Question about Dometic Rooftop RV Air Conditioner
2000 roof-top Brisk-Air
Have not probley run this unit more than 200 hours since trailer was purchased in 2000.
This year, I turned it on for the first time this season. Trys to run cold but
cuts out and then blows warm. Its been parked in the sun in 90 plus degree weather for the last 4-5 days. Do you think it needs to be recharged? Thanks for your help.
    Champion:
  • 254 Answers
I think you have a high pressure cutoff cycling the compressor on and off. Clean the filter inside the unit. Then with a hose clean out the foil condenser filter on top of the camper. Also you may need to buy a coil comb and comb out bent or damaged areas of the condenser coil on the unit that is above the roof of the camper.
Posted on Jun 10, 2008
What code is E-7
loss of 120 volts to relay module
Jun 14, 2015 | Brisk Air Dometic A/C Roof Top Air...
Can you recharge. a dometic a/c rooftop unit serial number 991762724
No service ports on the unit. It needs to have a service port soldered to it and the system breached before you can check / charge.
Aug 29, 2014 | Brisk Air Dometic A/C Roof Top Air...
I have a travel trailer with a coleman 7300 roof top ac unit. the unit will blow cold air but water leaks thru the plenum. i was told by the previous owner that it needs a new seal. i would like to fix it...
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
Nov 14, 2010 | Dometic Rooftop RV Air Conditioner
I have recently replaced the fan motor on my Briskair roof top A/C unit, should the squirrel cage draw air from inside the trailer and blow out rear of the unit, or have I installed this fan incorrectly?
Yes the air should be drawn from the trailer, over the cold coils and then
back into the trailer, whether rear or front.
The condenser coils should be self contained on top and blow
warm air outside the trailer
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 26, 2010 | Dometic Rooftop RV Air Conditioner
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
Dou Therm Brisk Air not running
Turn the ac off go up top the coach and remove the cover. Look for fan blockage, Wasp, mud dauber etc. Caution if it is wasps they will chase you off the end of your coach. Take some spray with you. If there is no blockage the fan motor is toast.
Thanks for using Fixya
Jerry
Mar 27, 2009 | Dometic Rooftop RV Air Conditioner
Dometic air conditioner
1The air coditioner does run on Electric. 110V 2. No you do not have to unhook the battery 3. Yes you need to put water in the hot water heater so you do not burn the unit up.
Feb 01, 2009 | Dometic Rooftop RV Air Conditioner
Duo-Therm Brisk Air Model 59516.601 Ducted Roof Air w/wall thermostat
First of all, I think you mean 110 volts on your meter, not amps, just so we're on the same page. It sounds to me like you may have a capacitor problem on your compressor. I'll try to see if I can find you a part # if you have someone very experienced with electrical that can change it for you. they can be a little dangerous, so only someone familar with them should work with it. What the capacitor basically does is store voltage and uses it to help the big draw on start-up of the compressor, kind of like giving it a boost to get it started, and after it's up and running, all should be well if everything else is up to snuff. How old is the AC unit? Did it run well for you in the past? I'm asking this just in case it was a recent installation, with perhaps wrong size wire used. Should be minimum 12/2 , with 20amp breaker,if that means anything to you, or your mechanic.
Aug 15, 2008 | Dometic Rooftop RV Air Conditioner
Air conditioner leaks/drips from filter inside travel trailer
Either your 14"x14" a/c gasket is lose on the roof allowing the condensation to flow into your RV or you have a cracked condensation tray under the evaporator. I'm guessing the later
JGRV
Aug 01, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
255 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
