My plasma is switching off after an hour and the screen is very warm is it the hot weather we are having
    Sergeant:
    Champion:
  • 326 Answers
U may have a problem with the display or....
Check the power settings in the control panel to make sure it is not set to blank, turn-off or put to sleep the display after one hour. Also when U reboot, goto the bios (F2 or del key) and check the power options there for the same things. If all looks good, have a repair shop check the display.
Posted on Jun 10, 2008
Philips 50 inch plasma black screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 07, 2017 | Philips 50PFP5332D 50 in. Plasma...
HOT SCREEN
Hello
Check the cooling fans at the top working well or not. If found damaged, replace it. It is normal that a plasma TV will heat up to an extent. If it overheats, cooling fans should be suspected.
Mar 02, 2012 | Panasonic Viera TH-50PZ80U Plasma TV
The T.V. suddenly turn off after viewing for about two hours. I turn the manual off/on switch but nothing happens. After about ten minutes when I turn turn on the remote control on, the T.V. turns on. ...
Yes this as been reported lot of time whit plasma ,that is because a over heat problem in the video processor especially in very hot weather period due to the cooling fan circuit where
is unable the cool down the circuit , some as put an external fan to blow air on the back panel slot, but you may need to verify the fan circuit inside the set to make sure its working properly......and i cant go so fare with this because i cant
troubleshoot the problem my self not from here..
hope that will give you an idea
regards Alan..
Oct 26, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
My 1997 tracer gets stuck in park in cold weather
replace the brake / shifter release switch under the column
Jan 13, 2010 | 1997 Mercury Tracer
Rear hatch will not stay open when weather is cold, temps below 45 affect the vacuum on the rear hatch. works fine in warm weather
Those little shocks are gas charged, thus pressure increases in hot, and decreases in cold. Over the years they tend to seep, or leak a bit, thus, only work good in warm/hot weather. They have replacement ones at autoparts stores, and shouldn't be too expensive.
Dec 04, 2009 | 1999 Jeep Cherokee
I have a Gateway gtw-p42m303 powers up to the warm up screen then light switches from green to standby orange. smells hot could be a power supply or capacitor?
Most likely a Y sustain module failure. Gateway does not make a set, so I would need a part number off of the board in order to give you an exact price of the part. Usually they're around $300.00
Nov 13, 2009 | Gateway GTW-P42M303 42 in. Plasma...
I have the same problem with my 98 accord v6. however it stalls more in warm/hot weather than in cold weather.
have a shop or dealership check ur fuel pump.. it is in the tank... so its best to let a shop do the work for u..if u dont have the expertise to tackle it urself... also try checking the ignition switch as well ...
Apr 03, 2009 | 1998 Honda Accord
Cigarette lighter adaptor becoming very warm in use
the lighter receptacle is dirty and needs cleaning
Mar 23, 2009 | Tomtom ONE XLS Car GPS Receiver
Rinnai r70e warm not hot
This's been a cold year!
Is this an instantaneous water heater?
If it's outside or on an un-insulated wall in an unheated area this could very well be all that's wrong with it!
Is your heater well insulated?
Are your pipes well insulated?
Is it in a heated area?
If not I would insulated it real good and try moving it to an area that's heated!
Has this been helpful?
Jan 21, 2009 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
My Samsung Plasma just got burned in!
I stupid friend of mine came over to feed my dogs when I was out. He watched my Plasme tv for a while and when he shut the system down he only turned the cable box off for opprox. 6 hours. I did have th Tv on pixal shift . Know my screen seams grainy in dark scenes . I does seem a little better after a rolling picture screen. How long do need to run the screen before it gets better?
Apr 02, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
