Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Fridge portion temp
Yesterday, when I cleaned my fridge I noticed the temp went up to 48 -50 degrees. I checked later and it was still at 48 degrees.
I emptied it and then thought I would try pressing the off button and allowed it to remain off for 2 or 3 minutes. I turned it back on and when I checked it this morning it was at 34 degrees. - exactly what I had set the temp. to be. The freezer temp has remained fine -of course -
Did I jsut reset it and everything is now OK?.
  • MaryDel Jun 09, 2008
    I didn't clean any mechanical areas of my Sub Zero. Only routine cleaning of crisper drawers, wiping off shelves etc.
    The door was open for a prolonged period of time. Usually the temp does rise a bit when I do this type of cleaning. This time tho, the temp went higher than normal 50 degrees and didn't go down.
    It wasn't until I emptied the fridge and thought to try turning it off and then back on again to see if that would do anyting.
    Do I need to call for service or have I corrected the problem? and what was the problem that turning it off and back on again corrected?
  • 1,031 Answers
Clean fluff from condensor, turn off overnight and defrost, turn back on following day and see how it is
Posted on Jun 09, 2008
    Master:
  • 638 Answers
Normally this is the procedure of reset for this type of problems and unknowingly you did the right thing and thats good.this type of problem occurs if the fridge is kept open for long time in the power ON condition the temprature of the fridge rises a bit and this whole procedure caused a problem to your fridge.so take care of this things and you can use your fridge freely its perfect.
rate this solution if you find it worth.
    Brigadier General:
  • 3,614 Answers
Have you just only clean the unit or you have defrost the fridge..?
    Guru:
  • 1,894 Answers
Try a reset
  • 1 more comment
  • dewan nafees ahmed Jun 09, 2008
    because reset makes u fine most of times
    it may also have been fine due to ur cleaning work.
    by doing which u may have cleaned the outlets and removed any dusts.
    but most of time reset makes everything ok.
    that is the reason u r on the right track now.
I have Kitchen Aid french door fridge with large temp fluctuation. Please help
Clean your coils first, if they are dirty from dog hair or lint in general it will overheat compressor and cause temps to fluctuate
Oct 17, 2016 | Refrigerators
GE model PDS22SFSALSS temp lights of the power control board blinking and clicking,what should I do
I have owned this fridge for less than 5 years. I had the same problem..very annoying...come to find out that the motherboard controlling the fan went bad. I will never own another GE fridge again, too many problems with GE. I paid for a sevice tech to come out and fix/replace the motherboard..$150.00 later and now the freezer portion doesn't seal and is always defrosting! I cleaned and checked all the gaskets, even cleaned the coils...still no solution. Time to put this dinosaur on craiglist and buy Samsung.
Jan 26, 2011 | GE PDS22SIS Bottom Freezer Refrigerator
Freezer temperature down to 6 degrees.. What should it be and how to fix it?
Hello your fridge should have a TEMP. DIAL located inside one of the doors or at the upper most portion of the fridge. You will need to adjust the dial to a warmer setting. Normally turning it COUNTER CLOCKWISE will increase the temp. You will notice the temp range by looking at the dial as it will be marked accordingly.
Jan 12, 2011 | Frigidaire Refrigerators
After a bottle of gin broke spilling it's contents in the upper portion of our bottom freezer Amana Model BRD18V2S, The refrigerator no longer gets cold, we have aired out the liquor fumes and although the...
My wife posted the information below and I would like to add more to the story: We have two identical Amana Bottom Freezer Refrigerators, Model:BRD18V2S installed in our Kitchen. Both fridges are in an alcove and stand next to each other. One fridge is used as the beverage fridge and othe other is used as a food fridge. At about 10pm she noticed that an entire bottle (600ml) of Gin had cracked and emptied into the refrigerator section of the fridge used for beverages. We do not know how long the spilled gin was in the fridge. She mopped it up and we went to bed. At 7am the next morning, the beverage fridge and its freezer were showing 71 Degrees F. and everythind including the ice had melted. (We have aftermarket external temperature gages that show the fridge/freesor temperatures) The food fridge uninvolved with the gin spill was reading 68 Degrees F
Sep 17, 2010 | Amana Refrigerators
Re: Tempurature Problems
The thermostat is likely failing intermittently, or the defrost timer could be failing.
Both parts can be tested (and should have been) by the repairman.
The defrost timer turns on and off to let the coils defrost - but if it stays off - can cause the rise in temperature. The thermostat, however, reports the temperature to the timer, so either (or both) could be to blame.
Have them tested.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
Freezer is not cooling
you may have defrost problem chech and see if you have ice build up back wall of freezer
Apr 06, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
GE Profile- Freezer/ Fridge at 56 wont go cooler!
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Aug 08, 2007 | Samsung RS2556 Side by Side Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
309 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
