Vertical lines appear on my lcd monitor
When i turn on my computer the lines are still there.they are always there there no matter what you are doing on the computer.
  • 4 more comments
  • Anonymous Aug 10, 2008
    recently had a full vertical line appear on screen.then i had a second vertical line on the screen.now i have three vertical lines on the screen.they are at about 3 inches away from each other.they start from the left on the screen and move towards the right,
    can you please help,
    breaming
  • toxinn Aug 24, 2008
    Dell 19". Vertical lines on the far right. Lines are there whether the monitor is connected to the computor or not. Does this mean the problem is isolated to the Monitor? Hardware or Software? Thank you.
  • Anonymous Sep 30, 2008
    I have several vertical lines on my lcd lap top monitor. It is gradually increasing the number of lines. They are colored and are permanent no matter what I am running. Any suggestions on how to fix this? Is it possible to replace the monitor alone...it seems to be an integrated portion of the lap top.
  • dawgpatche Nov 27, 2008
    one vertical line can be resolved w a pinch to the frame and it is gone,is this an easy fix?
  • Anonymous Nov 28, 2008
    I have Samsung SyncMaster940B with same problem.
    Greg.
  • atulyamail Dec 11, 2008
    Mine is a 943 i bought in India,but there is one line (vertical.)I put the cords so they don't touch. what to do?
  • 191 Answers
Hi
I am a Dell Certified System Engnieer(DCSE)
you have to be sure if its an issue with the screen or operating system or video card
what you have to do is
turn off your system
now the moment you turn it on again start hitting F2 key
you will get system setup screen
if you see those lines here as well get the LCD replaced and if there are no lines
then try installing the latest drivers
or else you have to get the parts replaced
either the screen or video card
but in case you get display fine in system setup
its for sure your display is fine
Posted on Jun 10, 2008
These permanent vertical lines are caused by a fault in the LCD panel. Gradually occur with normal wear and tear as you use the LCD. The only solution is to get a new LCD unfortunately if its out of warranty.
Posted on Apr 21, 2009
    New Friend:
What is the complaint vertical line in lgmonitor
Posted on Dec 28, 2012
I have the same problem...and try to find out any solution but fail because it was fault in the screen not due to drivers. so finally decide to get one new :/
Kristen Morey
Link Building Service
Posted on Oct 20, 2011
2 Suggested Answers
Fix-4U
  • 293 Answers
SOURCE: vertical lines appear on my lcd monitor
Hi..there,
There nothing you can do.... you've got a damage panel...
Posted on Dec 12, 2008
Vertical red lines no matter what input.
I'm assuming you're dealing with an LCD flat panel monitor.
If you've tried different input and from different computers and different cables, and you're still seeing vertical red lines, it's highly likely that the LCD is failing and there's not much that can be done easily to fix it. You will probably need to replace the LCD panel.
If the red lines are in different locations each time you power on, then it could be a controller board issue. But, if the lines are always in the same place, it's probably the LCD panel itself.
Oct 22, 2016 | Computers & Internet
A vertical line has appeared just off of the center of the screen. I have unplugged turned off reset and changed the background but the line stayed.
The vertical lines means you have failing T-CON board, part of the LCD panel assembly, it will get worst, new LCD panel will be needed. Westinghouse uses cheaply made screen like CheiMai, not LG/Philips.
http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | Westinghouse L1975NW Monitor
Monitor: Compaq TFT5015 Displays vertical lines
Check that the signal cable from the computer is firmly connected and that there are no bent pins in either end. If the trouble continues, the problem is in the monitor itself. Given the low replacement cost, it's uneconomical to try repairing these.
Apr 13, 2009 | Compaq TFT5015 15" LCD Monitor
Hi..there,
Dec 11, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Vertical lines on screen
Inside the monitor.
I don't know how comfortable, or knowledgeable you are about monitor repairs, but your next step would be to open the monitor, and reconnect any wired connections within.
Make sure to take safety precautions any time you work on the internals of a monitor.
If the monitor is still under warranty, contact them aboout a repair, or replacement.
If it's not, it's time to "go under the hood".
With the cost of LCD montiors as low as they are now, it may not be cost effective to attempt a repair beyond checking internal connections.
Aug 11, 2008 | Dell E197FP LCD Monitor
A big white vertical static band appears as soon a i turn on the power
Some of the transistors or the connection to the panel inside the monitor are damaged. There is no absolute fix for this problem.
You can try pushing on the bezel (NOT ON THE SCREEN) of the monitor at the edge of the screen directly at the lines and you may be able to push the connection back together well enough that the line goes away, but usually in desktop monitors the bezel is too rigid to allow you to put any pressure on the connections at the back of the LCD panel.
Mar 30, 2008 | Sony SDM-P234/B 23" LCD Monitor
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
A very thin vertical brun line in the middle
If it's a straight vertical or horizontal line always in the same place it's a panel issue which the average user even with repairing skills will not be able to reliably repair ,Sorry.
Samir
Feb 25, 2008 | Dell UltraSharp 1905FP LCD Monitor
Laptop lcd screen
that's not a firmware issue..your lcd is starting a slow decay to final unhappiness..
you can try the old driver downloader trick, but it's just a matter of time now.
Feb 21, 2008 | LG Flatron L1750S 17" LCD Monitor
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
8,070 people viewed this question
David Payne
David Payne
