Question about Samsung Washing Machines
I have lost the booklet that came with our washing machine. It is a samsung WF-J125N. My young daughter tried toopen door while in mid cycle and it has just stopped. Once turned off i tried to run it again. It fills with water slightly, but wont run or do anything else then comes up with a message 2 or 3e or something! Is there anything i can do to put it right myself? Any help would be most appreciated! Thank you Regards Tina
    President:
  • 1,294 Answers
Click on 'washing machines'(below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is..
Opening the door of a front loader while running or to put in an extra cloth.........is not too good at all.
Posted on Jun 10, 2008
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Samsung front loader washing machine power cut out mid load
If by turning off the power you mean you hit the power button .... try unplugging the machine for about 15 seconds and then plug it back in ... this may reset the machine. If not you may want to call Samsung ...
http://www.samsung.com/au/info/contactus.html Hope this helps!
Nov 25, 2013 | Samsung WF337AA Front Load Washer
Problem with Hotpoint Washing Machines Samsung
ND -not draining. There could be something is stuck in the drain pump or one of the hoses connected to it( normally a coin is stuck in the L-shapped plastic connector to the drain hose)if the system is clear,then I would replace the drain pump.
Nov 02, 2013 | Samsung Washing Machines
Samsung wf317aag stopped mid cycle now machine has no power
First, are you sure there is power to the unit? Check the breakers and post back.
Nov 03, 2012 | Samsung WF317AAG Front Load Washer / Dryer
I set washer to be on cold/cold but it comes hot??
CHECK YOUR HOSES- SEEMS LIKE THAY ARE ON THE WRONG TAPS
Jul 06, 2009 | Washing Machines
Stuck Mid-Cycle, Wet Clothes!!
unplug the machine for 15 minutes then try again
Jun 09, 2009 | Whirlpool GHW9150 Duet Washer
Operating of samsung WF-B1061 washing machine
You can download the manual direct from samsung just go to their site type in your machine and download.
May 22, 2009 | Samsung WF317AAG Front Load Washer / Dryer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
64 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
