Question about Compaq tc1100 Tablet PC
TC1100 keyboard replacement info
I recently spilled a drink and apparently fried my keyboard. I've bought the replacement board in lieu of the whole keyboard assembly. I tried to disassemble the keyboard assembly by taking out all the screws, but something is still holding the case together at the rear of the assembly (where the docking bar resides). I'm reticient to just pull it apart and wondering if anyone has had one of these puppies apart before and how I go about "releasing" the enclosure.
  • Bob Copp Jun 09, 2008
    Unfortunately, these manuals do not show how to disassemble the keyboard assembly. They show how to take everything else apart except for the keyboard. Thanks anyway.
  • javiercampil Sep 15, 2009
    I have the same problem, Did you solve it? How?
If you are replacing the keyboard component (i.e. the actual keyboard) the process is straightforward. You will need jeweller screwdrivers as the srew (torque and philips are quite small):
1. remove all outside screws on the back of the keyboard
2. as per wkuk above you (thanks!) you will see 4 small covers
3. Pop the covers off with a pin they are lightly glued on
4. Remove the 4 screws (philips head)
5. Turn the keyboard so the keys face the table
6. Separate the case exposing the back of the keyboard
7. There are two screws that need to be removed that hold the keyboard in
8. Remove the tape that holds down the ribbon cables
9. Two ribbon cables attach the the keyboard. Be VERY careful and disconnext the slim one from the existing keyboard. Disconnect the second cable from the keyboard body (as the kew keyboard will plug in there.
10. Remove the keyboard and replace with the new keyboard
11. Reverse the steps above.
The real key is to be careful with the cables. Hold the entire cable firmly as these types of connectors can tear. When you initially slowly remove the cables you will gain some idea of how far the cable goes into the connectors. Although I've done lots of fixes on hardware this was my first time doing my keyboard for my TC1100 and the start to finish was 15-20 minutes. If in doubt, take a phot of the keyboard after you've removed the keyboard.
Posted on Dec 26, 2009
At the back of the keyboard, you should see 4 dots in the area where the screen turing. Remove each cycle tap with a pin and you will see the screw. Once you unscrew them, you can reach the keyboard.
I have the same problem with my HP TC1100 and want to purchase a keyboard, can anyone provide me with the company, phone number and address on where I can make my purchase?
Posted on Nov 25, 2009
I have the same problem. Did you solve it? How? HELP ME, please
Posted on Sep 15, 2009
  • 191 Answers
Log on to this link
scroll down to
Service and maintenance information
there you have manuals available
Posted on Jun 09, 2008
I would like to know how to disassemble Compaq TC1100. Disassemble keyboard from screen unit.
There is a latch that you need to pull to seperate the keyboard base from the slate tablet pc. This latch is located behind the monitor where the keyboard attaches to the monitor.
Feb 26, 2011 | Compaq tc1100 Tablet PC
Wasted water in my hp tc1100 pc, now it will power up, but black sceen
either bake the board in an oven at 350 f for 10 minutes, let it cool, or replace the motherboard.
Mar 03, 2010 | Compaq tc1100 Tablet PC
My keyboard broke and since I can it take it off, id like to know where I can buy a replacement I don't want a regular keyboard, I want the same one that came with the computer. help?
You can't buy a new keyboard ecause they stopped making it since 2005 but you can buy an old one. I think the best place to buy it is ebay, you can get one for quite cheap.
Oct 29, 2009 | Compaq tc1100 Tablet PC
Tc1100 Blank Screen
You have identified your problem/fault by plugging in an external monitor and the image is OK. This proves the video card is OK and the fault could be the inverter or most likely the CCFL lamp.
The flickering screen indicated the CCFL lamp is faulty, it is a mini fluro tube which provides the back-light to the LCD. The inverter supplies high voltage to the CCFL lamp. It could be faulty and it is easier to replace.
For service, parts and DIY info check out LCD Parts - use this link to their WEB site : -
Oct 10, 2009 | Compaq tc1100 Tablet PC
Toshiba R100 keyboard not working
I did the same some two years ago, with the R100 on. I switched everything off, dismounted the computer body (not the screen)up to the last screw, and dried that sweet coffee from everywhere where I found it. Mostly this was the keyboard and mouse. The motherboard is luckily protected by some plastic sheet.
Regarding the keyboard, after disconnecting it from the motherboard, I washed it completely under flowing water and then let it dry for several days. In the meantime, I used a USB one. Since then, I used the same keyboard for two years until now, when it died, apparently rather from some motherboard-related reason than water. So I think - you may get a new keyboard, but if youre lucky, you may as well revive this old one.
Jan 07, 2009 | Toshiba Portege R100 Tablet PC
TC1100 checkered screen
Could be a bad ram chip as video uses the system board ram for video. You will have to crack the case and swap the ram for a known good stick. Be very careful!
Unfortunately the onboard video card may be bad, usually the problem.
I could crack it and check it for you, you pay shipping. I have the RAM.
Contact me at with "TC1100 repair" in the subject line.
I love the machine and you shouldn't have to pay a fortune to get an opinion.
I don't offer this service to any other group, machine or etc. Just the tc1000 and tc1100.
I'll answer your email and suppl contact info. I've been into several of these machines, no worries Mate.
Central Missouri, USA
Sep 20, 2008 | Compaq tc1100 Tablet PC
Tablet Keyboard not working
You may have a damaged (Physical) connection. If you know of someone with a tc1000 or tc1100 keyboard, try a swap to rule this in or out. The keyboards are interchangeable. I have several of both and have done this all the time.
Someone trying to "help you" close your "Laptop" could have damaged the connector at the Main board by trying to fold the tablet screen down like a laptop.
Might be a good time to clear static and reformat too. Cures a world of ills, just takes time.
Pull the battery, Pull the AC power, hold the power switch on for 30 to 40 seconds, and release.
Back up all your good data.
Try a restore, just for grins.
If no go, then do a complete reinstall of the factory image. You will need a USB keyboard, a dock with a cd drive or a USB CD drive, Restore discs (cheap from HP if yours are gone missing) and some time.
Install disc 1, follow the prompts through disc 2 and 3.
Follow on screen windows setup stuff when XP starts.
Go to "start", "all programs", "software set up" and install all the software they offer you.
Go to and download some free antivirus for now.
Shut down the PC
Try your keyboard.
Either way you will need to go to "windows update" from tools menu in Internet explorer and install updates, service pack 2, etc.
Best of luck, I really enjoy my tc1000 and my tc1100. Wouldn't know what to do without them. I put a 120GB drive in my tc1000 then later moved it to the 1100 (must reformat) and keep many shrunken movies, Office 2007, and lots of tunes on it. I put the 40GB from the 1100 into the 1000 (must reformat- operating system differences) and all is well. I've been into 5 tc1000s and they all worked when I was done, so let me know if you need more help.
I hope this isn't too late.
Feb 29, 2008 | Compaq tc1100 Tablet PC
TC1100 onscreen keyboard.
Use a USB keyboard and do a system restore.
Use a USB keyboard to access and search for a download there.
Use a USB keyboard to backup, reformat, reinstall factory image.Takes longer, but probably best overall fix, HDD may have a few bad sectors and format will fix or avoid them. May be a great time for a 7200 RPM drive and some more RAM! 2Gb RAM and a high speed drive will breathe a bunch of life into a great tablet like the tc1100.
Feb 03, 2008 | Compaq tc1100 Tablet PC
Chequered screen
I fixed mine finally!!! I ordered a cable kit and replaced the cable from the display to the motherboard (I actualy replaced them all but that one was the culprit.) Also, I learned that if you put the cable in backwards :) into the motherboard, it will appear very dim as it did with the bad cable. I believe that this is because the backlight inverter is not active, which in other posts here, may mean that the inverter is bad. Just a thought...
Dec 18, 2007 | Compaq tc1100 Tablet PC
Key board problem
check you keyboard in Regional settings and see that it is set to a 101 type (US or Aust) otherwise key location can change,also are you talking about Shift Keys or the Up/Down, Left/Right scroll arrows, let me know, otherwise something has gone arye on the keyboard itself.
Dec 12, 2007 | Compaq tc1100 Tablet PC
Compaq tc1100 Tablet PC Logo
1,685 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
