Question about Nokia 6300 Cellular Phone
Application for nokia extention jar
Applications
    President:
  • 1,257 Answers
Use the link below and you will find so many getjar application and games regarding your nokia 6300 ..........
www.getjar.com
www.mobile9.com
_______________________________________________________
Was this solution helpful. Show your appreciation by rating it.
dilip bagdi - technical associate
Posted on Jun 09, 2008
How do i install applications
  1. Click Start where it says Add / Remove Applications.
  2. Type your password, if prompted, and click OK.
  3. In the Device Application Selection screen, click Browse. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  4. Once the application is in the Device Application Selection list, verify it is selected, and click Next.
  5. On the Completing the Application Loader screen, verify the software to install is listed under Applications to be Installed or Updated, and click Finish.
If you are using BlackBerry Desktop Manager version 4.0 to 4.3then you need to follow this steps:
  1. Connect the BlackBerry smartphone to the computer.
  2. In BlackBerry Desktop Manager, open the application loader tool.
  3. In the Application Loader Wizard, click Next.
  4. Type your password, if prompted, and click Next.
  5. In the Handheld Application Selection screen, click Add. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Handheld Application Selection list, verify it is selected, and click Next.
  7. On the Completing the Application Loader screen, verify the software to install is listed under Applications to be Installed or Updated, and click Finish.
  8. Once the application is installed on the BlackBerry smartphone, click Close in the Application Loader Wizard.
Jul 26, 2012 | Samsung C3050 Cell Phone
Tip
Load applications onto your blackberry.
<span> <p>To load applications onto your BlackBerry, you need to work closely with your PC. On your PC, you use an <span>application</span> called <span>blackberry desktop</span><i> Manager</i> (BDM), which comes on a CD along with your BlackBerry. Application Loader is a mini application within BlackBerry Desktop Manager.If you have an employer-issued BlackBerry, your company might impose guidelines on what applications (if any) can and cannot be installed and uninstalled from your device. Be sure to familiarize yourself with your IT department's policy before attempting to install or uninstall software from a company-owned BlackBerry.<span>Accessing the Blackberry Application Loader</span>After BlackBerry Desktop Manager is installed on your PC, do the following to access Application Loader:<span>1. On your PC, select Start --&gt; Programs --&gt; BlackBerry --&gt; Desktop Manager.</span>BlackBerry Desktop Manager opens.<span>2. Connect your BlackBerry to your PC via your USB cable.</span>Doing so connects your BlackBerry to your PC. If successful, you see the password dialog box. If not, check to see whether the USB cable is connected properly to both your PC and your BlackBerry and then try again. If all else fails, contact your service provider, or contact your system administrator if you're an enterprise user.<span>3. Enter your password.</span>This completes your BlackBerry-to-PC connection.<span>4. On your PC, double-click the Application Loader icon in BlackBerry Desktop Manager.</span>The Application Loader Wizard welcome screen opens. At this point, you're ready to use the functions of Application Loader.<span>Using the Blackberry Application Loader</span><br /> <p> <span><span><span> <br /> <span> <p>To install an application onto your BlackBerry from your PC by using Application Loader, you first have to install that application onto your PC. The installation onto your PC varies, depending on which application you choose to install, so be sure to refer to the manual that comes with the application you choose.After you get the application onto your PC, you need to locate the application's ALX file (a file with the .alx extension). The ALX file isn't the file that gets installed on your BlackBerry; rather, it tells Application Loader where the actual application file is located on your PC. You can usually find an application's ALX file in the folder where you installed the application on your PC.you can install it on your BlackBerry by using Application Loader as follows:<span>1. Launch Application Loader from BlackBerry Desktop Manager.</span><br /> <p>The Application Loader Wizard welcome screen appears.<span>2. Click the Next button.</span><span>3. Enter your password, and then click Next.</span>If your handheld isn't connected properly, you see the Communication Port Selection screen. Connect your BlackBerry to the USB cable and make sure that the USB cable is connected to the PC. Then click Next.The Handheld Application Selection screen appears. This screen lists the applications that are already installed on your BlackBerry.<span>4. Click the Add button.</span>An Open file dialog box appears, which you use to locate the ALX file of the application you want to install.<span>5. Locate the ALX file and then click Open.</span>You return to the Handheld Application Selection.<span>6. Click Next.</span>Doing so brings up the confirmation screen, listing the application to be installed.<span>7. Click Finish.</span>The installation process starts, and a progress window appears. When the progress window disappears - and if all went well - the application is on your BlackBerry<br /></span></span></span></span><br /></span>
on Nov 23, 2010 | Cell Phones
My 5230 does not install any application
Hello, nokia 5230 can only install applications of JAR or JAD type only. Again, you must have enough memory to store them. Some nokia phones will not install applications bigger than 512MB. Provide me with more information and i will help you please.
Oct 04, 2011 | Nokia Cell Phones
I bought nokia c5 , and i don't know how to delete some applications as the message of memory full delete some applications is usually appearing please help me
To delete the application on the phone is quite simple.What you need to do is to go to the main menu, then you select application, then you select the application you want to delete,then you select option and scroll to delete, then the application will be deleted.
But i will suggest you move the applications instead of deleting them. To move the applications, just do the same thing you did when you wanted to get to the application to delete, then you select move instead of delete, it will ask for where you want to move the applications to, then you select the memory cards position, then the applications will be moved to the memory card.
Thank you for using fixya.
Caseytech
Sep 05, 2011 | Nokia C5 Cell Phone
How do you get a back off a sony ericsion x10 mini
The Back up and restore application will back up the directions to your applications downloaded from Android™ Market. After you have restored your content, you need to download and install the applications.
To reinstall the applications with the Sony Ericsson Back up and restore application:
  1. From the Home screen, find and tap Back up and restore.
  2. Tap Restore, and select the backup file you want to restore.
  3. Mark the Market applications checkbox. If you want to restore more data, mark the checkboxes of the categories you want to restore.
  4. Tap Continue > Restore data.
  5. Select the Market applications you want to restore and tap Restore.
  6. Tap Restore to be directed to the applications in Android™ Market.
  7. Tap Install > OK to download the Market application.
  8. Repeat step 7 for each Market application.
Note: You can also reinstall your applications directly from Market, without using the Sony Ericsson Back up and restore application. OpenMarket and go to Downloads, and reinstall your previously downloaded applications. Make sure that you log in with the same account you used before the Android upgrade so you can see your previously downloaded applications.
If you experience any problems during the backup using the Sony Ericsson Back up and restore application, do the following:
  1. Review all the category bars and see if they are progressing. Some categories might take more time due to their size, so be patient.
  2. If you receive a notification saying the application is not responding, restart the application and the backup.
Jun 03, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Application is supportive file nothing to display
in nokia 6500 the format of the application is jar type... or java application.. and it is also depends on the model of the phone and its compatible application...
May 17, 2011 | Nokia 6500 Slide Cellular Phone
My storm 9500 can't download any software I have tried several times keep on denying.
Add, update, or delete applications on your device
You can add, update, or delete applications on your BlackBerry® device using the Applications screen in the BlackBerry® Desktop Software.
When you connect your device to your computer, your device is scanned and the applications are listed in the Applications pane.
1. Connect your device to your computer.
2. In the BlackBerry Desktop Software, click Applications.
3. When your device applications are listed, do any of the following:
• To update an application, click the + icon beside the name of the application.
• To delete an application, click the x icon beside the name of the application.
• To install an application file (.alx) that is saved on your computer, click Import files to browse to it.
4. In the Application Summary pane, review your changes.
5. Click Apply.
Dec 03, 2010 | 123Renamer Quick Flash Player
How to unblock sites
Blocking an application means it will not be able to access any information about you or send you any application requests. To prevent a specific application from accessing any of your information, simply click the block application link beneath any application request you received.
Alternatively, you can block an application by going to its Profile Page. To get to that page, follow these steps:
  1. Enter the application's name in Search.
  2. Scroll down and click to see more results. (Do not click on the application's "Game" result - this will take you to the application's Canvas Page rather than its Profile Page.)
  3. You should be able to locate the application that you're looking for under Applications. Click the "View Application" to the right of the search result to view the application's Profile Page.
  4. Click on "Block Application" beneath the application's picture.
You can see all your blocked applications on the "Block Lists" page under "Blocked Applications." If you want to remove any applications from this list, click "Unblock." Keep in mind that you will not see the "Blocked Applications" section if you have not blocked any applications. You will also need to grant the application permissions again if you would like to re-add it to your profile.
Nov 04, 2010 | AT&T Facebook Apps
I can't download any application to my cell, it keeps saying cannot install contact your application supplier. can't update either nothing works HELP
For Nokia 6210, the Symbian OS only allows for .sis files or .jar files to be installed. If you are using the Application manager and it doesn't allow you to instal' the applications, connect your phone using the USB Cable and selecting Data Transfer and put the files on to your phone. Then install the applications on your phone through File Manager.
If the applications you are trying to download aren't in the mentioned format then you cannot install them into your phone. Make sure they are in .sis or .jar format.
Hope I was of assistance to you,
Cheers :)
Apr 22, 2010 | Nokia 6210 Navigator Cell Phone
My blackberry is just sayingblockerase6 Reset
The Block Erase 6 Reset error may result from corrupt data on your BlackBerry device.
To resolve this problem, you need to complete the steps:
Reload the BlackBerry Device Software by following these steps:
  1. Install the BlackBerry Device Software on your computer.
  2. Connect the BlackBerry device to the computer.
  3. Open BlackBerry Desktop Manager.
  4. Complete one of the following:
    1. If the Application Updates Available window appears, click Update Now. The Application Loader wizard appears.
    2. If the Application Updates Available window does not appear, double-click Application Loader. The Application Loader wizard appears.
  5. Click Next.
  6. If prompted, enter your BlackBerry device password and click Next.
    When the Application Loader wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation.
  7. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  8. Click Next.
  9. If the On the Device Backup screen appears, choose whether or not to automatically back up the BlackBerry device.
  10. Click Next.
  11. Click Finish to begin loading the BlackBerry Device Software.
  12. Click Close when the software is finished loading.
Inspite of this if you find the same error, you need to follow the steps:
  1. Remove the battery from the BlackBerry device.
  2. If a media card is inserted in the BlackBerry device, remove it.
  3. Connect the BlackBerry device to your computer using the USB cable.
  4. Open BlackBerry Desktop Manager and click Option > Connection Settings.
  5. In the Connection Settings window, click Detect. Make sure the BlackBerry device is detected.
  6. Close the Connection Settings window.
  7. In BlackBerry Desktop Manager, double-click Application Loader.
  8. In the Application Loader wizard, click Next to start the loading process. The Device Application Selection screen appears displaying the applications available to load onto your BlackBerry device.
  9. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  10. Click Next. The Completing the Application Loader Wizard appears listing the applications to be installed and removed from the BlackBerry device.
  11. Click Advanced.
  12. Select the Erase all application data check box, and then click Next.
  13. Select the check box beside Do not automatically backup the application data during the loading process. This check box is selected because the data on the BlackBerry device may be corrupt.
  14. Reinsert the battery into the BlackBerry device.
  15. On the Application Loader wizard, click Next to proceed with the loading process.
  16. When the process is complete, the Application Loader wizard will display the following message: The loading operation was successful.
  17. Reinsert the media card if one was removed earlier.
  18. Close the Application Loader wizard.
Nov 16, 2009 | RIM BlackBerry 7290
Nokia 6300 Cellular Phone Logo
140 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
