Question about Samsung ML-2510 Laser Printer
How to print from DOS?
My ML-2510 printer don't print from DOS programs, How i can make ML-2510 print form DOS?
  • carloswv Jun 10, 2008
    thanks for answer, but my problem is this: i have a DOS program, and my old printer (HP1200) print very well from this DOS Program (Fox for DOS Language). But my new printer doesn't. Its problem of my printer? (my printer not support DOS o its simply a malfunction of my printer and need send to warranty?) or need some special configuration in that?.
  • MRNAB Apr 01, 2009
    Cna any one help me?? i have replaced HP 1200 with Samsung ML 2510. M not getting the printing from a DOS based application while it works for Windows... HP 1200 is giving the printing from DOS
  • 191 Answers
Type
prn and then the file location
you will be able to get printouts from DOS
Posted on Jun 09, 2008
My samsung ml 2510 wont print. seems to start up ok, although it had been taking a little longer to warm up recently
hello problem is your toner cartridge change the toner cartridge and try to print.then warming up is became ok.
Jan 13, 2011 | Samsung ML-2510 Laser Printer
I dont have the disk
Hi
Please follow the link below :
http://www.retrevo.com/support/Samsung-ML-2510-Printers-manual/id/328dj293/t/2/
1. From the Tabel of Contents Choose Basic Set Up
2. It will take you to Page 14 form where you can follow instructions
Hope it helps you.
Jul 18, 2010 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Dec 12, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Jun 08, 2009 | Samsung ML-2510 Laser Printer
My ML-2510 samsung printer stopped printing?
Delete printer Icon in the "printers and faxes" dialog box, then use the software installation Cd to re-install it. Also, depending what software that printer uses, there may be a "Samsung" software to delete in "add/Remove programs" in the "control panel" as well. I would delete everything and start from scratch.
Select the proper port when setting up. I assume you are using a "USB" port?
Mar 15, 2009 | Samsung ML-2510 Laser Printer
Driver for Samsung ML-1640 for WIN98SE
I got the same problem. It seems they did not develop specific drivers for win98se. However, I found that you can print using the drivers for the old Samsung ML-2510. Win98se drivers for that printer can still be downloaded from Samsung website. I've been using the 2510 drivers with the 1640 printer for a couple of months, and worked fine so far. It seems very little change in electronics from the 2510 to the 1640 model.
You need also Virtual Printer Port for USB from microsoft.
Jan 07, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung ML-2510 will not print from MAC OS on Macbook
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
ML-1610 Laser Printer
hello sir first u install dos base drivers from your printer cd -see below
go control panel printers and faxes select dos base defalt print ok by if any problem uday_uday2004@rediffmail.com
May 19, 2008 | Samsung ML 1610 Laser Printer
Printing dbase reports on a samsung laser printer
dBase as in the old DOS based database program from the late 80s - early 90s? If so we'll need some more details on which version (II, III or IV)and the Operating system the program is running in to start with.
Feb 17, 2007 | Samsung ML 2010 Laser Printer
Samsung ML-2510 Laser Printer Logo
432 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
