Toshiba 32A41 Front Cover Replacement
I am considering replacing the front cover due to cosmetic damage and while the part is still available. I have not opened the set as yet.
Is the front cover removable by itself or does it actually act as the frame/chassis for the CRT and other parts as well?
  • 4,234 Answers
The front cover assembly is available as part # 23530150 at a cost of $41.91 from tritronicsinc.com
Dan
Posted on Jun 09, 2008
Toshiba estudio233 say close front cover,where is the front cover?
Front cover is the cover u open to insert toner
The front cover & side cover is connected together via same switch, make sure is connected
If not switch problem, then probably the power supply issue
May 09, 2017 | Toshiba Office Equipment & Supplies
Close Front Cover For Toshiba E-studio 350
There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Dec 02, 2015 | Toshiba e-Studio 350 Copier
How to replace two of the shift solenoids on a Pontiac Aztek 2004
1-2 Shift Solenoid Valve Replacement ,same for other shift solenoids !
Remove the case side cover. Refer to Control Valve Body Cover Replacement . Disconnect the transaxle wiring harness.
Removal Procedure
  1. Remove the air inlet duct. Refer to Air Cleaner Assembly Replacement in Engine Controls - 3.4L.
  2. Remove the engine mount struts. Refer to Engine Mount Strut Replacement - Left Side and Engine Mount Strut Replacement - Right Side in Engine Mechanical.
  3. Remove the shift cable bracket from the transmission.
  4. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  5. Remove the left front tire and wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
  6. Remove the left engine splash shield. Refer to Engine Splash Shield Replacement in Body Front End.
  7. Remove the left tie rod end from the steering knuckle. Refer to Rack and Pinion Outer Tie Rod End Replacement in Power Steering System.
Remove the left wheel speed sensor harness connector (2) and the harness (1) from the lower control arm. Remove the left lower ball joint from the left steering knuckle. Refer to Lower Control Arm Ball Joint Replacement in Front Suspension. Remove the left stabilizer . Refer to Fastener Tightening Specifications in Suspension. Reposition and secure the drive axle toward the rear of the vehicle. Remove the trans mount nuts at the frame.
Caution: Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or damage to the intermediate shaft. This damage may cause loss of steering control which could result in personal injury.
Remove the intermediate shaft (1) from the steering gear (2). Refer to Intermediate Steering Shaft Replacement in Steering Wheel and Column - Tilt.
Support the left side of the frame with a utility stand. Remove the left side frame bolts. Use the utility stand in order to lower the left side of the powertrain enough to gain access the case side cover bolts.
Support the transmission with a transmission jack. Use the utility stand in order to lower the left side of the frame enough to access the case side cover lower bolts. Position the drain pan under the transaxle. Disconnect the transaxle wiring harness electrical connectors.
Remove the case side cover bolts (56-58). 56 are regular bolts ,58 are studs .
Remove the case side cover pan (53).
If not replacing the side cover, steps 24, 25, 26, and 27 are not required.
Remove the case side cover gasket (54). Remove the case side cover inner gasket (59).
Inspect the case side cover (53) for the following conditions:
Damaged or porous gasket sealing surfaces
Damaged or porous casting surfaces
Damaged or stripped bolt holes
Inspect the case side cover gasket (54) and case side cover inner gasket (59) for damage. The gaskets are reusable if they are NOT damaged. Clean the case side cover gasket surfaces
Install the 1-2 shift solenoid (315A). Connect the transaxle wiring harness. Install the case side cover. Refer to Control Valve Body Cover Replacement .
Important: It is recommended that transmission adaptive pressure (TAP) information be reset.
Resetting the TAP values using a scan tool will erase all learned values in all cells. As a result, The ECM, PCM or TCM will need to relearn TAP values. Transmission performance may be affected as new TAP values are learned.
Reset the TAP values. Refer to Transmission Adaptive Functions .
Good luck , this job is a real pain in the ***
Aug 25, 2015 | Pontiac Cars & Trucks
Toshiba 32A41 32" TV - I turned the TV off at the power switch on the front of the TV. The solid red LED turned off as it has for 12 years. NOW, neither the remote nor the power switch on the front of
Sounds like the power supply is down mate unless it's just a fuse replacement it's probably more cost effective to buy a new one.you could try gumtree or eBay for one with a damaged screen.
Dec 01, 2014 | Toshiba Televison & Video
How do I remove the hard disk of Toshiba laptop?
Hard drive replacement on this unit is quite easy. Turn the machine upside down, and with power removed (battery and AC adapter disconnected) remove the two screw holding the HDD cover in place (right side of laptop near the front). Remove the cover and then remove the single screw holding the drive in place. Slide the drive out. Replacement is the opposite of removal.
Oct 04, 2014 | Toshiba Satellite 4030CDT Laptop Universal...
I am trying to find a replacement part: The rubber cover that protects the housing for the front wheels of the Aspire "Quickie" power chair.
The front rubber cover and bracket for the Aspire front wheel is part #561670 and the list price is $160. It is available from Sunrise Medical at 800-456-8165. I replace these quite often because they wear out. The components underneath tend to be sharp and can cut your foot and ankle. I am afraid that this part is available only from the manufacturer.
It is possible to use a rubber inner tube or large rubber hose to cut and shape a replacement part if you are inclined to save a little money. I don't know how well this would work in practical use. Hope this helps.
Dec 27, 2010 | Health & Beauty
One jewel fell out can i get a replacement
The short answer is no.
You might find a specialty shop that would have a replacement but my experience has been that you will need to get a replacement band or case from Fossil . You will end up paying for this because Fossil's warranty doesnt cover cosmetic damage.
Sep 15, 2009 | Fossil Metal Dress Marissa ES1512 Watch...
Well, i lost the front of my tv moving it. it was destroyed, now i'm looking for a replacement but don't know what it's called. could someone tell me? is it the screen? Panel? I don't have a clue, searched...
if it's the lower front, then you need the speaker grill, if it's the upper front then you need the screen assembly, if it's the middle front, then you need the control assembly, these are very common tv's, you could probably pick one up off craigs list or some websight just like yours but don't work and get the housing parts cheap, new, they might not be available since they are considered cosmetic parts and are discontinued early on in the life of the set.
Sep 07, 2009 | RCA D52W19 52" Rear Projection Television
Toshiba laptop black screen
The backlight on your display is not working, which is why you can dimly see the icons. Power for the backlight comes from a small board called an inverter which is mounted in the bottom edge of the display. It is a common problem for these inverters to fail. There are replacements available from vendors online, and installing the new board is usually a simple job.
In your case, the inverter problem may be due to the hinge trouble you have. The twisting force that damaged the case may also have broken the inverter board or caused its power connection to pull loose. Or the inverter trouble could just be a separate problem. You would need to open the display to check.
There are screws through the front and the front cover snaps in place. Remove the screws and the front cover and you will see the inverter board under the display panel. There are connectors at both ends. One is the power for the inverter and the other is the connection to the backlight. Make sure they are seated and that there is no visible damage to the inverter board.
Replacement hinges may also be available for your computer. Search for them and an inverter by looking for your paticular model.
Apr 01, 2009 | Toshiba Satellite L15-S104 Notebook
Require a new top cover
As always you can count on E-bay for computer parts. I purchase cosmetic replacement parts all the time from the site. You can usually find complete covers and add on covers.Here is just one that might help.
http://cgi.ebay.com/TOSHIBA-SATELLITE-A100-LCD-TOP-COVER-PANEL-V00060150_W0QQitemZ120360429639QQcmdZViewItemQQptZLH_DefaultDomain_2?_trksid=p3286.m20.l1116
Jan 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
Televison & Video Logo
Top Televison & Video Experts
