Question about Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 won't connect
The camcorder recognizes that I've plugged it in when I have it on play mode, it says "DV-IN".  We bought a 4 pin (camera) to 6 pin (computer) firewire cable, but the computer didn't have a 6 pin port.  So we traded it in for a 4 pin to USB firewire.  It connects, but I get an error message whenever I do, or it doesn't recognize it at all. I'm running a Windows XP.
-micha
  • 1 more comment
  • sweetpeaboo Jun 10, 2008
    Want to purchase 4 pin dv to usb and transfer from DVC to computer. Should this be a problem?
  • zMicha Jun 11, 2008
    It's a USB cable with a 4 pin firewire on the other end. Sorry if I wasn't too clear on that.
    The error message is in the icon tray:
    I then get this window:
    Reconnecting doesn't work, and I'm almost positive it's not the camera.
    Can you help?
    Also: Sorry it took me so long to post this. And as a solution. I don't see a reply thingy anywhere. So I hope this is okay.
  • Anonymous Oct 28, 2008
    the problem is in the camara....i have gone thru 3 of these camaras, the work for a while........
  • Canon Master
  • 2,794 Answers
Your saying 4 pin USB firewire. Which one is it?
It should be 4 pin firewire.
What is the error message that you are getting?
Posted on Jun 09, 2008
Computer doesn recognize camera
Have you downloaded the drivers for that camera: http://www.usa.canon.com/cusa/support/consumer/camcorders/minidv_camcorders/zr800#DriversAndSoftware
Also if it still doesn't work try taking the memorycard out of the camera and reading it using a memory card reader.
Oct 10, 2013 | Canon ZR800 Mini DV Digital Camcorder
Computer reconized canon zr85, but not the zr800
load or reload the drivers for the zr 800,you should be able to get the drivers off of canons website
Dec 03, 2009 | Canon ZR800 Mini DV Digital Camcorder
I connect the IEEE cable (4 pin to 4 pin) to the camera and the computer and turn the camera to "play". The camera is not recognized by the computer.
Check the cable first. It's easy - put another one. If it works - change the cable. If Not - check the PC input by connecting another similar camera. If it works with another camera, then Your IEEE camera port is broken and needs to be repaired. And the order of connection must be: 1. Power off camera. 2. Put IEEE cable on it. 3. Plug another connector of cable on computer. 4. Power on the camera. DON´T TRY TO CONNECT A CAMERA IN A PLAY MODE, it probably can destroy Your camera IEEE port. Sincerely.
Sep 11, 2009 | Canon Elura 100 Mini DV Digital Camcorder
Macbook not recognizing camcorder
I had this problem when first plugging in my Canon zr80 to my Mac. What I did first was (if you have it) open up the program Imovie in you're applications menu. Then plug the firewire cable into both the camera and computer. Turn the camcorder on and set it to play(VCR). Once this happens you should see a "DV in" on the camcorders screen, followed by a blue window on you're computer. The rest should be easy.
Jul 01, 2009 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 - transfering video to DVD recorder
Just want to make sure you are talking about a four-pin firewire cable (small and flat) as opposed to a 4-pin s-video cable (round).
If you are talking about the latter, there is no control signal in an s-video cable so there is no "recognition" possible. Make sure that you have your DVD recorder set to S-video in and then hit play on the camcorder. You will need audio cables too if you want sound transferred. You should see video after you have manually pressed "play" on the camcorder.
Dec 29, 2008 | Canon ZR800 Mini DV Digital Camcorder
CANON MINI DV
It probably has a defective power supply and will need to be serviced by a professional.
Jul 26, 2008 | Canon ZR800 Mini DV Digital Camcorder
Tape Playback
Try cleaning the tape heads with a DV tape cleaner and see if that works.
Jul 07, 2008 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800
Use a firewire cable. Your camera has a 4pin on it (DV port). Your HP laptop may have a 4 pin DV port in the back of it as well.
What model laptop is it?
May 29, 2008 | Canon ZR800 Mini DV Digital Camcorder
Unable to tansfer video to computer using DV cable..
Pinnacle software will recognize the camera installed through a firewire cable once the camera is turned on. Windows movies software doesn't recognize DV cameras. You may be able to get capture to work if you go to Microsoft.com and download the Windows Media 9.0 Development Kit. I believe DV input is a capture option.
There has to be a 3rd party program installed to get it to recognize it.
Good luck on that.
Sep 20, 2007 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 MimiDV Camcorder
You cannot connect a DV cable to a USB port. These are two incompatible standards. DV is also called Firewire, iLink or IEEE1394. You PC must have that kind of port for you to transfer your video from the ZR800 and you will need a DV (iLink/Firewire) cable. You cannot use USB cable they will not work. Check www.MyCableMart.com if you want an example. Most new PC come with 1 or 2 iLink/Firewire/1394 port. If you PC does not have an iLink/Firewire/1394 port then you will need to install a iLink/Firewire/1394 card (see http://www.usbfirewire.com/Parts/rr-fw-byt.html) for more information.
Aug 13, 2007 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 Mini DV Digital Camcorder Logo
466 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
