Question about Whirlpool Refrigerators
We have a Whirlpool gb22dk refrigerator freezer. The bottom freezer keeps meat frozen but will not keep sea food ice cream bread ect frozen. This fridge came with our house which we purchased 2 years ago and is about 4/5 years old. This problem only started a couple of days ago. We normally kept the freezer at about 4/5 on the dial but last night turned it up to max and at noon today more of the sea foods had thawed. The ice cube tray remains frozen. Please help
  • ckmoore2004 Jun 12, 2008
    There was quite a bit of dust under the fridge but cleaning it out didn't seem to help so we have had to get a repair tech in after all
    Tks for trying
  • Anonymous Mar 24, 2014
    my stand up whirlpool freezer is not freezer top half and only freezing bottom half and alarm is going off
  • 868 Answers
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Posted on Jun 09, 2008
    Scholar:
  • 75 Answers
Make sure that the food is not packed too tightly, and the cold air can circulate, and that the door seals are tight, to keep the cold air in. Also make sure that you do not have an ice build-up that would block cold air circulation, or that the cool air intake is not blocked, especially by ice build-up. Ice build-up can happen on hotter days when the door is getting opened alot (also interfering with keeping the cold air inside the freezer altogether).
The freezing point for ice cubes is 32 F, while other foods require colder temps - especially those that have fats, like ice cream.
If you verify that the air is moving successfully and the gasket around the door is tight, and if the setting is low but still not sufficient to keep the foods cool, you may need to call for a repair.
My freezer only freezes certain food. All the
Get a freezer thermometer and ensure the temp is turned down to between 0 and 10 degrees F.
Oct 05, 2014 | Refrigerators
Lg lbc22518ww bottom freezer not keeping food frozen
door seals may be bad. check for cold air leaking especially on the corners and the hinge side.
Feb 28, 2014 | LG LBC22518 Bottom Freezer Refrigerator
Freezer does not keep ice cream frozen
You are having a problem with one of the three main components of the the defrost system. Look into rear of your freezer to see if ice and frost is beginning to build up on the rear panel. If yes begin manual defrost by unplugging and remove contents of freeze. Even better send me the model number of your Whirlpool. That is how I tell you were the problem began most likely. Look around the door frame and inside the fresh food section sea Breeze
Apr 12, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice in the freezer side bottom of my side by side Maytag.
You are having either a defrost problem combined with the defrost drain being frozen over. Need to unplug and remove the rear panel in back of freezer to examine exactly what is happening. Some models like yours have electronic vents that cole if the control becomes defective. . The other possibilities ar the
Adaptive Defrost part number 61005988
The defrost heater with defrost thermostat part number 61006199
Visit our site or click on your model number or part number. I will be here to assist you in your repair, Thanks Sea Breeze
Click Here=> PART NUMBER AND MODEL SEARCH FEATURE
Aug 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
My ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Has just one termostat on bottom, freezer won't keep ice cream frozen, although it does keep meat and ice froze
OK send me the model number as found in photo below. You may have a circulation problem that I will be able to look over closer when I have model number. Sea Breeze
http://servicepartstec.blogspot.com/
May 25, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Freezer is not working to optimum capability. Meats and frozen foods harden, but ice cream and breads do not. I have the temperature control to almost maximum. Any ideas?
remove bottom kickplate and clean condensor coils, pull away from wall and vaccuum behind and underneath. if the machine cant breath, it cant cool properly
Mar 05, 2008 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
525 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
