Question about Maytag Portable Air Conditioner M6P09S2A
M6P09S2A-When compressor kicks in the lights in the room go dim
Brought it out of storage, turn it ON and all of a sudden when the AC kicks in, all the lights in the room dims. I only can run the cooling FAN.....Any sugestions?????
  • 40 Answers
Call an electrician . Sounds like you are pulling too many amps. I wouldn't even run the fan....
Posted on Jun 12, 2008
Why is our a/c blowing room temp air when the setting is on cool?
It sounds like the compressor is not running. This could be due to a faulty thermostat, a bad start capacitor for the compressor, a bad compressor overload or simply a bad compressor. You would need a voltage meter to check all of these components.
Jun 20, 2014 | Maytag Portable Air Conditioner M6P09S2A
Relays click when interior fan is on
Often the click which can be heard when the A.C. kicks in is the clutch on the A.C. compressor. Be sure that it isn't just this sound which you are hearing.
Also check the operation of the idle control valve which is supposed to raise the engine revs to compensate for heavy power drain. If this isn't working correctly, then this would explain the lights dimming under low revs.
Nov 16, 2012 | 1998 Ford Escort
Turn my roof top ac on , fan runs but when compressor tries to run lights in camper dims 3 to 5 sec. don;t kick breaker off, any ideas?
You need to get a reading on the current draw of the compressor. Use a clamp on ampmeter to do this. Compare your reading with the data plate on the compressor. Your compressor may be getting ready to go out. You can also check the capacitor. If may be getting weak and need replacing. Another idea may be to install a hard start capacitor if the compressor is OK.
Sep 05, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic 57915.531 air conditioner in my camper. When the compressor goes on the lights go dim. Then if left on it will trip the circuit breaker. When I reset the breaker and turn the AC back on...
The compressor is not always starting...sometimes it tries but does not start...
It could be a capacitor and relay problem... or the compressor could be going bad...
Change the capacitor and start relay first and then see if that gets it going...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 04, 2010 | Dometic 57915531 Air Conditioner
I cannot get my wintair room air conditioner to stay on! It keeps cutting on and off, going from fan to air conditioning. Need help!!
It sounds like your air conditioner is doing what it is supposed to do. The compressor kicking in and out is an energy saving method of using the ac. When the thermostat (ball attached to evaporator coil) registers the set temperature the compressor kicks off.
Jun 28, 2010 | Heating & Cooling
Doesnt cool small bedroom with doors shut. I have
it should freeze that room with 9000btu do you hear the compressor turning on or is it blowing jus air? also helps if you switch the air intake to recirculate the room air rather than intaking the air from outside
Jul 30, 2009 | Maytag Portable Air Conditioner M6P09S2A
The ac lights inside the honda odessey van not on -> no ac
Could be a number of things..
Maybe a loose fan belt..
Maybe low on gas..
maybe a relay or sensor..
Hope this helps !!
Rte me good ;o)
Jul 13, 2009 | Kia Optima Cars & Trucks
Poetable AC compressor licks in for 10 min
It is probably either the high pressure switch or the frost control. The high temp switch usually trips because the condenser coil is dirty which does not allow it to exhaust heat very well. The frost control will trip if the system gets below 39 degrees on the pipes. This is usually do to low refrigerant or dirty filters. Good Luck!
Jul 03, 2008 | Maytag Portable Air Conditioner M6P09S2A
Heating & Cooling Logo
247 people viewed this question
Top Maytag Heating & Cooling Experts
Rick Johnson
Rick Johnson
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
