Question about Weather King 10AJA2501AH Air Conditioner
My central air never kicks off
My central air unit never seems to cool my house properly and never kicks off I have it set at 72 degrees and it reads 80 in here I have cool air coming from vents Not sure if maybe it needs recharged or what?
  • 1 more comment
  • Anonymous Jun 10, 2008
    same problem
  • mcdewgal Jun 11, 2008
    we just moved into a condo townhouse that has a weather king 13AJA18A01 which never shuts off. the temp was fine the first week or so but with the really humid hot weather the house is on the warm side. i thought it might have frozen up so i shut it off and took a look at the unit and sure enough it was frozen. so it is currently thawing out. i have read that it could be a dirty furnace filter but ours is brand new. or it could be under sized duct work, i sure hope not. hopefully someone has a solution.
    i would appreciate some advice.
    karen
  • George Barber Jul 13, 2013
    Are you going to tell me the readings or not???
  • 770 Answers
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Posted on Jun 09, 2008
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
Everyday the central air unit keeps our house at a comfortable 73 degrees. Every evening, despite the thermostat setting of 72, the house heats up to 77-79. What's the problem?
Is the sun hitting the t-stat during the day? If its a programmable unit check the programming, perhaps its set for energy sving at night
Jun 21, 2011 | Heating & Cooling
Central air unit out side will run non stop in hi temp cond and not cool very well, coils have been cleaned along with condenser and evap. it will run and turn off in early morning hours, freion is wher it...
Here is what you need to do to make sure your system is charged correctly go to the furnace take the temperature of to supply temp and take the return temperature at the furnace. You should have 18-20 degrees temperature difference if your return temp. is 77 degrees you should have 57 to 59 degrees. If you dont have these temps your system either wasnt cleaned properly or not charged correctly. If this helps please rate me and do a testimonial.
Jun 07, 2011 | Goodman Heating & Cooling
We have had this unit for 3 years. We have had it serviced with freon and cleaned each year. The problem is that the air blows out of the vents but it is not cold. Well, for example, it was only 78 outside...
Hello, it is possible that the unit may be undersized for you home and not being able to keep up with the indoor heat load. The only way to determine thia have a hvac contractor do a cooling load calculation on your home. I have seen many units undersized that cause this problem.
Apr 09, 2011 | Goodman CPLE24-1 Air Conditioner
I have never used central ac before - how do I set it? If it is on 75 will that cool the house? If I want it cooler, do I put it lower? like 65?
As to your question 'will 75 cool the house?' The answer is 'yes' - if the outside temperature is low enough. Typically speaking you can expect your central AC to cool a properly insulated house to a down to a temperature of about 20-25 degrees lower than the outside temperature. For example - if the outside temp is 95 degrees. You could expect to get your house down to 70-75 degrees. If the outside temp is 110 degrees then you could only expect to get the house to 85 or 90 degrees.
So .. as you can see - your 'inside' temp will be directly affected by the 'outside' temperature.
As to the operation of central air; it is very simple.
I would suggest that you not pay 'too much attention' to what you have the thermostat set on. A comfortable temperature - is a personal thing - so - I would set it somewhere - say 72 and see how I (and others in the house) was handling that setting.
If you want it 'cooler' just 'notch' it down a degree or two - if you need it a little warmer - turn it up a degree or two. Do this "fine adjusting" till you have the temperature setting you are comfortable with.
Usually the more you can leave your thermostat alone the better off you will be from a comfort position and an electrical useage standpoint. Obviously, the higher you have your thermostat set the 'less' it will cost you on your electric bill.
How high you set the temperature is a balance you have to come to based on how comfortable you want to be - matched with how much you want to hold down the electric bill.
hope this helps
Aug 14, 2010 | Honeywell Heating & Cooling
My Honeywell AC unit doesn't seem to be working properly. It will not retain a temperature. I set the thermostat to hold a temperature of 70 degrees. Room temp still reads 74 degrees. Something is working,...
The frost on the pipe indicates you have a dirty filter, dirty evaporator coil, Blower not running at the proper speed (to slow) or you are low on refrigerant.
Jun 29, 2010 | Heating & Cooling
AIR IS NOT WORKING. hAVE SYSTEM SET AT 72 AND STILL SHOWS 85 DEGRESS IN HOUSE. PIPES AT THE TOP OF UNIT SEEMED TO BE FROZE
There are two things that make a central air conditioner freeze up, they are poor air flow, that means check your air filter, and your system is low on refrigerant, and that will take a serviceman to fill on refrigerant. For the time being set your thermostat cool/heat switch to off, and turn your fan switch to on. This will thaw out your cooling unit, and when the ice is gone you can switch the heat/cool switch to cool to resume cooling until you have figured out which problem you have.
Jun 24, 2009 | Heating & Cooling
Getting cooler air
if you are desiring to have it 62 degrees in the house, the cool setting needs to be more to like 66 deg and the heat setting needs to be like 58 degrees. that would make it more around 62 degrees in the house.
change the heat setting first to 58 and then change the cool setting to 66. this gives your temperature 62 +/- 4 deg.
Jun 16, 2008 | Computers & Internet
Weather King 10AJA2501AH Air Conditioner Logo
400 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
