Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Socket Connect Error
We have just set up a new printer, but get this annoying Socket Connect Error on the printer's web page: http://knoll.simula.no/wcd/system.xml
without knowing what it means.
What is wrong?
  • 1 more comment
  • v2pjames Jun 16, 2008
    I am having this same issue with my C252.
    I understand that it's a problem with flash - but how do I go about fixing it?
  • Anonymous Jul 12, 2008
    Same problem. The HTML solution was useless.
  • vickih Oct 17, 2008
    I'm having the same problem as described by others.
  • 167 Answers
This is due to a problem with Flash.
You can log out and then in again, but view the page as HTML and not as flash.
BTW if you re going to post the back door to your copier over the internet you may want to change the Admin password.
I have been able to log in a view properly.
Posted on Jun 09, 2008
  • Kevin Hayes
    Kevin Hayes Jul 14, 2008
    To changfe from flash to HTML mode, simply click on the "log out" icon and when you are asked to log in again, do so as a user, but select the HTML option.
    You may need to hit refresh while holding the SHIFT key in order to reload from the server and not from your cache.
I have fixed this problem on our Konica Minolta C250. Read on here that it was related to Flash, so first tried to connect to the Konica with an older machine and found that it woked fine. No more 'socket connection error'.
Then, just for giggles, I tried uninstalling Flash all together on my own workstation (from Add Remove Programs) - and it works perfectly.
So just remove Flash while accessing the Konica. You can reinstall it again afterwards.
Lame, huh? Apparently the latest version of Flash is not compatible with the Konica.
Posted on Nov 14, 2008
  • Mohamed Ganaini Mar 27, 2017
    i did same steps but still the same issue appears, for konica c368
Hmmm, at least consider changing your administrator password instead of using the default one.
Posted on Oct 31, 2008
Bikeman...
You can still access your bizhub over the internet. Not good.
Posted on Aug 26, 2008
We have just set up a new printer, but get this annoying Socket Connect Error on the printer's web page. this for konica c368
must not have down loaded the latest firmware because there is firmware fix to his problem have a tech come out and update the firmware
Mar 27, 2017 | Konica Minolta Office Equipment & Supplies
Dymo\DLS8|printer Settings.xml access to the path is denied
Just remove PrinterSettings.xml and Settings.xml (in DataTracking folder). Next time you start the software it creates new files and the problem is gone.
Feb 04, 2012 | Dymo LabelWriter 450 Turbo USB Label...
HP Solution Center
When you click on the icon it is trying to open an xml file which is like a web page. The parsing error means there is an error in the page. I think the best way to cure this problem is to go to http://www.hp.com/#Support and put in the model number of your computer and download new drivers for your printer. You should also uninstall any current drivers you have from control panel's add and remove programs.
Dec 07, 2009 | Office Equipment & Supplies
Error 507 on blackberry 8700c
error 507 means that the operating system on the handheld is missing.
1) Download the latest version of the handheld os from your carrier's web site
2) Execute the downloaded file
3) Locate and delete VENDOR.XML from your PC's C: drive
4) Connect the BB and start Desktop Manager
It should reload now.
Oct 01, 2009 | RIM BlackBerry 8700c Cellular Phone
I cant find hpc20155.xml
This is direct from the HP website. some files were renamed... it works!
ISSUE: During the LaserJet P2015 Series USB installation, the following error message is displayed: 'hpc20155.xml' on HP LaserJet P2015 Series CD is needed SOLUTION: The HP LaserJet P2015 EWS driver on Microsoft Windows Update and Windows Market Place Web sites is newer than the driver that is included on the product CD that shipped with the printer. Because of this. the Microsoft Windows (Found New Hardware Wizard) will install the driver from the web. Some file names are inconsistent between driver version 1.0.0.12 and version 1.0.0.10, including the hpc20155.xml file, hence the attempt for the driver to search for the hpc20155.xml file will fail, and prompts the error message. To resolve this issue perform the following:
  1. Click the Browse button on the error message.
  2. Browse through the CD to Drivers -> windows 2000_XP .
  3. Select the file hppcp504.cab , and click OK .
  4. The error message "The Software that you are trying to install has not passed the windows Logo Test " appears. Click Continue Anyway .
  5. If the error message "hpc20155.xml on HP LaserJet P2015 Series CD is needed " appears again, follow steps 1-3.
  6. The required files are copied, and the driver is installed and ready to use.
If the issue still persists then perform the following in the order listed before trying to reinstall the software.
  1. Go to Start -> Control Panel -> System -> Hardware -> Windows Update.
  2. Set the option to Never search Windows Update for drivers .
NOTE: It is important to re-enable the Windows Update function after installing the printer software, otherwise the updates for all the other software on this computer will be blocked. After disabling Windows Update, complete the following steps. Be sure to reenable Windows update after installing the software:
  1. Disconnect the USB cable and remove the device listing from Device Manager
  2. Go to Start ->All programs ->HP ->P2015 ->Uninstall , "OR" Go to Add & Remove and check for the P2015 and uninstall .
  3. Then go to Printer & Faxes . Select the HP LJ P2015 icon and press the Delete button on the keyboard. After deleting the printer icon, go to File and Server properties . Go to Drivers tab and remove any P2015 drivers if listed.
  4. Also delete the following files/ folders C:\program files\HP\toolbox Fx or P2015 C:\documents & settings\app data\tool box Fx
  5. Run the scrubber.exe . Find this on the cd X:\utils\ccc\scrubber.exe & scrubber.ini NOTE: The Scrubber utility can also be downloaded from the web if the original installation CD is not available. However, it is only available as part of the full software installation package named hp_LJ_P2015_Full_Solution_AMWE.exe on hp.com . Once the files are extracted to a folder just open the util folder then the ccc folder and the scrubber.exe file will be visible.
  6. Paste these files at the following path and run the scrubber.exe C:\windows\system32\
  7. Empty the recycle bin
  8. Turn the printer back on.
  9. Now install the printer software again. Connect the communication cable to the PC and printer when prompted during the installation.
Sep 07, 2009 | Office Equipment & Supplies
Je n'arrive pas à desactiver le gestionnaire d'acces
Désactiver le Gestionnaire d'accès à des postes de déploiement
Si vous avez choisi d'identité Support Communications Express pour permettre l'accès au gestionnaire de Single Sign-sur panneau, et que vous souhaitez désactiver le support d'identité plus tard, suivez ces étapes:
1.
Set uwcauth.identity.enabled de faux dans le dossier de désactiver uwcauth.properties identité SSO.
2.
Prenez une copie de sauvegarde de l'actuel fichier web.xml de l'UWC-deploydir / SUNWuwc / WEB-INF / web.xml.
3.
Copiez le fichier web.xml de l'UWC-basedir / SUNWuwc / lib / config-templates / WEB-INF de UWC-deploydir / SUNWuwc / WEB-INF /.
Attention - Attention --
N'oubliez pas de fusionner les données de configuration supplémentaires que vous avez inclus dans le fichier sauvegardé à web.xml web.xml
-OR-
To Disable Access Manager Post Deployment
If you have selected Identity Support for Communications Express in Enable Access Manager for Single Sign-on panel, and you want to disable identity support later, follow these steps:
1.
Set uwcauth.identity.enabled to false in the uwcauth.properties file to disable Identity SSO.
2.
Take a backup of the existing web.xml file from uwc-deploydir/ SUNWuwc/WEB-INF/web.xml.
3.
Copy the web.xml file from uwc-basedir /SUNWuwc/lib/config-templates/WEB-INF to uwc-deploydir/ SUNWuwc/WEB-INF/.
Caution – Caution –
Remember to merge any additional configuration data you have included in the backed up web.xml file to web.xml
May 08, 2009 | Computers & Internet
Zebradesigner for xml ''error in processing zpf and lvr files''
Somehow, the correct printer driver is not installed when setting up Zebra Designer for XML.
To fix it, clck on "Start->All Programs->Zebra Designer for XML->Add Printer".
A wizard opens, select "Next" and choose the printer you are designing labels for. Click on "Next".
Select "Update existing printer driver(s)". The driver gets updated and voilá!, now you can export your label desgins.
Mar 19, 2009 | Zebra Z4M Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
5,512 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
