Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
HD doesn't show up!!
I have a simpletech pininfarina 500GB external HD that I use with my Macbook. Sometimes it decides to show up when it's plugged in, but more often than not it's like it's not even there. Which really bites, because all my music is stored on there. What do I do?? Why does it only work half the time? I need my tunes!!
Thanks,
Alana
MissCherryBombDesign@gmail.com
  • keric1154 Jan 17, 2009
    I am having the same problem except my computer is not a mac, but an HP Pavilion tx1000 tablet. I tried to check the USB root hubs to see if they were shutting off when not in use. They were, but I fixed that and the drive is still going in and out of recognition, sometimes within a few seconds. The drive is fairly new, it's just about a year old. can anyone help??
    Sergeant:
  • 369 Answers
Hi
please goto utilities and diskutilities and check the dd is shown over there if yes just try to select the hdd an verifiey the hard drive and say repair it should be fine unless there is any hard ware problem
thanks
Posted on Jun 16, 2008
  • DUSHYANT SINGH
    DUSHYANT SINGH Nov 12, 2008
    HI
    please check the disk utilities and see if the hard disk is getting over there and u go to first aid forlder select your hard drive the simmple tech and say verifye disk and it should get mounted and also inthe mac book pro the usb ports onyour right hands side dosent detects the hard disk some times alwys use the left hand side usb ports and should work..
    other thing if its always doing the same please copy your data to another hard drive and reformat the harddisk as mac os journald so u dont face the problem again again ....
    thanks
  • 3 Answers
Simple solution, IF IT WORKs
I have had this problem with a SimpleTech 1TB SimpleDrive external hard drive with USB connection to a MacBook, and found this solution in another forum. It's simple if it works, but don't spend too much time with it if it doesn't -- it's then a more complicated situation that other folks' answers (here or elsewhere) address.
1) Power off the computer.
2) Power off the SimpleDrive and disconnect it from the computer (or just disconnect it if your drive [like mine] doesn't have a power switch).
3) THIS IS THE KEY STEP! Unplug the SimpleDrive from it's power supply.
4) Wait a minute or a few [sorry, I haven't timed it] with everything powered down, especially the SimpleDrive disconnected from power and computer.
5) Reconnect everything as usual: power up the computer, reconnect the SimpleDrive to its power supply, reconnect the SimpleDrive to the computer.
6) If it works, good. If not, try other posted solutions.
Why I think this works.
a) My SimpleDrive does not have an on/off power switch, so the drive is constantly on, even though it doesn't indicate this in any way when it's not plugged into a computer. (The drive is constantly on to detect when it has been connected to a computer.)
b) The drive gets into a bad state [the drive's internal software gets confused], which is solved by rebooting the drive. Since there's no on/off switch, you have to unplug the drive from power.
Part of the "simple" of my SimpleDrive is not having a power switch, but rather the drive's detecting the USB connection to a computer. But SimpleTech's driver software is faulty in being able to get into a bad state that can only be corrected by fully powering down, which only happens when fully disconnected from power.
And this is a hard solution to find because we've been trained to use the on/off switch to power things down, not unplugging them. Way back when, since programming microprocessors, I've discovered that some computer problems are only solved by turning the durn things off. The high tech version of banging on them with a hammer til they work.
Good luck! I keep my SimpleDrive disconnected from power whenever I'm not using it, and this problem has gone away for me.
Posted on Feb 26, 2011
How do i get a copy of the manual?
You may find the info you need here. Hard drives come with the barest of information
http://www.hgst.com/support/faqs/external-drives-faqs/simpletech-faqs/simpledrive-pininfarina-faqs
It does not appear they offer the manual on the site.
Jan 18, 2015 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
I accidentally plugged my laptop cord (19v) into my Simpletech pininfarina 500gb external hard drive (12v). It was only plugged in for about 20 sec and the HD power light was slowly blinking. I...
Your hard drive is probably dead. However there are stillhopes for hard drive datarecovery.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezingsometimes works to revive a dying hard drive, at least for a shorttime(Probable just about 20 minutes), but be sure that the bag is sealedtightly so that condensation and ice crystals don't form. Put it in yourfreezer for 24 hours that will do the trick. While it's still cold, plug itinto your computer. And you may be able to view it in 'my computer'. And youmay act quickly, because you may only have 20 minutes to recover your data offit and after that the hard drive is completely dead.
If it fails, you will have to go to a recovery office where supply datarecovery service but let's hope not because it will cost you a lot of money andwhether they can recover data is not guaranteed.
Here is a tutorial to guide you how torecover hard drive data.
Aug 31, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Not recognized
Make sure that the connectors are inserted properly. Try another cable or see if it mounts on another computer. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 07, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
My SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive suddenly disconnects a Reconects again....
You may have a power supply that is defective or is failing. Try another power supply, 12V, 2A, center pin positive.
Jan 24, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Lost instruction booklet fo simpletech 250 ex hd
The drive is USB. To access the drive, plug it into a USB port of the computer.
The drive should be recognized by the computer.
I am not sure about Simpletech, however, most drives do not have an "instruction book".
What are you looking for in this documentation?
Dec 14, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
774 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
