Question about Dryers
Dryer will not tumble
I have a Kitchenaid electric dryer model KEYE760WWHO that will not tumble.
I do not have a repair manual and can't find one online. I tried to troubleshoot using the schematic this is what I found:
I have power all the way through the start relay.
Power next goes through a switch of some type and then to the motor.
I don't have a legend to tell me what this switch does.
The door switch from the motor to N is good but I don't get any power to the switch.
The following switches are good: Hi Limit Stat., Oper Stat.
The Thermal Cutoff is good, and the Heater elements are good.
The Timer switch appears to be good.
I don't have any info on the electronic control.
Can you help?
Thanks,
John
  • JohnDS Jun 09, 2008
    I had checked it before posting, see my comments above. It was good. I also tried your premium service but they didn't have the troubleshooting guide or a schematic for my model dryer. I asked FixYa to refund the charge since I knew no more after talking to a expert that when I had started. I do have a lot of troubleshooting experience and I've worked in electronics for years. Thanks for responding but without the schematics or trouble shooting guide I don't think you can help. I got to this site trying to find a troubleshooting guide that would explain more on the timer switch and control board.
    Thanks anyway,
  • 770 Answers
Have you checked the door switch?
Posted on Jun 09, 2008
  • Gary Davd
    Gary Davd Jun 09, 2008
    TESTING AND DIAGNOSIS
    Diagnostics
    The following problems can be diagnosed by observing the indicator LEDs on the control panel.
    Power Failure
    When the 3 STATUS LEDs are flashing: Drying + Cool Down + Finish Guard, a power failure may
    have occurred during a cycle.
    · The flashing LEDs can be turned off by pressing “ON/SELECT” or “CANCEL”.
    Open/Short Thermistor
    When the TIMED LED is flashing, the thermistor or the wiring to the thermistor is open or shorted.
    · The thermistor must be replaced or the wiring fault must be corrected.
    Door Open
    When any one of the following STATUS LEDs is flashing: Drying, Cool Down or Finish Guard, the
    door has been opened during a cycle.
    · Close the door and press “START” within five minutes of opening the door in order to continue the
    current cycle.
    · The electronic control will turn off automatically if the door is left open for more than five minutes
    or if “START” is not pressed within five minutes of closing the door.
    Motor Test
    If the motor will not start, check the following:
    - Line Voltage (120VAC) - Motor
    - Harness/Connections - Door Switch (120VAC contacts)
    - Motor Relay - Control Assembly
    - Thermal Fuse
    1. If the Lockout LED is lit, press and hold “SELECT/LOCKOUT” pad under OPTIONS for 5 seconds.
    The Lockout LED will turn off.
    2. Press “ON/SELECT” pad if the LEDs are on and go to step 4.
    3. If all LEDs are off:
    a. Check the ‘120VAC supply voltage to the electronic control assembly. (W to BK)
    b. If 120VAC is present and the harness connections are OK, replace the electronic control
    assembly.
    4. Press “START”
    21
    a. If the motor does not start and there is an “Invalid Tone”, check the door switch. (D to D1)
    b. If the motor does not start and the Drying LED lights up, check the motor and thermal fuse.
    c. If the motor still does not start, check the motor relay (BK to BU)
    d. If 120VAC is present and the harness connections are OK, replace the electronic control
    assembly.
    No Heat Test
    If the heater will not turn on, check the following:
    - Line Voltage (120VAC) - Heater
    - Harness/Connections - Centrifugal Switch
    - Heat Relay - Thermistor
    - Thermal Cut-Off - Control Assembly
    - Hi-Limit Thermostat
    1. Press “ON/SELECT” and “START”. The Drying LED will come on and the motor will start. the
    heater should turn on after a 4 second delay.
    2. If there is no heat, check the heat relay.
    a. If 0VAC, check the centrifugal switch, heater, hi-limit thermostat and thermal cut-off.
    b. If 120VAC, replace the thermistor and check harness connections.
    Heat In Fluff Test
    If the dryer heats in Fluff Air, check the following:
    - Harness/Connection - Heat Relay
    - Heater - Control Assembly
    1. Press “ON/SELECT” until Fluff Air LED indicator is lit.
    2. Press “START”
    3. If heater is on, check the harness connections and heater.
    a. Check the heater relay on the control board (BK to R)
    b. If 0VAC, replace the electronic control assembly.
    Shut Off Test
    If the dryer will not shut off, check the following:
    - Harness/Connection - Motor Relay
    - Sensor Strip - Control Assembly
    1. Remove clothes from the dryer and press “ON/SELECT”.
    22
    2. Select Automatic - Less Dry and press “START”.
    3. If the motor will not stop after 16 seconds, check sensor strip (Y-R to G-Y).
    a. If 0 ohms with no load, check for a short in the sensor or the Y-R wire.
    b. If infinite ohms (Y-R to G-Y should be infinite with no load,) replace the electronic control
    assembly.
    If the dryer shuts off too soon in an “Automatic” cycle, check the following:
    - Sensor Strip
    - Control Assembly
    1. Short the sensor strip together and press “ON/SELECT”.
    3. If the motor stops after a 16 second delay, short Y-R at the control assembly.
    4. Repeat steps 1 & 2.
    a. If the motor runs more that 16 seconds, repair or replace the sensor and the Y-R wire.
    b. If the motor stops after a 16 seeond delay, replace the electronic control assembly
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
Dryer not tumbling
Look up the model, google or the like and see if u can find some schematics. Its does seem likely to be the belt but u may find a better way to crack it open.
Aug 31, 2012 | KitchenAid KEYS750LQ Electric Dryer
Tumbler won't tumble
broken or worn belt
Jan 19, 2011 | KitchenAid Dryers
Got new tmbledryer week old no digital display checked fuse on plug
Cheapest price search results for AEG T58840- Tumble dryer- Technical details, features, compare prices, AEG T58840 buying guide, reviews, tests, d and buy a AEG Lavatherm T58840 Electric Dryer from 419 at Deal Time UK.See images, features, check best price and 2 reviews and ratings by people who have bought this Aeg T58840: "A lot quieter than my old tumble pare prices for the AEG T58840 Washer d impartial reviews and buy online for speedy delivery only denser tumble dryer with Silent pare the UK's best prices for AEG T58840 and other Washer-Dryers from 100s of online shops.
AEG T58840 AEG Tumble Dryer Condenser, FREE DELIVERY, Buyers and Sellers offer the widest range of domestic appliances from top of the range to budget items at the most.7Kg Drying Load, Condenser Dryer, Sensor Drying, Large LCD scree, 20hr Delay rn everything you need to know about tumble pride ourselves on our customer service and the best prices on internet for the AEG Appliances Tumble Dryer Condenser Freestanding T58840 from BHS pare prices from across the web and read product reviews on AEG Lavatherm t58840 compare prices on Aeg t58840 from online T58840 Condencer Dryer- 7kg Load in White.
T58840: 7Kg Condenser Tumble Dryer in White: 433.97: AEG: T88840: 7Kg Condenser Tumble Dryer in White: 535.00: AEG: T35850: Vented Tumble Dryer: 264.97: AEG: Electric Shop supply AEG T58840 7Kg Condenser Tumble Dryer in White from leading manufacturers at discounted T35850 Vented Tumble Dryer- Special T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 White Freestanding condenser tumble T58840 Condenser tumble Price: 448.85.Tumble Dryer Models from AEG: T35850; T58860; T88840; T58840.
Aeg T58840 Condenser Dryer, read the latest user reviews and compare prices on Aeg T58840 Condenser T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 Condencer Dryer- 7kg Load in T58840 from Chantry Digital AEG 7kg Load Condenser Dryer with White T58840 Colour WhiteManufacturer AEG7kg Drying LoadCondenser DryerSensor DryingLarge LCD Screen20hr Delay StartCondenser duct information and details for AEG Lavatherm T58840 Electric AEG T59800 Dryer is in stock at several UK k the green box and well make sure that more people get to.
Find out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in p with dryer hotpoint tumble problem on AEG T58840 Condenser Tumble Dryer Electric and free tech support for dryer hotpoint tumble d out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in rything you want to know about the T58840.491.00: NEW AEG T58840- MANUFACTURE a better deal by comparing prices on AEG T58840 Washing Machines to save money online and guarantee Christmas T58840 3) Tumble Dryer Spares and T58840 3) Parts- Page 2- Belt, Door, Drum, Filter, Seal, Heater, Hose, Knob, T58840 Tumble Dryers Condenser In White Aeg The number one appliance specialist in the UK.
Condenser Sensor dryer
Large LCD Display
Sensitive Option, Leisure Programme
21 programmes including Microfibre, Jeans, Bed Linen
Easy Iron, Extra Dry, Storage dry, Hand Iron
Machine Iron, Intensive Dry, Extra Dry, Wool Care etc
Large 36cm porthole opening
Interchangeable door hinge
Manual timer up to 40 minutes
Stainless steel drum with Internal Light
Drum Light
please comment on these on how helpful.
Dec 21, 2010 | AEG T58840 Dryer Electric
The dryer tumbles but does not heat. There is no
If you dry a lot, you may need heating coils. Heavy loads such as jeans and towels will put a premature stress on those coils.
Jun 21, 2010 | KitchenAid KEYS750LQ Electric Dryer
Dryer continues to heat when door is open
The model number you put up is for a gas dryer, but you said element, so I'm assuming it is actually electric.
If this is in fact an electric dryer, you most likely have a heating element that has shorted to the case. There is a small chance that something else in that circuit has shorted to ground but I doubt it.
If this actually is a gas dryer, please discontinue use immediately and get a licensed tech over there to look at it.
Good Luck
May 16, 2010 | KitchenAid KGYS850LT Gas Dryer
WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 24, 2010 | Abbaka White Knight 38AW Electric Dryer
KitchenAid Dryer Timer stopped working - won't stop drying
Timers cannot be repaired. The mechanism is a spring - once it weakens, or fails - a new timer is required.
CLICK HERE for your part.
It is $83.72 USD.
Here is a Buy-it-Now eBay auction for $34.99USD & Free shipping!!
CLICK HERE
Your part number for the timer is 3976570a
A used part would have to come from an appliance store that salvaged from an abandoned washer.... and it may fail shortly anyway.
The new timer will have a warranty, and give you 10 more years of service.
Well worth it.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 05, 2009 | KitchenAid KEYS850LQ Electric Dryer
Dryers Logo
224 people viewed this question
Top Dryers Experts
