Question about IBM ThinkPad T21 2648 Notebook
Light blue color to the screen
Somehow on my HP T21 the screen has a light blue color where the white was normally there. Is there a solution for this? Is the screen going bad?
Also, if the cover is tipped to another angle, then a shadow effect of light blue with a little of the white appears.
  • JMS5000 Nov 13, 2008
    I have the same issue, except on a Dell 5100. Areas that are normally bright white are turquoise, and there are horizontal turquoise lines on tabs and stuff. Also, some areas are flickering like a bad horizontal hold on an old TV.
OK, after diligent searching on the internet, I found several instances where someone suggested that a video cable may have come loose. Before forking out cash for a new screen, I pulled mine apart. Lo and behold, a poorly fitted connection on the back of the LCD - taped into place that way by the technician who built the thing. Why it waited 5 years to fail is beyond me. Anyway, it's back to normal after reseating and taping it back down.
Posted on Nov 13, 2008
    Genius:
  • 2,028 Answers
It's possible that the screen is going, it's also possible that the inverter is going. An inverter can cause the same color change problem. It's definitely one of the two.
Posted on Jun 12, 2008
  • Ryan Rogers
    Ryan Rogers Jun 12, 2008
    One more thing. Check the connections from screen to inverter to board.
Display loses color after start up turning black & white
I wouldn't think that was the problem I would check the settings.
Mar 17, 2014 | HP G60-120US Laptop
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Installing fan & light control (27182) - in the box, there are red, white and black wires. On the control, there are red, blue and black. So, black to black; red to red; right?....does blue go to...
Under normal circumstances, NO! Black is normally power in to a box and to a switch. The switch controls the power out to the red line and most likely the blue line. White is always circuit neutral (ground). Your power will most likely come in via black and then go to the lights on either red or blue and to the fan on the other wire, either red or blue, the color you did NOT use for the lights. Some place you should also have a bare or green wire that would act as equipment ground, connecting to the metal of the box.
Sep 06, 2010 | Hunter Ceiling Fan Light Switch Control
Casio F91W-1 Wrist Watch- backlight color
You can change the backlight on a casio wristwatch by holding the Light button, but only if it has an LED light in the side of the screen such as yours does. There is Light Blue, Red, Pink, Blue, Green LEDs in the side of the screen and you can change between them. There is also an option that flashes between all the LEDs when you press the button.
May 06, 2010 | Casio F91W-1 Wrist Watch
Hp 6820s will not power up.
Try removing the battery and see if the light is normal.
If so, you may need to replace the battery.
Sep 28, 2009 | HP Computers & Internet
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Blue smudging down left side of the paper and paper turning greyish color
check the fixing unit if the adjustment for envelop is activated or not the same. set to normal.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
42" philips plasma flat panel television
same problem anyone know what his is please send me an email. real unhappy!!! this tv cost me $900!!!!! rami7344@bellsouth.net
Oct 22, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
IBM ThinkPad T21 2648 Notebook Logo
122 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Jax Planet
Jax Planet
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
