Plastic smell the unit is new (probably less than 24 hours of use) but has beengiving off a strong plastic smell today after about 6 hours of use. i'mhoping this is temporary but am concerned that it may be harmful.
  • 95 Answers
Only time will tell, a lot of times they will give off a slight odor when they are new but should stop pretty quickly. If it still stinks after 6 hours I would say there is a problem, If it is a portable unit take it back, if built in call the supplier.
Posted on Jun 10, 2008
Top 2" of my concrete wall has eroded. How do I fix it, so it will last, and make sure new concrete bonds to the old?
Hi.
There are different kinds of concrete coating. The choice of product varies, depending if the wall is interior or exterior and on the location of the wall (for example the product used in a bedroom's wall will be different from the coating adopted in a garage).
Epoxy coating are great products that can be used in exterior or interior. Epoxy products however may smell and trigger allergies. Epoxy is one of the strongest coating for exteriors.
If the space is a living room, then it is probably better to use acrylic cement. Acrylic coatings do not smell and do not release volatile compounds. Acrylics look similar to Portland cement and are generally less strong and adherent than epoxy paste.
The application method is usually illustrated in the coating product's container. The procedure consists in cleaning the wall (you can use a power washer), applying the product with a trovel, and then checking the results after 24 hours or when prescribed in the coating's instructions.
After applying the coating you can finish the wall with paint and sealer product.
Oct 18, 2013 | Yamaha RX-V757 Receiver
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
Smells like burning plastic
Probably the odor from the new lamp. It should disappear shortly.
Jul 16, 2009 | Televison & Video
Ammonia smell when Dometic Air Comditioner is on
sounds like you have an old unit and it has a leak , the real old units where filled with ammonia as the gas
Feb 16, 2009 | Dometic Rooftop RV Air Conditioner
Left fyring pan in oven during cleaning cycle
hi dr68,
The service techs at servepro fire/water damage cleanup and restoration might have a few free suggestions, they deal with smoke damage/residual odor issues every day.
Servpro Industries, Inc.
801 Industrial Boulevard
Gallatin, TN 37066
Phone: (615) 451-0200
Fax: (615) 451-0291
anaanymous
Oct 16, 2008 | Sharp R-1610 Microwave Oven
Plastic smell
Be sure all packing materials are removed your operators manual will tell you how to remove them.
Jun 09, 2008 | GE AJCQ08ACB Air Conditioner
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Heating & Cooling Logo
129 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
