can ping the printer from each of your computers. If you can, great, install the new printer by adding a "local" printer at a new TCP/IP port with the IP address of your printer. If not, then you may have some routing issues.
Are all of the printers connected to the same switch? Do you have multiple "routers" on your network acting as DHCP servers?
Hope this helps.
May 27, 2009 | D-Link DP 300 (DP-300) Print Server
My brother printer MFC-640CW has stopped taking comand to print documents from my computer, i can copy and scan, but not print . ink pads are full.
Make sure the status and configuration of the print server. Check following:
1 Make sure that the machine is powered on, is on-line and ready to print.
2 Print the Network Configuration List of the machine and check if the settings such as IP address settings
are correct for your network. The problem may be the result of mismatched or duplicate IP address.
Verify that the IP address is correctly loaded into the print server. And make sure that no other nodes on
the network have this IP address.
3 Verify that the print server is on your network as follows:
For Windows®
(1) Try pinging the print server from the host operating system command prompt with the command:
ping ipaddress
Where ipaddress is the print server IP address (note that in some instances it can take up to two
minutes for the print server to load its IP address after setting the IP address).
(2) If a successful response is received, then proceed to Windows® 98/98SE/Me Peer-to-Peer print
(LPR) troubleshooting
. Otherwise, proceed to Step 4.
4 Reset the print server back to the default factory settings and try from the initial setup again. For
information how to reset to the default factory settings, see Restoring the network settings to factory in the manual.
Jul 01, 2008 | Brother Office Equipment & Supplies
I can not print when I connect to my jetdirect print server.
Hi, sorry for late answer, I have been offline for a while.
Connect RJ45 to router and parallel to computer
You need to download Software here first selecting 300x and windows version.
Then you can use the HP JetDirect Wireless Setup Wizard
to setup your printer on network.
You may also be required to install printer drivers, to do this use printer CD or download them from the Internet.
Regards
May 01, 2008 | HP JetDirect Print Server
High Ping When playing Battlefield 2142 Online
There are a lot of factors that can affect ping rates. Server location, server load, local internet load, and your computer and network setup. The server you access for Battlefield may be too far from you. Try typing "ping 69.147.114.210", at the command prompt,(usually found in "All Programs/Accessories") also without the quotes. You should get numbers in the 40-60ms range. (thats Yahoo.com by the way), then put in the IP number of the Battlefield server. Any returned numbers under 100ms are ok, if your getting higher numbers, check the Battlefield forums to see if there is a server closer to where your located. If your getting numbers over 250-300ms at both sites, then download Lavasofts Adaware SE which is free, and Spybot Search & Destroy, also free and run them both, (once a week after as well) they will remove spyware and adware from your computer. There is a possibility that spyware or adware is using network resources.
Aug 11, 2007 | ASUS V8420/TD Graphic Card
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
Canon imageRUNNER 210S Copier Logo
46 people viewed this question
old marine
old marine
