Question about RCA 27V530T 27" TV
Gone haywire My set is about 3 yrs old. Everything has quit working on it. I turned it on and there is a picture, but the channel won't change. I tried to use the menu, it will come up on screen, but it doesn't work, the highlighter keeps running up and down the page, it won't stop on anything. The sound is doing the same thing. I finally got it to adjust, and then the bars came on screen and the sound started going down on it's own and then no sound, and I couldn't adjust it at all. I tried to turn off the set, but I had to unplug it to get it to go off. The controls on front of the set will not work at all. I was not having any problems at all until this. What could be causing this? About what would be the approx cost to repair it, and would it be worth it. Thanks, Cindy
  • 31 Answers
Your circuit board has definately overheated. You have to send it into the manufactorer for a replace.
If this helps at all, please rate this a FixYa. - Evolution
Posted on Jul 16, 2008
Alarm comes on when I turn ignition and car won't start, Alarm gone haywire
may be the battery, since all the components work off of it you need to check all connections, low battery, batterys are only good , if you have a 3 yr old battery, it is only going to be good for 3 yrs, or less, depends on how long it set on the shelf.
May 03, 2013 | 2006 Scion tC
50' philips plasma tv has sound but picture is distorted
I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
All sound but no picture its
32' polaroid llc tv&dvd flat screen three yrs. old
tda03211c
Feb 06, 2010 | Televison & Video
RCA P46924 46" Rear Projection Home Theatre Gone Haywire
the button cluster in the front may have a bad tack switch(button) or the buttons may have loose connections. you can take the speaker grill off and look yourself...watch for wires..unplug your tv first:) also if you use spray cleaner that may have seeped into the button cluster too...you may be able to get the cluster as a whole from a local tv repair shop and put it in yourself..save labor charges:)
Mar 21, 2009 | RCA P46924 46" Rear Projection Television
Side BY Side Picture On TV Black And White
Try holding the stop button and the DVD dubbing button at the same time and waiting about 3 seconds. I had to do this twice, but it solved my problem.
Feb 27, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Everything works except picture
Most probable cause is the vertical output IC. You can get a replacenment at the following link.
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
TV PROBLEM
No sir its not just an adjust ment or "twiddling" It sounds like its one of the same as your girlfriends set except a differant part such as a capacitor in the vertical curcuit, Output IC or even a defective resistor?? Good Luck
May 18, 2006 | Grundig GF70-600 TV
RCA 27V530T 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
