-   switch unit on to speed..33/1/3 for example, nothing happens, if remove platter, can see motor spindle moving very slightly, put platter back on and leave for 45 mins and the platter is revolving, at the correct speed. There is a small circuit board attached to the motor, which is not a papst type, could the capacitor be responsible, for this problem, or could it be the motor itself.
Check the fuse in the plug and make sure power is available at motor end of mains lead.
Also, remove belt and see if motor turns (If the 6 rubber motor mounting grommets are failing, it may help to gently push motor up from below). If not, its prob the motor and these can be found on e-bay.
Was this helpful?
Yes
No
Solution #2
posted on Jun 17, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
Well, with a turntable that old, if it hasn't been restored it likely needs to be. Could be the power cord, the motor or the clutch.
I would select the CD and push play the CD turntable would rotate but a selection is not made by the...
(More)
I would select the CD and push play the CD turntable would rotate but a selection is not made by the play mechanism. The Load/ unload button when pushed the turntable makes a complete revolution The model isDCS--M480.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
