Question about Amana Refrigerators
I have a AMA IC6 ice maker and the ice is stuck together form water running over into the catch tray.i have removed the ice maker and let it thaw then reinstalled and the same thing happened. any suggestions thanks in advance
Having problemAMA IC6 Icemaker. Water leaking into tray as it is making cubes causing previous cubes to freeze together and to the bottom of the container. Trying to defrost to see if that helps. Any suggestions appreciated.
Posted on Jun 09, 2008
I need to thaw the ice that is in my ice maker (Kenmore Elite, 106.56709500), how do I do this? Can I just remove it?
Just get a new ice maker on cheap on ebay since the heating element (for ice removal) on tray will cost more than a new maker!
Aug 25, 2017 | Refrigerators
Ice keeps getting stuck in ice maker # fsc23r505b2
Most icemakers have a low voltage defrosting element wrapped around the ice shute to prevent the ice from freezing and jamming up. Carefully have a look for any disconnected wires or damage to the heating element. If the ice is getting "glued" together in the ice box itself, its likely that the water tray is overfilling and causing water to run down into the ice box. When it freezes, it freezes all the ice blocks together. In this case, you may need a new ice maker tray or ice maker water valve.
Oct 20, 2013 | Frigidaire Refrigerators
Ice maker maker not calling for water. changed mixer valve (new) still nothing water dispenser works. the icemaker runs it rotation ok still no water coming into tray
the fill line is frozen in the freezer .remove ice maker fill line is located behind maker use a hair drier to thaw.. could be ice maker too it controls the water valve.
Aug 24, 2010 | Kenmore 53642 / 53644 Side by Side...
How to fix frozen ice maker line ice formed around line coming into maker
Remove fill tube from the refrigerator and run hot water through it to thaw. Reinstall and replace the water valve. A seeping water valve will freeze the fill tube.
Mar 04, 2010 | Refrigerators
Whirlpool freezer on top ice maker is making a grinding noise and is not making ice Apiece of ice is sticking out of the icemaker's tray. we left it in the off position a couple of days. when we returned...
You should have three screws on the side of the ice make. Two right above the tray and one below. Remove the screws and unplug a four wire connector.
When you reinstall it check for proper water fill. A low water pressure to unit or ice maker valve getting plugged up can cause a small cube to get stuck.
Jul 28, 2009 | Refrigerators
Frozen water in ice tray
You do need to thaw the ice maker out completely. I always remove it but that may be more than you are up to. You can also try a hair dryer on it to thaw it out.
Feb 26, 2018 | Whirlpool GS6NBEXRB Side by Side...
Frigidare ice maker making slabs of ice, not cubes
Today, I removed ice maker and auger motor. Found out this morning that water was running down the back of frig. inside, everything in freezer was frozen together. Found this out after removing all food from freezer. When i looked into the ice maker where water enters, that was frozen solid. After thawing and checking everthing. I put it back together in freezer. It is nine oclock now, and I do have cubes. I really can't tell you what I did, except thaw it all out. It's been running for four hours now and it seems to be all right.
Nov 16, 2008 | Frigidaire Dryers
Amana ic6 ice maker
sounds like your ice maker is working properly and that maybe you pinched the water line when you reinstalled it back into the elbow.. is the elbow clear of any ice build up or foreighn matter that would restrict the flow of water into the ice mold tray? If so..that's your problem.. ( thaw it out or melt it and then you should be OK) Hope that helps..
Aug 18, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Water/ice dispenser
if you take the kick plate off below the doors, youll see a small wire harness on the left hand side. youll see a plastic conection where the wires come together. one or more wires are broken. its a pretty common problem with ge. if you cut the conector off and use butt conectors to reconnect the wire matching the colors you wont have the problem anu more
Nov 25, 2007 | GE CleanSteel GSL25JFTBS
Ice maker won't fill
leaky solenoid? could cause ice build up
Jul 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
210 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
