Help i cant get my print are scanner on my computer i had a man to work on it and he took evert-hang off so now i cant use my print are scanner and they lost my cd when we moved thank you carol massa phone number 918 315 1266
    New Friend:
What is the printer model?
Posted on Apr 11, 2013
I have a cannon mp530, I lost the disk and want to hook up to my new laptop
Posted on Jun 09, 2008
I have a cannon mp530, lost the disk and want to hook up to my new lap top
Will not print but it will scan and copy
Some times printer manufacturer provide print and scanner drivers separately, did you try to find "print driver"?
Or... some times when you plug your device prior to start installation agent, it do not work until... you re-connect your printer in to other USB port. Try it!
Aug 22, 2012 | Lexmark X4530 InkJet Printer
RE: HP 2110 all-in-one printer. I have put in a new Black HP toner cartridge (color is OK). The printer then goes through the "Align Print Cartridges" process. After the cover page (which prints...
Turn off the printer
Clean the Scanner Glass with Lint Free Cloth ( drop 2-3 drops of water on Cloth, Squeeze it and Wipe the Scanner Glass.
Also try to switch/change the Wallsock/Surge protector socket since the Scanner bulbs are not getting enough power to scan the page
Jun 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
Cant get know help to program my scanner
Programming the BC60XLT is simple and straightforward:
- Select the frequency to program.
- Select the channel that you wish to program it into. You can press MAN and the channel number, followed by MAN, or just repeatedly press MAN until the desired channel is displayed.
- Enter the frequency, including decimal point (for example, 156.065). The decimal will display as a dash.
- Press E. The frequency is now programmed into the scanner memory, and you can repeat the process to program any channel.
For more information on your scanner, you can download/print the operating manual here:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Apr 25, 2010 | Uniden BC60XLT Handheld Scanner
Scanner won't work
did you try the copier function?if you can copy documents then the scanner is good,well if it wont works you cant print neither..but as you said you get a print out.reinstall it carefully and slowly..the logic board has no problem,just focus on the driver..
Sep 08, 2009 | HP Officejet 5610 All-In-One InkJet...
I keep getting a paper jam, I don't know how to fix this,
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printer if the printhead is not moving to the center or if it is stuck on the right side
Hope this will help
Thanks
Byron
Aug 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My scanner wont work with vista
you may have to uninstall vita because some scanners are not for a particular problemm , they may be for a lesser programme see if it works
Jan 12, 2009 | Canon CanoScan D1250U2F Flatbed Scanner
Dont have the cd
Go to this website and you should be able to find all you need to be able to be in the printing game again :)
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128296&dlc=en&lc=en&cc=us
Angela
Aug 29, 2008 | HP DeskJet F380 All-In-One Printer
Deleting Files from spool after they have printed
see your Spool settings, Set Print directly option and try.
Apr 09, 2008 | Lexmark X6100 Flatbed Scanner
116 people viewed this question
jasbo
jasbo
