Question about Cakewalk Computers & Internet
No sound
I have sonar home studio6,I plugged my pod xt line 6 into the line input of the computer. I also downloaded the usb driver gearbox 3.60.I chose an input and an output.But I can't assign an output in the track display and there is no signal, but I can hear the sound of my pod.
  • 22 Answers
The other thing with Home Studio is the driver mode. You have to check what kind of drivers the Line 6 uses, and find them under Options > Audio. Probably ASIO but not sure. Check with Line 6
Posted on Feb 13, 2009
  • 53 Answers
Sounds to me like you don't have a bi directional sound card.
It could verywell be your USB driver.
try uninstalling the driver. driver and reboot and let the PC plug and play a generic loaded USB driver.
Possible your sound card or chipset does not support the driver.
goodluck
44hink
Posted on Jun 12, 2008
There is no factory recall on my pod xt pro
That's correct, there is no onboard recall. In order to reset, follow the instructions in this link-
http://line6.com/support/page/kb/_/pod/pod-20-podxt-family-pocket-pod-floorpods/pod-xt-series-factory-reset-reflash-and-firm-r491
Apr 06, 2014 | Line 6 New Line 6 Pod Xt Podxt Live...
Problems with sound that is coming from computer (output monitoring)
The first thing you should do is to uninstall the EDIROL UA-101 USB2 Driver Ver.1.0.3 for Windows XP and reinstall the system. If the problem persist try to use other usb cable, if the problem still the same please let me know inorder to make another procedure to follow to identify the problem.
Hope this will be helpful.
Nov 28, 2007 | Edirol UA-101 External Sound System
How come mmt tweak knob and select knob arent working on my line 6 pod xt live
It sounds like the pots need replacing if re-soldering didn't work. i would take it to a Line 6 authorized service center.
Line 6
Sep 01, 2017 | Line 6 New Line 6 Pod Xt Podxt Live...
Why does my XT Live suddenly blast the volume and reset the wah pedal? tried factory reset but still does it! Annoying!
I would FIRST suspect that the power into the unit might have an intermittent connection. It would probably reset everything if the power momentarily breaks. Power jacks are NOTORIOUS for this problem.
Aug 15, 2011 | Line 6 New Line 6 Pod Xt Podxt Live...
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
I cant get any output in sonar 6 ahd yes the rack is active im new to sonar just the mixer xenyx xl 1832 usb
Make sure Sonar is set to use the Xenyx for the clock in the audio options pull down menu. It often defaults to your PC soundboard.
Sep 23, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Big Toneport UX 2 Connecting problem! ( FREEZE/ASK TO RESTART )
The drivers that come with gearbox do not work with snowleopard and windows 7. Ok pull out the usb connector of your UX2, then restart, next look in applications/line 6/drivers and there you will find a program that allows you to uninstall the drivers for UX2. Restart, and then go to the line 6 supportpage look for the free download page, search for toneport UX2 - drivers - osx and check the betabox. download the two or three drivers, install them (restart after installing a driver then install the next driver) restart, then start up gearbox and plug in the usb cable of your toneport!
The drivers are not yet the final drivers, they are still beta versions, march 19, line 6 expects to have the final drivers for snowleopard and windows 7.
Excuse my english I'm dutch,
Peter.
Nov 11, 2009 | Line 6 TonePort UX2 Sound Card
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
Drivers Disappear
Its a fight between 64 and 32 bit versions. Audio codec is not so compactable with your sound card sysaudio file You need an updated driver which is compact-able with direct x latest can solve your problem
Jun 19, 2008 | Compaq Presario 700 470024-192 Notebook
Recording on my Yamaha CP33 keyboard using USB
We're talking about audio recording. If so you must conntect your piano by using the L + R outputs with your sound card or mixer line inputs (that's how I do this). USB is ok if you want to use your piano as a master keyboard (MIDI). Another important thing is that you must have an additional application installed called sequencer ( for example Cubase Sx, Sonar...) which will let you store your digital music. I'm not talking about the proper settings of them because it could take a day or so...:)
Overall, you will have to learn a bit about the home studio, home recording techniques. There are tons of informations on web. A great thing is that you can use your CP33 as a master keyboard to control additional virtual instruments (VST) or for example play different piano samples (check Synthogy Ivory). Possibilites are endless!
Regards
Radek
May 24, 2008 | Yamaha Full-Size Keyboard
Computers & Internet Logo
158 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
