Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60PP9202/17F Projection Television
Need ideas on how to troubleshoot low voltage in a circuit. Have service manual. Low voltage is on yoke coil. Reads 130V,manual says is supposed to be 148V. This is causing a green bleed to the right of highlighted areas on images. Ive read articles stating a cause is low volt on yoke. Can I email you schematic for advice? Thanks
  • mopower74 Jun 09, 2008
    Do you have an address for me to send the schematic? Its pdf format. Maybe you could shed some light, all three yokes are having low voltage. This tv is a 2004 model.
  • 3,037 Answers
How old is this tv?
Projection tvs are all basically the same. Most likely it is the coil unless you can find a short somewhere else in the power supply. The coils tend to go after so much use. If you still want to email the schematic, let me know but I think you are right with thinking that it is the coil and it will need to be replaced.
Let me know if you have any further questions as I would be more than happy to answer them for you
Posted on Jun 09, 2008
  • Benjamin Patri
    Benjamin Patri Jun 09, 2008
    bestdarntootingood@yahoo.com, I'll have a look at it and will get back to you when I can
How to reset the yokes on my 51pw9363/17f
Hmm...You need to be carefull when adjusting them...if can realy throw the convergene off. To adjust get the service manual first...it has a section on the yokes...
Feb 17, 2013 | Philips 51PW9363 51" Rear Projection...
Mitsubushi VS-5043 Rear Projection,,, Replaced 3 Converrence IC's. Recovered green color. Red color is bowed. Cannot move red crosshais in convergence set up. Is their a way to reset? Could something else...
There are a few low value 1-watt flameproof resistors in the convergence yoke circuits. They typically range from 1 to 3 ohms. An open resistor will cause the respective color to be non-responsive. Also chack that you have the convergence yokes re-connected to the correct connectors on the board.
Nov 10, 2009 | Mitsubishi VS-5043 50" Rear Projection...
My 51' hitachi hdtv television make a clicking noice when on
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 24, 2009 | Hitachi 57F500 57" Rear Projection...
No sound.
thank u!!!
rate me
Jul 02, 2009 | LG 62SX4D 62" Television
Philips Magnavox Rear Projection 51mp392h convergence resistors
This means you do have some bad resistors low ohms 2.7 most of the time its only 2 of them depends on how long you played set before replacing STKs .
Oct 27, 2008 | Philips Magnavox 51MP392H Rear Projection...
Samsung HC-P4752W No power
Have you tried unplugging the convergence yokes and then try powering up the set? Its not uncommon for that chassis to shut the set down when the ICs are bad.
Jul 04, 2008 | Samsung HCL4715W 47" Rear Projection...
Need help with projection tv
usually the low voltages are attributed to a capacitor that is not performing right under load. however the only way to diagnose the capacitors is in circuit with an ESR meter, those are very exspensive unless you purchase a kit and put it together yourself. I know the following link has the ESR meter kit that needs to be assembled for a reasonable price. You may want to consider getting one, the other alternative is buying a capacitance meter and removing each capacitor from circuit and checking them. here is the link that may be your best bet they do offer free tech support as well.
http://servicemanuals.vstore.ca/
Apr 22, 2008 | Philips 60PP9202 60" Rear Projection...
Toshiba projection television
If setting the convergence in the menu doesn't help it's most likely the convergence amps. Your set takes two STK394-250A Sanyo built amps at Q751 & Q752 Toshiba p/n# 23135048. Also check, or have checked, the low ohm resistors in that circuit referred to as the yoke return resistors.
Bill
Dec 01, 2007 | Toshiba 51H84 51" Rear Projection...
Flashing LED on front panel
The place is call wwww.servicemanuals.net ,you can get it download or a paper copy,for this set I dont know the price but it will give it to you when you put the model number.Check for shorted horizontal output and loose conections,sometimes intermitant conection damage this transistor.Be careful
Oct 04, 2006 | Toshiba 57H81 57" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
