Question about ASUS P4S533-VM (P4S533-VM/L) Motherboard
PC powering off
I suspect my PC is overheating, I see the hose on my liquid cooling has a large bubble in it. There is no blue fluid in it. My PC will ruin for a few minutes then stop, I was on the bios screen in tools and the temp was up to 71C. Then it just turned off.
  • DOnIn Jun 10, 2008
    I have a coolermaster aquagate viva RL-M4A-E7E1-GP, how do I add liquid to it and what liquid do I use?
  • 114 Answers
You probably have a setting in the BIOS for the PC to shut off when the processor reaches 70C, you can disable that, but it can get hotter and hotter till the CPU melts. So try putting some more liquid in the PC.
Posted on Jun 09, 2008
How do I check for a blown head gasket on my 1990
Pretty much same answer as I gave for 87 Reliant see below. Shops have equipment to do cylinder leakage test. Do basic stuff below before doing last test ...cylinder leakage...which costs $$$.
Main point you are losing antifreeze/water. Check to see if you have water on the dipstick mixed in with oil. If so...probably a head gasket. If oil looks normal..... Before you do any test, tighten every hose connection. Check for loose connection into antifreeze reservoir. Sometimes there are small cracks on top which lets out pressure from cooling system. Look for leaks on water pump and radiator. Look at spot where you park the car...any liquid on floor? Not sure?..Put piece of cardboard under car to see if liquid is dripping from car. No leaks?...Start with a pressure test of the system. The pressure test is simply equipment that replace the radiator cap, a hand pump connected to it then air is pumped into cooling system. You watch the gauge to see if pressure is dropping. If pressure does not drop ..problem is most like a worn radiator pressure cap or stuck thermostat.. Do not buy the kind with button on cap to push down and release pressure. get original type and correct pressure. If overheating still, thermostat could be stuck, replace. Overheating of engine causes vapor lock, bubbles in fuel, which causes car to stall and kill. When cools off, fuel cools down and fuel will flow through fuel system again. Large amount of oil disappearing with overheating also sounds like head gasket or cracked head....Tighten up all bolts to gaskets, look for oil leaks on garage floor or driveway. If engine has developed a miss when running, pull plugs out and look for wet fouled plug. If antifreeze leaking into cylinder...plug tip will be whitish, if oil leaking into cylinder, grimey oil fouled. Do compression test on cylinder that is fouled and that will pinpoint if bad head gasket or cracked head. When doing compression test, radiator cap is removed and you listen to hear bubbles in radiator from the cylinder leaking into cooling system. 87 Reliant not worth pulling engine apart if head gasket or cracked head. Best oil treatment to reduce oil consumption is "Engine Restore" Used on my 58 Impala 348 tri power for 28 years. If I did not add it after oil changes it used oil and smoked....I swear by it for ANY engine after 100,000 miles.
Oct 19, 2014 | Cars & Trucks
2001 Honda Deauville NTV 650 coolant overheating
Hi, Diamonddiabl and the usual suspects are:
1. Low coolant level.
2. Restricted radiator air flow.
3. Faulty thermostat.
4. Coolant pump or fans inoperative.
5. Vent hose crimped.
6. Air in the coolant and needs bleeding.
7. Engine idling too long or bike moving too slow.
8. Coolant too old needs to be replaced.
9. Faulty temperature sensor, wiring or connector.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
5 COOLING SYSTEM
Overheating Issues Coolant dumping
HONDA NT650V DEAUVILLE BIKE WORKSHOP SERVICE REPAIR MANUAL Download... $15
https://www.partsfish.com/page/oem-parts-for-honda
HONDA NT700V Owner Manual
Jul 11, 2012 | 2001 Honda Deauville NTV 650
Just replaced my water pump but my car is overheating. could the water pump be defective?
I would say that is possible, but unlikely, if you just put on new one, this could be most likely your thermostat is stuck or just plain bad. If it is over heating instantly, and your sure your water pump is operating correctly, then it could be the thermostat.
Jun 13, 2011 | BMW 323 Cars & Trucks
Hi John here PA, I have a 1997 BMW 740il with overheating problems, about 3-4 months ago I blew a upper radiator hose, until then, except for topping off the coolant level every so often everything was...
Best test,,NAPA sells a combustion leak tester(balkamp #700-1006) A tube of liquid that will change color if combustion gas is in the cooling system.Thinking you may be right about a head gasket problem or possibly a crack in the head.
It comes with instructions and is cheaper than having a shop guess at the trouble.
Apr 18, 2011 | 1997 BMW 7 Series
My jeep is overheating off and on what could the problem be the coolant bubbles in the filling resovur
you may have head gasket issues. Have a shop do a Block Check. They will use a blue fluid to test for combustion gases in the cooling system, if present, the fluid turns yellow and you have head gasket problems.
Sep 01, 2010 | Jeep Liberty Cars & Trucks
1990 Subaru Legacy with an intermitent overheating issue. Has had the thermostat replaced. Any ideas? Thanks, Graham
I would fill radiator with fluid, start car and allow to warm up. Watch catch can for bubbles. If there are bubbles I would suspect a head gasket leak.
Mar 17, 2010 | 1990 Subaru Legacy
1996 Acura 3.2TL Overheating Problem...
From your description of symtoms it sounds like you have a bad water pump. If the coolant is not circulating properly you will have a heating problem. Sometimes even a new thermostat can stick and cause the engine to overheat. I have seen them fail in as little as a week after they were installed.
Sep 13, 2009 | 1996 Acura TL Series
Overheating problem on a 1998 BMW 318ti
it's head gasket or water pump, or if you are lucky the thermostat is broken.
Dec 30, 2008 | 1999 BMW 318 ti
1998 sable
cloged radiator or head gasket blown
clogged radiator let cool then run car without radiator cap when warms up the water should be running fast in direction without bubbles
if slow the there is a clog in radiator
the other things of over heating tranny low on fluid
oil fluid low
drive line fluid or grease low
binding brakes
warped fan blades or improper fan clutch or defective
hope this helped its off the top of my head since im not there
Jun 08, 2008 | 1998 Mercury Sable
ASUS P4S533-VM (P4S533-VM/L) Motherboard Logo
129 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
