Question about NorStar M7324 Telephone
Phone doesn't go to directory
When calling into the main number, it keeps on ringing instead of going to the directory after a couple of rings like it used to do.
Appreciate any help
Can you dial into voicemail and check your messages? Maybe the voicemail is down.
Posted on Jun 23, 2008
How can I get the phone to ring when an outside call comes through instead of the recording?
It is an option in the menu under phone settings. If number of rings before answering machine is not set to a number or set to zero it may always go to the answering machine.
Sep 16, 2015 | Lands Phones
Why does my phone only rings once, calling party hears a couple of rings and then goes to voicemail. goes to dial tone when answered after first ring.
Press menu, go to settings then scroll down to ring count and set number of rings before it goes to voice mail.
Jul 18, 2014 | Panasonic Lands Phones
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
Panasonic kx dt 333 When the phone rings the red light doesn't flash to denote which line it's coming in on. Any idea how to resolve this?
Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
Carl
May 11, 2011 | Panasonic KXDT333 Phone
How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
Hello, I'm trying to turn the ringer off some of the phones at my work. We have panasonic kx-t7630 phones. Are you able to help me please?
When you bought the phone system, it was either installed by a professional installer, or you got some sort of instructions. A Panasonic phone system of the TDA/TDE/NCP type rings phones by Incoming Call Distribution Groups (ICD). The main group is 1 and usually is numbered 601. Extensions are members of an ICD group(s) and the number of rings can be programmed for No Ring, Immediate ring, or delayed rings of 1-6.
You can turn off the ringing, but keep in mind that CallerID only displays on a ringing phone or after you answer it. So, if you somehow have access to program 620 and 621, then you can change it from a phone, if not, you'll need access to the maintenance console of your particular phone system.
I don't wish navigating in 620/621 from a phone on my worst enemy and it's beyond the scope of a free forum to instruct you on how it works. I suggest you call your Panasonic service tech.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
Our AT&T 1725 has quit recognizing when the phone is ringing. The phone keeps own ringing instead of beign answered.
There are a couple of things to try. First is to check the cable & plug that connect the 1725 to the telephone line. Disconnect the phone line from the back of the answering machine, plug it into a known working telephone, using cell phone (or another land line) call the phone number and see if the phone rings.
If it doesn't, replace the line cord and try again.
If it does ring, check the optioning to make sure it is set for, say 2 rings.
Also, is the telephone line a regular telephone company POTS line or is it one that is being provided by a cable modem? If your phone service is being provided by a cable company, the media converter might not be putting out enough voltage for the answering machine to realize that the line is ringing.
If everything is correct, replace the answering machine.
Aug 18, 2009 | AT&T 1725 Answering Machine
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
Picking up a call
@AlexaF
A couple of things to try. First, walk up to the phone that's ringing and dial 720# on the intercom. They may have set Call Pickup Deny (by dialing 721) and this will clear it.
If that doesn't work, you may have fallen out of the pickup group. You can test this by using the Directed Call Pickup code which is 4 + the ringing extension number.
If that works, but 40 doesn't, there's some programming(system prog 600) that needs to be examined. By default though, each phone is in pickup group 1.
Carl
Sep 29, 2008 | Panasonic KX-T7730 Corded Phone
NorStar M7324 Telephone Logo
196 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
