Question about Apple iMac G5 Desktop
DVD coding for mac computers
Is it possible to reset the dvd coding of my iMac? I can only change the drive coding 2 more times so would like to reset it to the factory maximum.
    Problem Solver:
  • 5 Answers
Http://superdrive.cynikal.net/
If not download VLC player. (Video Lan Client)
Posted on Jun 23, 2008
Brand new apple dvd drive will not accept dvd
The DVD works by just pushing it in far enough till you get resistance, then the drive pulls the DVD in by itself. If after it pulls the DVD in, it just ejects it, The DVD drive thinks you are using an incompatible disk.
You can also try resetting the SMC.
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 24, 2014 | Apple MacBook PC Notebook
Just got an lg ge20 not working on mac
I wish I could tell you that your Mac is compatible with the LG GE20 20X DVD Burner but unfortunately it is not.
Here are the system requirements for this burner
LG GE20 20X DVD Burner Technical Specifications
The CD included is not the only item that is not compatible with the Mac, it is also the DVD burner itself. It is only windows compatible I'm afraid.
However, I do know that the Apple.com online store, has a comparable DVD+RW burner, the
LaCie 22x d2 DVD+RW with LightScribe
which will work with your iMac.
This is a genuine incompatibility issue.
If you had an Intel iMac, there actually is a workaround process where virtual machine software, like VMWare Fusion or Parallels, could be installed, with a version of Windows XP, Vista, or 7, display as a 2nd terminal within a Mac OS X desktop.
What's makes this effective, is that the LG GE20 could work with a windows virtual machine and because software like VMWare for example, can share devices, including optical CD/DVD drives, the Mac could share that drive with the windows virtual machine.
But since you do not have an Intel iMac, unless I am reading the description of your Mac computer(Apple iMAC Mac Notebook) incorrectly, the LaCie burner information, I provided above, would be the best option for your model of iMac.
Again, if I have described your model of Mac incorrectly let me know and I will be glad to assist further.
Regards,
-Mactechtrainer
Feb 01, 2010 | Apple iMac Notebook
Sims 3
No problem.
Here is what you need to know:
The regional code for the US is (1).
You can change your DVD Region code up to 5 times on your Mac.
Review the information on DVD Regional codes via this Apple Support link to change the region code:
DVD Region Codes - DVD Player
Let me know if this Apple data helps!
Regards,
-Mactechtrainer
Jan 29, 2010 | Apple 24" iMac Desktop
My 20 inch imac wont stop trying to eject stuck dvd
not if you don't want to ruin the warranty.
maybe a certified repair shop can replace the drive for you.
Aug 02, 2009 | Apple 20 iMac - Intel Core 2 Duo 2.66GHz,...
Dirty DVD Drive?
You can clean your DVD Drive by inserting the Disk Cleaner its either dry or liquid cleaner. If you don't have a disk cleaner just purchase it in the store near in your neighborhood. In that way you can clean the DVD Drive Laser eye and make it possible to read another disk next time you used. Usually it takes 15 minutes the standard cleaning time if you are cleaning the DVD Drive to ensure that it is properly cleaned. Also if it doesn't work then probably you can find a technician and let it check to the technician. I hoe that the laser eye of your DVD Drive is not damage due to some disk you inserted earlier.
Hope this recommendation helps solved your problem.
If you need more assistance just reply to this post. thanks
Jun 26, 2009 | Apple 24" iMac Desktop
My DVD-drive needs replacing. Is this possible on a Mac?
Yes, Just check your apple drive to see what it is set to primary or slave and replace as same. www.xlr8yourmac.com has great resources to check drive compatibility.
Apr 16, 2009 | Apple iMac G4 20" Mac Desktop
''imac g4 does not see dvd drive after Xferring files and setting
when booting in os x after the first boot chime immediately hold down keys <apple,option,o,f> all at the same time and allow computer to boot to open firmware once there type "reset-nvram" exactly like that but without quotation marks and press enter once it returns to command prompt type "reset-all"and press enter (you must have the "-" in between the commands) the computer should restart if not when the command prompt returns type "reboot" and hit enter ..... also you can check the drive status by going to "system profiler" in apple drop down menu--->about this mac-->more info or applications folder-->utilities folder--->system profiler then selct disk burning under hardware in the list on the left
Mar 18, 2009 | Apple iMac G4 Desktop
Mac dvd drive regency code locked
This is not a feature of the Mac - this is a feature of DVD-ROM drives and is part of the DVD standard.
DVD-ROM drives, once changed 5 times, can NOT be changed.
The only solution would be to purchase an external DVD drive, and set IT to region 2, and leave your internal one set to region 1.
The region settings are legal issues with the DVD standard - the 5-time limit is permanent, hardcoded, and unchangeable.
Aug 03, 2008 | Apple PowerBook G4 Mac Notebook
Apple iMac G5 Desktop Logo
69 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
