Question about Kenwood DNX7100 Car Video Player
Region problem Hi I have problem , I need to change the unit to region 2 from region 1 (dvd) and the frequency, step from 200khz to 50 khz (tuner) please help me . benny DNX 7120
  • dr_benny Jun 15, 2008
    Hi I did not get any solution yet
    How can I programming jig to change region ?
    Guru:
  • 1,894 Answers
Check out this page
read post7
Posted on Jun 15, 2008
  • dewan nafees ahmed Jun 15, 2008
    the service manual calls for a programming jig to change regions.
    also not heard that these can be hacked to region free
    Master:
  • 555 Answers
A manual for your player can be found here.
Posted on Jun 09, 2008
How do I change language on pioneer deh4600bt
Section
02
Using this unit
(iPod control)
c
This unit's iPod function is operated from your
iPod.
d
(Bluetooth indicator)
Set up menu
After installation of this unit, turn the
ignition switch to ON.
SET UP appears.
Turn M.C. to switch to YES.
# If you do not use the unit for 30 seconds, the
set up menu will not be displayed.
# If you prefer not to set up at this time, turn
M.C. to switch to NO.
Press M.C. to select.
Follow these steps to set the menu.
To proceed to the next menu option, you need
to confirm your selection.
LANGUAGE (multi-language)
This unit can display the text information from a com-
pressed audio file even for information embedded in
English, Russian or Turkish.
! If the embedded language and the selected lan-
guage setting are not the same, text information
may not display properly.
! Some characters may not be displayed properly.
1 Turn M.C. to select the desired setting.
ENG (English)-??? (Russian)-TUR (Turkish)
2 Press M.C. to confirm the selection.
CLOCK SET (setting the clock)
1 Turn M.C. to adjust hour.
2 Press M.C. to select minute.
3 Turn M.C. to adjust minute.
4 Press M.C. to confirm the selection.
En
FM STEP (FM tuning step)
Use FM STEP to set FM tuning step options (seek
step settings).
1 Turn M.C. to select the FM tuning step.
100 (100 kHz)-50 (50 kHz)
QUIT appears.
! The manual tuning step is fixed at 50 kHz.
! When AF and TA are turned off, the seek step is
fixed at 50 kHz even if set to 100.
5
To finish your settings, turn M.C. to se-
lect YES.
# If you prefer to change your setting again, turn
6
Notes
! You can set up the menu options from the sys-
tem menu and initial menu. For details about
the settings, refer to System menu on page 19
and Initial menu on page 23.
! You can cancel set up menu by pressing SRC/
OFF.
Basic operations
Important
! Handle the front panel with care when remov-
ing or attaching it.
! Avoid subjecting the front panel to excessive
shock.
! Keep the front panel out of direct sunlight and
high temperatures.
! To avoid damaging the device or vehicle inter-
ior, remove any cables and devices attached
to the front panel before detaching i
Feb 08, 2015 | Pioneer Deh-5400bt Car Stereo...
FM frequecy increases/decreases too mugh pr. step
Hi, Your post/description "the frequency increases in steps of .2 Mhz or 200Khz" refers to the increment of frequency spacing between tuning steps and is largely dependent on the radio standards of the country/region the radio is intended to be used. Assuming no hardware fault to the radio, tuning steps may be adjusted by: 1. With the radio switched off, press the Step/Band button for about 2 seconds. This will display the current FM tuning step (200Khz as in your case); 2. With the radio switched off, press the Step/Band button for about 10 seconds. This will display FM and a blinking 50Khz with a single beep sound. By rotating the Tuning Control you can increase or decrease this value. 3. pressing the Step/Band button again will move you to the tuning increments of the AM band again adjustable via the Tuning Control. 4. pressing the Step/Band button again will save the setting and complete the process. Hope this be of some help. Good luck and kind regards.
Sep 13, 2007 | Makita BMR100 Radio
I cant tune in to AM radio stations like 873 2GB it only increments in units of 10 so nearest is 870 or 880. Is there a solution??
You would think a radio as versatile as yours would be able to tune to a specific frequency but you are experiencing one of the shortcomings of digital tuners. Some radios allow selection of 9 KHz or 10 Khz channel spacing on AM but that is not the answer for your particular problem.
Dec 10, 2014 | Jensen AWM975 AM/FM/CD/DVD/USB/WB/iPOD...
Pcm 48 khz
mine does the same thing. I found a pdf of the manual and it said this in the troubleshooting section:
""PCM--kHz" appears on the display. , The sampling frequency is more than 48 kHz. Change the DVD setting to 48 kHz."
I have my seiki tv hooked into the dvd/ld input through a coaxial cable, and I don't think my tv has a setting to change the sampling frequency. so I have no idea what to do. any help would be great!
Jan 15, 2014 | Sony STR-DE445 Receiver
Ft 2900r yaesu all i see on the screen is B0001 i can't see the frequency
Try powering the unit up while holding the Set/MHz button. I did that and it restored the display (and the rest of the radio's operation) back to normal.
The character codes are test-mode displays that correspond to frequencies (in MHz):
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
I haven't the foggiest idea why this isn't in the manual somewhere, or at least flipped back to normal by a two-key or three-key reset. 73, k2mct
Sep 16, 2012 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Can only receive forgein channels
See the swection on "Listening to the radio" on page 24 of the manual...
http://www.retrevo.com/support/Onkyo-TX-SR500-Receivers-manual/id/365ag205/t/2/
You can switch the AM band tuning steps between 9 kHz and 10 kHz.
The initial setting is 9 kHz. Please set the AM tuning step frequency to match the AM band tuning step frequency in your area.
USA and Canadian models 10 kHz
Other models 9 kHz
Press MEMORY while holding down TUNER.
Note: All the preset stations are erased when you switch the AM band tuning steps.
Oct 07, 2011 | Onkyo TX-SR500 Receiver
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
Region problem
Try this for the tuner fix. Turn unit on.Hold down (volume down and SRC )buttons and unit will power off.Keeping them in also press and then release the reset button(bottom right hand side) .Release the other 2 buttons and unit should now restart with 50khz fm spacing and 9khz am spacing.If you find out how to change region code,Post It
Jun 09, 2008 | Kenwood DNX7100 Car Video Player
Frequency increases/decreases in steps of 0.2 kHz
Hi again, Seems you posted twice. A copy of my reply to your other post.... Assuming no hardware fault to the radio, tuning steps may be adjusted by: 1. With the radio switched off, press the Step/Band button for about 2 seconds. This will display the current FM tuning step (200Khz as in your case); 2. With the radio switched off, press the Step/Band button for about 10 seconds. This will display FM and a blinking 50Khz with a single beep sound. By rotating the Tuning Control you can increase or decrease this value. 3. pressing the Step/Band button again will move you to the tuning increments of the AM band again adjustable via the Tuning Control. 4. pressing the Step/Band button again will save the setting and complete the process. Hope this be of some help. Good luck and kind regards.
Kenwood DNX7100 Car Video Player Logo
126 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
