Question about Zanussi ZWF1430W Front Load Washer
Stoped machine washing machine stoped in wash mode now I have a machine full of water and clothes, will not work on any programe/
  • 66 Answers
If you still have power then it sounds as if your pump may be blocked
Posted on Jun 15, 2008
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
How do i fix my washing machine,it only drains water instead of washing clothes.
call a service technician as it may be a faulty program board
Nov 20, 2015 | Washing Machines
Washing machine washes then will not spin HELP HELP dirty clothes
When you set "the timer to drain and spin only". After "drain" program finished - not pump or motor sound or all sound stoped, the machine is freeze?
The meaning is sometimes, the sensor of water level doesn't working properly. The "drain" program is keeping running.
May 27, 2017 | Washing Machines
Error nf code
That code is the no fill, or no water code. Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water which in return will give you the nf code as well. What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness.If both those are good somewhere inside the body of the machine is a tech guide which will tell you how to go into diagnoistic mode and run test on every part of the machine to narrow down the actuall problem.
Apr 29, 2012 | Amana 3.5 Cu. Ft. Front Load Washer...
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
I purchased a whirlpool washer (model # WTW5600SQ) in 12/07 and the spin cycle does not effectively remove enough water from the clothes. The clothes,after the spin cycle completes, are still very heavy...
Hi Tim, Check the filter to see if it blocked .. also, take note to see if the machine is gathering a full spin speed, if not, you may need new brushes in your motor
Aug 21, 2009 | Washing Machines
Zanussi ZWF1430W Front Load Washer Logo
66 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
