Question about Denon AVR-1706 Receiver
Avr1706 The unit will not power up.
I have unplugged it and plugged it back in with no luck. There are no lights showing at all. Is there a fuse that I should look for.
  • 682 Answers
Check power cord first-apply spray contact cleaner in on-off switch and press it many times.
Posted on Jul 12, 2008
Dryer will not start
If you manually turn on timer can you hear the faint ticking? #1Verify breaker is not tripped. #2 Unplug dryer. Remove back cover. On many makes there are 2 blue wires that connect to a white and black "fuse" towards the bottom of the unit. Unplug both wires and electical tape them together. plug in dryer and start the cycle. If it works, unplug and go buy the fuse. Clean lint out of air system from dryer to lint screen through exhaust.
Jan 09, 2014 | Dryers
My one year old 8000 BTU GE window unit will not turn on. The electricity was going off and on so I unplugged the air conditioning unit off. Now it will not come back on. The green light on the plug is on...
Is the display panel lit up? If not look for a fuse mounted on the board.Take the fuse to radio shack and get another. Unplug the unit before attempting to service it.
Jul 09, 2011 | Heating & Cooling
How do you change the fuse?
I guess you checked for power at the outlet. First unplug unit. Second hang plug where you can see that you've unplugged unit, and that you can see that it's still unplugged when you come back from whatever interruptions that will occur.
Take off the long vent above the door. That will expose the screw holding the control panel on. Remove that screw and lift the control panel straight up to expose the innards. The fuse will be a light gray or white ceramic piece with silver on the ends. Once it's out check the silver end for the amperage rating, ie 20A or 18A.
Replace with a ceramic fuse with the EXACT SAME VALUE. Still see the plug? Reverse the order to reassemble. Test run. If the fuse blows again the unit will have to be opened up for component/connection checks. The fuse will probably cost $3.00-$5.00, just so you're not suprised.
Hope this helped, and good luck.
fil
Mar 02, 2011 | Frigidaire FMT116E1B Microwave Oven
My str-k502p stopped showing the lights on the front. everytime i plug it in it makes the clicking sound like its on but nothing shows up. when i try pressing the power button all that happens is the...
Check fuses on unit .Fuses should be on right side of amp .If all fuses are okay.If a fuse needs replacement .Replace with same type and always make sure unit is unplugged .Its possible unit needs repair
Jul 20, 2009 | Sony Audio Players & Recorders
Ford 6006e rds eon cd radio - won't switch on
remove the head unit from the dash, unplug the main connector from the rear and then plug back in. the unit seems to reset itself and asks you for the security code, should work afterwards. must be common fault as ford dealer new exactly what to do when i took mine in.
Apr 01, 2009 | Car Audio & Video
Kenmore elite microwave
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Jan 28, 2008 | Kenmore 62702 Microwave Oven
Optiplex GX260 won't boot
I had the same issue and accidentally discovered a temporary solution. Unplug the power from the back of the machine, open the case and unplug the ATX power connection from the motherboard. With the ATX cable unplugged, plug the power cord back in. When you try to turn the computer back on the power light should turn orange and fans should be spinning, with it powered on plug the ATX connector back in. That should turn the computer off. Turn it back on and it should boot fine. You can even shutdown and restart, but when the power is unplugged you will have to go thru the same process to get it back up. This sounds crazy but it worked on mine. Good Luck!
Nov 01, 2007 | Dell OptiPlex GX260 PC Desktop
Hitachi 60FX20B
If you hear the unit comming on and theres no sound or Picture, then theres a fault in the horizontal sweep/HI Voltage circuit. This should not be fooled with unless you know the safty issues with HI voltage as theres voltage in these sets even after they are unplgged for a while. Good Luck
Jul 06, 2006 | Hitachi 60FX20B 60" Rear Projection...
Unit will not power on, has the standby light on
I took your advice I unpluged the unit then held the power button in then pluged it back into power outlet the unit came on. There is one thing I might add I had to do it twice before the unit came on. Now how long will it work? Who knows
Jun 06, 2006 | RCA RT2500 System
Denon AVR-1706 Receiver Logo
81 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
