The refrigerants is related to a system preassure and temperature relationship! If too low preassures the refrigerant cools too low.. If just right it will stay above freezing temperatures ((32*)) If too high of a preassure, or too much refrigerants ,the temperatures will stay too high and not cool down the return air at manufacture specs. and not remove the designed btu's and humidity... ....(bottom line, just check out a reputable hvac serviceman.) Oh yes, also low air flow across the indoor coils!
Outdoor coils dirty creats high head pressure which in turn destroys a hermetic compressor for the fact that a hermetic compressor uses Superheated vapor to cool windings..Your post is so vague but for the fact you advise a service tech...
New unit installation, 1800 BTU 220 volt. Getting voltage to both outside and inside units. Can't...
(More)
New unit installation, 1800 BTU 220 volt. Getting voltage to both outside and inside units. Can't get the inside unit to start.
about three years old worked great until now.system runs for about 15 min systems shut off...
(More)
about three years old worked great until now.system runs for about 15 min systems shut off completly,compressor amps high.line set leanth is about 60 ft,charged 2.3 lbs per foot any less and lines freeze.outdoor temps vary from top to the bottom of out door coil.
I bought 3 mini split systems from a company in NY and had them professional installed last summer. ...
(More)
I bought 3 mini split systems from a company in NY and had them professional installed last summer. When there was a prorblem with one of the unit I tried to use the warranty and no one responded. I contacted the Attorney General's office in NY and they tried to contact the company to no avail. I now have a problen with two of the units after having spent over $5000. One unit has a flashing error code of "E2" and will not come on. The other unit, the indoor unti will come on but not the outdoor unit. This happened after a power surge. Does anyone know what this erro code means and how to repair it?
LBJ
