Question about RCA D52W19 52" Rear Projection Television
PROBLEM WITH D52W19Z RCA
I think the power supply is bad. It's what I've been told by people I call. I hear the clicks when I try to trun on but no screen. Can I order the part and replace myself? I was quoted $350 - 450!
Thanks,
Rod
703-909-0937
  • KandeeL Jun 12, 2008
    The T.V will not turn on but the green power light comes on and you hear a clicking noise 3 times. Then you have to wait several minutes for the light to come back on. When it does happen to power up, the picture is very wavy for a few seconds also.
  • RCA Master
  • 8,617 Answers
Certainly, but along with the click does the power light flash? let me know and I will try to isolate the problem for you and then I can post a link where you can get replacement boards along with instructions on how to install them.
Posted on Jun 10, 2008
Rca D52130
Power supply or high voltage supply problem---set well known for bad solder connections in and around the high voltage transformer---also known in early models for the high voltage splitter to be bad.
typical high voltage transformer:
Nov 05, 2012 | RCA Televison & Video
VE 920 clicking
THE problem on this unit is the power supply , need to open unit and check for bad capacitor on power supply , they look look pop from the top
Feb 03, 2012 | Audiovox VE1040 10.4 in. TV/DVD Combo
What is most likely the problem when I push power button and I get nothing, no response at all, Power supply or Mobo ?
First of all, I'm assuming that you've connected everything correctly. I would think if absolutely nothing happens, it's probably the power supply. If a motherboard is bad, the power supply will still flip on, you'll hear the fan, and then nothing will happen. So your best bet for fixing this is replacing the power supply. Possibly with one that has a higher wattage.
Jul 29, 2011 | HP Computers & Internet
If my samsung dLp HLM 507,has no lights,no power& the lamp is tight in the socket.Could it possibly be the BP-96 lamp? I've heard there's some sign of life when the lamp is bad.this set's dead
90% of the time the lamp is bad when the lamp is bad a lot of the time you will here a buzz sound by the lamp its trying to trun on the lamp but cant. also look at the flashing lites on the front of the tv it should give you code
Dec 08, 2009 | Samsung HLN5065W 50" Rear Projection...
MY TV IS CLICKING AND WON'T TURN ON
Good Day;
The most common problem with these Models/ Chassis' is IHVT (intergrated high voltage transformer) going bad. They have around 99% failure rate. T14401 > part number > 239111 >IHVT.
Try to get RCA part a little more pricey but more reliable then after market ones. You can tell if it's bad by the crust on the top of IHVT.
Good Luck, big IRISH.
Sep 11, 2008 | RCA P52926 52" Rear Projection Television
Rca big screen television 65 inches
the clicking is the relay clicking which is one of the first components when power is applied. Your set will need to be diagnosed by checking the stanby and start up circuitry. Unless you are skilled this is one chassis thats left to a skilled repair tech. They have alot of problems with the power supply and deflection circuits, flybacks and etc.
Apr 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Relay click and 9 blinking led.
Try the following steps:
1. Remove the power supply to X Main board, check VE. If you get normal VE then replace the X Main board. Otherwise to 2.
2. Remove the power supply to Y Main board, check VE. If you get VE then replace the Y Main board, otherwise to 3.
3. Replace the SMPS board & SMPS 200V board.
Good Luck
Mar 22, 2008 | Samsung SPN4235 42 in. Plasma HDTV
RCA F32450 ATC113 chassis Dead & Squealing
IHVT # 257805 or ASTI 2078 = 20.00.......................T.
Dec 02, 2007 | RCA F32450 32" TV
NOT TURNING ON
it is a power supply problem. disconnect the horz. output collector plug it in and hear if you have sound. if the same check for 13v 24v if U are not a tech do not try to do this.
Dec 13, 2006 | RCA P52960 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
