On Nov. 13 2008 I had to call the warranty people to cme and fix the sameproblem.On Nov. 13 2008 I had to call the warranty people to cme and fix the sameproblem.
You can't post conmments that contain an email address.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Around 5 gallons per FiLL more then 1 fill per cycle add up all the fills for the cycle that you use..that will give you the total water used...hope I helped thanks for voting...
Yes. On top loading machines, it is very easy to see. On front loading machines, not so easy to tell. Front load machines fill to a very low level, (which is why you should only use 1 to 2 tablespoons of HE soap with them) then when they begin to tumble (wash motion) the clothes absorb water, causing the water level to drop, resulting in the fill of additional water until the original water level is acheived again. This process generally takes several times to get all the clothes saturated and the water level to stabilize. Additionally, water valves may cycle on and off several times as the machine adjusts the water temperature, even if you were running an empty washer through a cycle. Gentle cycles will use more water, as more water = less abrasive scrubbing action. Normally, using front loading machines, you will not see much if any water through the door window.
these tips…
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it. Good luck!
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
